What Speed Range Keeps a Car from Skidding on a Banked Curve?
  • Thread starter Thread starter matibtst
    Curve
The problem involves a banked curve with a radius of 30 meters, where a 950 kg car is traveling at 40 km/h. The task is to determine the range of speeds that allows the car to navigate the curve without skidding, given a coefficient of static friction of 0.3.
  • Exploratory, Conceptual clarification, Problem interpretation, Assumption checking
  • Participants discuss the need to understand the forces acting on the car, including the role of friction and the banking angle. Some suggest drawing diagrams to visualize the problem, while others question how to derive the slope of the curve and the relevant equations.
There is an ongoing exploration of the problem, with some participants providing guidance on drawing diagrams and considering the forces involved. Multiple interpretations of the frictional forces and their effects on the car's motion are being discussed, but no consensus has been reached.
Participants mention constraints such as the need for more effort in problem-solving and the requirement to understand the equations introduced in their physics class. There is also a reference to the icy condition where the coefficient of friction is zero, which adds complexity to the problem.
matibtst
curve banking problem?
a curve of radius 30m is banked so that a 950kg car traveling 40 km/h can round it even if the road is so icy that the coefficient of static friction is approximately zero. Find the range of speeds at which a car can travel around this curve without skidding if the coefficient of static friction between the road and the tires is 0.3
This part i really need help in pls may i ask for any equations to use i can't even understand the problem. I can't interpret the free body diagram pls give me a formula ^^
none i tried drawing a slope with an object but i don't know how to get the angle of the slope...
What class are you taking? What equations are introduced in the chapter that this question is from? You need to show more effort before we can help you much.
think about this
when the car has maximum speed, friction is down the slope and when speed is minimum, friction is up the slope
First ignore the friction and calculate the slope of he curve from the icy case. Draw a diagram to show the forces on the car.
How do i calculate the slope pls.. I'm taking physics natural science and the last formula our pro gave us was the coefficient of friction times normal force is equal to force of friction. so i don't know how to get the slope of the problem i don't even know how to derive where the slope came from sorry
thank you for the diagram it has been very helpful thank you very much i at least have an idea now on how to sole ^^
Extending it to the case of friction just involves adding the extra foces, remember that friction will act parrallel to the road in a direction to stop the car slipping.
As you said above, friction force is the normal force * coefficient of friction.
I guess frictional force considered in this question is the force acting perpendicular to the road which avoids the car slippin towards or away from centre of the circular track(or any kind of track, maybe call it instantaneous center) at lowest and highest speed at the curve respectively.
the frictional force mgb_phys is considering is the force which gets the car going
  • · Replies 20 ·
