What should be the mean effetive pressure ?
  • Thread starter Thread starter falik
    Mean Pressure
The discussion focuses on calculating the Indicate Mean Effective Pressure (IMEP) for a 4-stroke, single-cylinder engine with specific parameters, including 7.5 KW brake power, a mechanical efficiency of 80%, and a maximum pressure of 34 bar. The mean effective pressure (MEP) represents the constant pressure that would produce the same work as the engine during its cycle. To find the MEP, one must first calculate the net work done in one cycle and determine the engine's displacement volume using air standard analysis. The conversation also emphasizes that homework questions should be directed to the appropriate forum, indicating a preference for organized discussions. Understanding the MEP is crucial for evaluating engine performance effectively.
falik
A 4 stroke, single cylinder engine working on constant volume cycle, developes 7.5 KW brake power at 60 rev/sec the mechanical efficiency being 80%. The pressure at the beginning of compression is 0.97 bar, the engine has a volumetric compression ratio of 7 and the maximum pressure reached in the cycle is 34 bar. If both compression and expansion is according to the law PV= costant where n=1.38, calculate Indicate Mean Effective Pressure ?
bump ! anyone ?
Homework questions are best answered in the relevant forum. Also, if you're expecting an answer within 7 hours of posting a question, you may be disappointed.
It is presure that is mesured on the "motor table" (i don' know how to say in english, maybe dyno table?).
Please refer all future HW questions to the HW Forum. Anyway...
The mean effective pressure (MEP) is the theoretical constant pressure that if acted one the piston for the entire stroke would produce the same amount of work actually developed. This can be shown mathematically as:
MEP = net work for one cycle / displacement volume
You first need to determine the work created from one cycle. Then using either the air standard analysis or the cold air standard analysis you need to work backwards to determine the displacement volume of the engine. Once those two parameters are found, you can then easily find the MEP.
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Calculate minimum RPM to self-balance a CMG on two legs'
Here is a photo of a rough drawing of my apparatus that I have built many times and works. I would like to have a formula to give me the RPM necessary for the gyroscope to balance itself on the two legs (screws). I asked Claude to give me a formula and it gave me the following: Let me calculate the required RPM foreffective stabilization. I'll use the principles of gyroscopicprecession and the moment of inertia. First, let's calculate the keyparameters: 1. Moment of inertia of...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
