What Math Class Teaches us how to Draw a Graph?
  • Context: High School
  • Thread starter Thread starter askor
    Class Graph
The discussion revolves around the mathematical concepts and classes involved in drawing graphs, particularly focusing on functions like y = x^2 and y = 9x - x^3/9. Participants explore the relevance of algebra, calculus, and other mathematical principles in graphing techniques, including the identification of turning points and the behavior of functions at infinity.
  • Homework-related
  • Some participants suggest that graphing is primarily taught in algebra classes, particularly in high school and pre-calculus courses.
  • Others argue that drawing graphs can be done by plugging in values for x and calculating corresponding y values, which does not necessarily require advanced math.
  • A participant mentions that graphing more complex functions, such as cubic functions, involves understanding derivatives and turning points, which are typically covered in calculus.
  • Some participants discuss the steps involved in graphing functions, including determining zeros, differentiating, and identifying asymptotes.
  • There is mention of historical perspectives on teaching graphing, with references to older educational materials that included derivatives in algebra courses.
  • One participant highlights that polynomial functions can be graphed in earlier grades using simpler methods, such as the table method.
  • Discussions also touch on the definitions of polynomials and the nature of their coefficients, with some uncertainty expressed about the classification of polynomial functions.
Participants do not reach a consensus on the specific math classes that teach graphing techniques, with multiple competing views presented regarding the role of algebra and calculus. The discussion remains unresolved regarding the best methods and educational approaches to graphing functions.
Some participants note that the understanding of graphing may depend on the definitions used and the educational context, leading to varying interpretations of when and how graphing is taught.
This discussion may be useful for students exploring the mathematical foundations of graphing, educators looking for insights into teaching methods, and individuals interested in the historical context of mathematics education.
askor
What math the drawing a graph, for example: y = x^2, is taught? Is it algebra, calculus, or any other else? Thanks
Mathematics news on Phys.org
Have you done any research on this? What have you found?
Algebra probably. Draw how? In a graphing tool it's simple. Drawing it by hand is difficult for non-trivial functions as it requires you to solve the equation for a lot of different values and then plotting them as points; this is tedious work and will only give you a poor approximation of the actual graph.
It is taught in a class called algebra in high school (NOT abstract algebra), and often called pre-calculus in college.
How do you draw the graph of ##y = 9x - \frac{x^3}{9}##?
I only know how to draw a graph of quadratic function. This function has a power of 3.
Where are the turning points? What is the value of the function at those points? How does the function behave as ##x \to \pm \infty##?
We call it curve discussion here at school. The recipe is always the same:
  1. Determine the zeros of the function.
  2. Differentiate as often as it is possible.
  3. Determine all zeros and sign changes of all derivatives.
  4. Determine all poles.
  5. Determine the asymptotes at the poles.
  6. Determine the asymptotes at infinity.
Once you have all these, you can draw the curve very precisely.
Without knowing any algebra or calculus, you can just plug in some values for x and calculate the resulting values of y. Do you know any calculus? (You have not posted any information about your background in your profile.)
Yes, I learned calculus of differentiation and integration.
Then you should be able to do the steps that @fresh_42 put in the post above (possibly with some review). His list looks complete to me.
You need limits and differentiation to apply all steps outlined by the moderator above in post#8. This is typically high-school education in most countries. I wouldn't call it advanced stuff, but surely not elementary.
if the graph of a differentiable function changes direction, then the derivative equals zero somewhere in between. This means the graph does not change direction between any two consecutive zeroes of the derivative. Thus the most efficient way to graph a function is to plot the zeroes of the drivative and then to determine the limits at ± infinity. If the derivative has no zeroes, and even if it does, you will also want to plot a few other points, such as where it crosses the x-axis and/or y axis, and where it changes curvature. It is thus useful to plot zeroes of the second derivative, since curvature can only change at these points.
It follows that efficient graphing can only be taught in or after a course which teaches derivatives, hence usually calculus, at least today in the US. Note however that over 100 years ago in the US, we had more elementary books such as Treatise on Algebra by Charles Smith (1888), that did treat derivatives, so my father may have learned this in high school in the early 1900's.
THAT, or at least mostly.
Students learn to make simple graphs in "Algebra 1", and the studies for making graphs continue from there.
If at least you have studied your Algebra 1, then you know to either (1) use a graphing tool, or (2) plug in values for x and evaluate corresponding y values; and then plot your points and draw your curve. Too simple? You learn more about such graphs in College Algebra.
This is the original problem of what I asked:
How do I draw the V shear and M moment graph like above?
The image and question (post #16) seem to give a sense of mechanical engineering or Physics(mechanics). One would learn to draw pictorial figures AND make graphs throughout Mathematics courses and not only starting with Algebra 1. You first asked "What Math Class Teaches us how to Draw a Graph"? ALL OF THEM!
I will go out on a limb and try to answer the original question, but I could easily make mistakes.
To graph y = 9x - x^3/9, first set y = 0 and get x = 0, 9, -9. If one also notes that the leading term is a constant multiple of -x^3, one knows the graph comes down from + infinity on the extreme left and goes down to - infinity at the extreme right. Hence just graphing these 3 points, (-9,0), (0,0), and (9,0), one knows the graph comes down from the left, crosses the x-axis at (-9,0), then at some point between x= - 9, and x= 0 , the graph turns up again, crossing the x-axis at (0,0), continues upward, then turns down again at some point between x=0 and x = 9, and goes down again, crossing the x-axis at (9,0), then continues on down to minus infinity. Calculus is not really needed for this rough graph, which looks a bit like a fishhook on the left, and an upside down fishhook on the right, with their points meeting at (0,0).
To find the 2 turning points, use calculus to take a derivative, getting y' = 9 - x^2/3, and set it equal to zero, getting x^2 = 27, or x = ± sqrt(27). Plotting these two points gives the turning points as (-sqrt(27), -6sqrt(27)), and (sqrt(27), 6 sqrt(27)).
To clarify that the curvature does indeed change from concave up to concave down at (0,0), compute the second derivative y'' = -2x/3, set it equal to zero, getting x=0.
To compute the slope of the graph at this "inflection" point, compute y'(0) = 9, getting the slope of the tangent line at (0,0).
That is about what a calculus student of mine would learn.
One usually learns to graph polynomial functions, which your example here resembles, in College Algebra.
I said, "resembles" not "is". Some people will tell that a polynomial function has integer coefficients. I am not fully certain if this is or is not correct.
Polynomials can have coefficients from any ring or field.
I have seen this done as early as 5th and 6th grade math. Although they take a "table" method approach. Ie., they give a naive definition of a function, then pick a few nice numbers to plug into the function, and tell you to connect. One starts learning other methods, besides the one mentioned above, in Algebra 1. You redo it again in Algebra 2, but learn new techniques to graph polynomial of higher degree than 3.
Only the exponents of the variables of a polynomial need to be positive integers (including 0).
I made a technical word choice mistake. The exponents in polynomials are the Whole numbers. "Integers" obviously the wrong word choice.
Actually students are taught about graphs, not just at Algebra 1, but also BEFORE reaching the course. Elementary kids are taught about bar graphs and pie charts. Maybe other kinds...
  • · Replies 18 ·
