What is the tension in the lift cable and in the string?
The discussion revolves around a physics problem involving a mass suspended in a lift, focusing on calculating the tension in the lift cable and the string under specific conditions of acceleration. The subject area includes dynamics and forces, particularly in the context of Newton's laws of motion.
  • Mixed
  • Participants explore the calculations for tension in the string and lift cable, questioning the assumptions about the masses involved and the effects of acceleration. Some participants attempt to clarify the roles of different forces acting on the system.
The discussion is ongoing, with participants providing feedback on each other's calculations and interpretations. There is an exploration of different perspectives on how to approach the problem, particularly regarding the forces acting on the string and the lift cable.
Participants note potential confusion regarding the mass supported by the string and the implications of the lift's acceleration on the tensions involved. There are references to specific constraints, such as the maximum tension the string can withstand before breaking.
Starrrrr
Part One:
A mass M1 = 30 kg is suspended by a light string from the ceiling of a lift of mass M2 = 300kg.
If the lift accelerates upwards at 1 m/s2, what is the tension in the lift cable and in the string? (g=9.8 m/s)
Part Two:
If the string breaks when subjected to a tension of more than 700 N, what is the greatest possible tension in the lift cable so that the string remains intact?
2. Homework Equations : t-mg=ma , f=ma3. The attempt at a solution: Part One: Tension in string, t-mg=ma, t-(30)(9.8)=30(1), t=324N
Tension in lift cable, t-mg=ma, t-(300)(9.8)=300(1), t=3240N ( Is this correct ?)
Part two: Not sure about part two.
Doesn't the lift cable have to support the weight of the 30 kg mass also?
Your right! So the combined mass is 330kg,then the tension= 3564N and the second tension force equals 3240N ?.
Can you please explain what you mean by "second tension force"?
Lol, sorry I mean the tension of the string
It looks like your result for tension of the string is off by a factor of ten. Can you take another look at that. Maybe it's just a typo.
How? I calculated the tension of string=(300)(1+9.8)=3240N
What mass is the string supporting? 30 kg or 300 kg?
Oh the mass of the string its 30 kg. 324N. Sorry, for the confusion.
For the second part, calculate the minimum acceleration of the lift for which the string will break.
so a=f/m = 700/330=2.12ms^-2
I thought the string only supported the 30 kg mass.
Oh I thought when buffu said 'acceleration of the lift for which the string will break' I had to combine the masses, I interpreted it wrong.
Also consider the directions of your accelerations. Which way does g point? What's the direction of the mass' acceleration as it's being pulled by the cable?
ok thanks.
so is the accerelation equal to=23.33m^-2
Starrrrr said:
t-mg=ma
This is the equation you originally used. You should use this same equation for this calculation. I'm sorry I didn't point this out sooner, but I just now noticed it.
Thats fine, thank you for your help :)
Just to explain a little bit, the answer you calculated (23.33 ms-2) would be the right answer for a mass of 30 kg sitting on a frictionless surface with the 700 N force acting horizontally. In the situation of this problem, the weight of the 30 kg mass is acting against the tension of the string so the acceleration is reduced accordingly. Contrast that with a problem where the 30 kg mass had a 700 N tension acting on it downward (in the direction of gravity), In that case, the 700 N force would produce a greater acceleration than the other two cases.
Why not make a FBD for these kinds of problem ?
