What is the unit conversion for 28.8 Volts/(Meter/Second)?
7 replies · 2K views · last reply
led20
Hi ALL
i need to unit Conversion :
from: 28.8 Volts/(Meter/Second) to (....) Volts/(Inch/Second)
from: 28.8 Volts/(Meter/Second) to (....) milliVolts/(milliMeter/Second)
Thanks
led20 said:
Hi ALL
Thanks
Hi and welcome to PF!
Let
Volts = V
Meter = m
Second = s
Inch = in
then
[tex]\frac{V}{m/s}=\frac{Vs}{m}[/tex]
while
[tex]\frac{V}{in/s}=\frac{Vs}{in}[/tex]
So if you were given a problem that said, for example, the metal costs $10/m, then could you figure out how much it costs per inch instead? That is, what is the value of x such that
[tex]\frac{$10}{m}=\frac{$x}{in}[/tex]
If you can figure this out, then your problem is essentially the same because we can ignore the Volt-seconds in the numerators since they're both equivalent (think of them as merging into the $ symbol in my example).
I do not understand your answer
Do you can , give me more Explain
Are you mean , like this:
(v.s/m)=(v.s/in)
(28.8v*1s/1m)=(xV*1s/39.4in)
then
28.8 v(m/s) = 1135 v(in/s) ?
your example:$10/m to x$/in
i thenk
1m=39.4in
$10/39.4in = $0.254/in
Thanks, now I understand (Excellent)
1 m/s = 39.4 in/s
28.8v/(m/s) / 39.4v/(in/s) = 0.73 v/(in/s)
then
28.8v/(m/s) = 0.73 v/(in/s)
it's good
but,What about the second question
You can make it more simple for yourself by ignoring a lot of the common units.
[tex]28\frac{V}{m/s}=x\frac{V}{in/s}[/tex]
We know that 1m = 39.4in, therefore we convert metres to inches by making that substitution wherever we see metres.
[tex]28\frac{V}{39.4in/s}=x\frac{V}{in/s}[/tex]
And cancel all of the common units on both sides (which is the same as dividing both sides by [itex]V/(in/s)[/itex]) to get
[tex]\frac{28}{39.4}=x[/tex]
Now for the next question, again, do the substitutions as I've just shown you. 1000 millivolts = 1 volt, 1000mm = 1m.
Note: remember we are striving for simplicity, so in your first problem, you could have canceled common factors by going straight from
to
[tex]28\frac{1}{m}=x\frac{1}{in}[/tex]
by cancelling V/s. This helps to draw focus onto the problem at hand and not get messed up with all of the units.
http://im86.gulfup.com/ckruO5.png
Very good, but you don't need to do it in 2 steps. Do it all in 1.
[tex]28.8\frac{v}{m/s}=x\frac{mv}{mm/s}[/tex]
Converting the LHS (left hand side):
[tex]=28.8\frac{1000mv}{1000mm/s}[/tex]
Cancelling the 1000's
[tex]=28.8\frac{mv}{mm/s}[/tex]
Hence x=28.8
Decorative graphic reading "Thank You!" in green script beside a bouquet of white daisy-like flowers with black outlines and green leaves on a light green background.
