What Is This Mysterious Physics Equipment?
  • Thread starter Thread starter badteddy
    Equipment
The discussion centers around identifying various pieces of physics equipment found in a university's equipment room. Participants are exploring the potential uses and characteristics of these items, which range from antique to more modern equipment. The scope includes technical identification and historical context of the equipment.
  • Participants discuss various items, with one suggesting that photo #4/9 is a lab demo box for lowpass and highpass filter characteristics.
  • Another participant notes the presence of a synchronous spark timer from 1980, indicating the age of some equipment.
  • One participant proposes that image 712 may be an instrument for measuring magnetic declination.
  • Another suggests that image 731 is a parallel plate capacitor, while image 736 is identified as some sort of electroscope.
  • Image 740 is speculated to be used for studying buoyant force, with a question about a possible outlet for a pump.
  • There are differing views on item #10, with one participant identifying it as a low voltage DC electric motor, while another suggests it is a motor/generator.
  • Item #2 is identified by multiple participants as dip circles, which can move in both vertical and horizontal directions.
Participants generally agree on some identifications, such as item #2 being dip circles. However, there are competing views on the identification of other items, and the discussion remains unresolved regarding some specifics.
Some identifications depend on assumptions about the equipment's function and condition, and there are unresolved questions about the exact nature and use of several items.
This discussion may be useful for individuals interested in historical physics equipment, those involved in equipment cataloging, or anyone studying the evolution of physics laboratory tools.
badteddy
I'm working for the physics department this summer and I've been tasked with cataloging our equipment room. Part of this job involves identifying equipment used by previous professors but that no one knows about anymore. Could I get assistance in identifying some of these items or the labs that they might be used for?
Here are pictures of all the equipment:
http://docs.google.com/leaf?id=0B40qb-5Nbo80ZmNjNDFjNWMtZTAwMS00Nzk4LWJmY2QtYTJiNjEzYjA5Y2Jj&sort=name&layout=list&num=50
Welcome to the PF. It looks like folks would need a Google Docs account to view those pictures. Can you upload PDFs or JPGs as attachments?
Whoops, my bad. I think this link will work with much better success:
http://picasaweb.google.com/theodore.lindsey/PhysicsEquipment?feat=directlink
PS. Thanks for the speedy response.
Wow, that's some antique stuff!
The only one I think I can help with is photo #4/9. It looks like a lab demo box for experimenting with Lowpass and Highpass filter characteristics. You get either Lowpass or Highpass output characteristic, depending on whether you use the top rail or the bottom rail as the ground reference. Input from the signal generator is at the left.
So it would appear that #4 and #9 are part of the same lab?It sure is old. That isn't even the most ancient stuff I'm finding while digging through the equipment room here. Perhaps one of the most amusing is a synchronous spark timer that has a note on it stating that it worked dated 1980. It appears that I'm the first to go through some of the really old stuff in quite some time.
I found one more item that puzzled me: http://picasaweb.google.com/lh/photo/a0ZdcLtom55IduX9T1uW9g?feat=directlink
It appears to be some sort of motor...
My guess for some of the items:
Image 712 - at least one of them looks like an instrument for measuring the angle of magnetic declination (if the needle is magnetic)
Image 731 - a parallel plate capacitor. At least one plate can be moved by using the Plexiglas handle.
Image 736 - some sort of electroscope
Image 740 - Used to study buoyant force, maybe. Is there any outlet on the other side of the big sphere? Something to connect it to a pump?
I agree with nasu's guesses(items 2 are actually called dip circles)
In addition I think that item 6 is a variable spark gap(needs to be connected to a suitable supply eg an induction coil) and item 10 is a motor/generator.
Item 8 could be a leyden jar.
Item # 10 is a low voltage dc electric motor, possibly pre - 1900. It is series-connected and reversible. Look for a manufacturer's name on it. Do not put excess voltage on it. It is probably rated at 3 to 6 volts. The commutator is probably very dirty and oxidized, and does not conduct. Measure resistances, and do not exceed 1 amp (I = V/R).
Bob S
Item #2 appears to be three compasses, that can move in both vertical and horizontal directions (not at the same time).
Yes they are called dip circles.In my post above I referred to item three instead of two.Having reading your post I had another look and corrected my mistake.
Thanks for all your help. Once I knew what I was looking for, I was able to confirm each of those items and have had great success with the project. Thanks again for your help.
-Theodore
  • · Replies 33 ·
  • · Replies 119 ·
18K
