What mistake did I make in my time-dependent force problem solution?
  • Thread starter Thread starter Loststudent22
    Force
10 replies · 4K views · last reply
Loststudent22
A time-dependent force,
= (9.60
− 4.10t
), where
is in Newtons and t is in seconds, is exerted on a 2.00-kg object initially at rest. (a) At what time will the object be moving with a speed of 15.0 m/s?
F=ma
I solved for a then integrated that and got 4.8t-1.025t^2
Set it equal 15 squared both sides to eliminate the square root when solving for the magnitude and finally got 23.04t^2-1.05t^4 -225=0 and can't solve it. So I must have made some mistake.
[ URLs fixed by a mentor ]
Loststudent22, you didn't have the correct URLs for the i and j characters at your webassign site. I fixed them.
Next time you can try latex. ##{\hat{i}}\ {\hat{j}}##
They were the I and J hat vector components. I will have to look into latex I"m not familiar with it yet. I'll trying using a picture next time for the question and my work.
Have you tried a substitution for t? You should be able to turn the equation into a quadratic...
I plugged the equation into wolfram to solve for t and it didn't give a answer
You have:
Let : x = t^2
Write the equation in terms of x. Can you solve that?
Yeah it doesn't work it gives an answer with imaginary numbers. I pulled out my 89 and it just says false when I try to use the solve function. Is it possible the online assignment gave me numbers that don't work nicely or I must have made some mistake.
So you should revisit how you derived your equation. Lay out the steps so we can take a look.
F=ma
a=4.8-2.05t=dv/dt
To arrive at an equation for the instantaneous velocity of object I integrate the above equation
V=4.8t +c1-1.025t^2+c2
The object is at rest when t = 0 s. so c1=c2=0
When V=15 m/s
The magnitude of V=15=√(4.8t)^2+(1.025t^2)^2
I square both sides to eliminate the square root and got the equation I'm having trouble with
Loststudent22 said:
F=ma
a=4.8-2.05t=dv/dt
When V=15 m/s
Really? Because I spot a sign difference right away.
