How Do You Calculate the Speed of a 20Hz Longitudinal Wave with 0.4m Wavelength?
  • Thread starter Thread starter whitehorsey
    Speed Wave
The speed of a longitudinal wave with a frequency of 20.0 Hz and a wavelength of 0.4 m is calculated using the formula v = wavelength × frequency. Substituting the given values, v = 0.4 m × 20.0 Hz results in a wave speed of 8 m/s. This calculation is confirmed as correct by participants in the discussion.
  • Understanding of wave properties, specifically frequency and wavelength
  • Familiarity with the formula for wave speed (v = wavelength × frequency)
  • Basic knowledge of longitudinal waves
  • Ability to perform simple arithmetic calculations
  • Study the characteristics of longitudinal waves in more detail
  • Explore the relationship between wave speed, frequency, and wavelength in different mediums
  • Learn about wave interference and its effects on wave speed
  • Investigate applications of wave speed calculations in real-world scenarios
Students studying physics, educators teaching wave mechanics, and anyone interested in understanding wave behavior and calculations.
whitehorsey
1. A periodic longitudinal wave that has a frequency of 20.0 Hz travels along a coil spring. if the distance between successive compressions is 0.4m, what is the speed of the wave?
2. v= wavelength times frequency
3. v= wavelength times frequency
= 0.4 * (20)
= 8 m/s ------ I'm not sure if this is right.
Looks good!
Welcome to Physics Forums.
thank you!
  • · Replies 16 ·
