What tests can falsify general relativity?
118 replies · 14K views
Demystifier said:
Just the opposite, since I can measure only the present, I want a singularity in my present.
I mean a singularity that was in your past, now is in your present, and will be in yiur future. This phasing is very non-relativistic, but i hope it is clear.
For anything not near you, you only measure information from your causal past. By definition of horizon, any singularity behind a horizon is never in your causal past (but it does change from being in your causal future to “possible present” - spacelike separation, at a specific event on your external world line). You never get information from it because it is never in your causal past.
Big bang singularity, if it really exists, would would always be in your causal past and, in principle, you get information from it.
A naked singularity from a collapse has all three causal relationships with an external observer. Causal future, whence you can send something to reach the singularity at formation. “Possible now”, whence you can no longer influence its formation or detect it yet. Causal past, whence you can get information from its formation.
Although I can't really add to the discussion at hand, I would like to add a paper for those interested in an experiment that did deal with the SEP (Strong equivalence principle) that be found here:
https://www.nature.com/articles/347261a0
A interesting thing you may notice in the paper is the bring up speculation of a "5th force", so when I read it, I asked my advisor why they even did that. Apparently during the (80s?), there was a some work done on a potential "fifth force of nature", so in some older papers you may seem them addressing those claims. Not sure if there are many "fifth forcers" around anymore though...
Enjoy!
Is it enough if c is not constant ?! When I approach a light source, the frequency increases, but the duration of the pulse that passes also becomes shorter. Conversely, the frequency decreases when removed, but the duration of the pulse also becomes longer. The same pulse passes me in a shorter and longer time. This is only possible if the speed of light (the pulse) (relative to me) becomes higher and lower.
  • Skeptical
No it isn't. It's trivial to Lorentz transform the leading and trailing edges of a light pulse and show that the lengths and frequencies change, qualitatively in the way you describe, but that the speed is invariant.
Say the trailing edge of a pulse of light moving in the ##+x## direction is at ##x=0## at ##t=0##. Then you can write down the position of the ##n##th wave crest infront of that as ##x=n\lambda+ct##. Then you use the inverse Lorentz transforms, ##x=\gamma(x'+vt')## and ##t=\gamma(t'+vx'/c^2)##, to eliminate ##x## and ##t## and rearrange. The result is $$x'=n\sqrt{\frac{c+v}{c-v}}\lambda+ct'$$which shows the Doppler shift factor multiplying ##\lambda## and that the wave speed is still ##c##.
Ibix, your rebuttal is invalid, because this (Lorentz transforms) is derived directly from the assumption that c is constant.
  • Skeptical
No, his rebuttal is valid, because he is showing you that there is a perfectly self-consistent solution to the scenario you proposed that has ##c## constant--and since ##c## being constant is an experimental fact, we should use the solution that is consistent with that fact, not some other solution that you or anyone else dreams up that isn't.
Your claim seemed to me to be that Doppler shifts and pulse length variation were inconsistent with an invariant speed of light (apparently Peter thought the same). I showed that they are consistent by deriving those effects with, as you say, an assumption of invariant light speed. That would not have been possible if your claim were true.
Did I not understand what you were claiming?
Inferring something based on an assumption is different from a measurement or hard evidence. It is an elaboration of an assumption and therefore remains an assumption. Since a speed is a length divided by a time duration at all times, I cannot avoid different speeds if I divide the same length by different durations. This is evidence without assumptions, purely scientific.
  • Sad
  • Skeptical
Of course. But we have plenty of evidence that ##c## is frame invariant. So my argument is based on an assumption with a lot of experimental justification.
You continue to fail to understand how different frames measure light beams, as you did in your last two threads on the topic.
Rubbish. You are making assumptions, such as (incorrectly) assuming that different frames see a light beam as having the same length. This is not the case in a relativistic universe.
True, but irrelevant, since we have plenty of measurements and hard evidence regarding the speed of light. It seems as though you do not understand what this evidence means, physically.
Which is not what is going on with the relativistic Doppler shift. @Ibix has already explained what is going on and why it is perfectly consistent with an invariant speed of light.
Light is not easy to measure. Is there a measurement of the speed of light where the light source and observer move with respect to each other at high speed? If not, how can you be sure?
  • Skeptical
Synchrotron radiation. Black hole jets. See also section 3.3 of the experimental basis of special relativity FAQ, linked from a pinned post at the top of this forum.
Note that you are shifting your goalposts here. Your initial claim was that a constant speed of light was inconsistent with Doppler effects. I showed that this was false. You are now asking a different question about the experimental basis of relativity, which seems to me to be rather off topic for this thread.
Alväger, T.; Nilsson, A.; Kjellman, J. (1963), "A Direct Terrestrial Test of the Second Postulate of Special Relativity", Nature 197 (4873): 1191.
Note the year.
No. The observation of far away spectroscopic double-stars proved, that the light arrives with the same speed relative to a telescope on earth, when one star is moving away from the Earth and appears red-shifted, and later is moving back towards the Earth and appears blue-shifted.
Sources:
https://en.wikipedia.org/wiki/De_Sitter_double_star_experiment
https://en.wikisource.org/wiki/A_proof_of_the_constancy_of_the_velocity_of_light
If the speed of light would depend on the speed of the light source, then multiple optical copies of each star in a far enough double-star system would be measured in a spectroscopic analysis as moving slowly in only one direction - apparently violating Keplers law. But that is not measured. See animations for one of the two stars, for different observation distances:
http://www.physik.li/beispiele/Doppelstern/Doppelstern.htm
It seems the basic absurdity with @Speady 's argument has not been raised. The statement
The italicized part of this argument would apply exactly as stated for blue light versus red light for flash bulbs, stationary with respect to some detector. Does @Speady believe different colors of light travel at different speeds? I hope not, and the resolution is that the wavelength of a pulse is different. Doppler changes the wavelength of a pulse exactly inversely to frequency change. A shorter wavelength divided by a shorter duration, then produces exactly same speed. The key point is simply that red light doppler shifted to blue has all the same properties as blue light directly emitted as blue, including shorter wavelength. Quite frankly, the misunderstanding here is one that would be surprising even for someone with no background beyond a typical high school physics discussion of waves.
PAllen said:
It seems the basic absurdity with @Speady 's argument has not been raised. The statementThe italicized part of this argument would apply exactly as stated for blue light versus red light for flash bulbs, stationary with respect to some detector. Does @Speady believe different colors of light travel at different speeds? I hope not, and the resolution is that the wavelength of a pulse is different. Doppler changes the wavelength of a pulse exactly inversely to frequency change. A shorter wavelength divided by a shorter duration, then produces exactly same speed. The key point is simply that red light doppler shifted to blue has all the same properties as blue light directly emitted as blue, including shorter wavelength. Quite frankly, the misunderstanding here is one that would be surprising even for someone with no background beyond a typical high school physics discussion of waves.
As someone who has not really delved into upper division physics yet, would this be of relevance?
c = λ f
(The very first thing anyone learns in high school about light wavelength and frequency)No mention of transforming between reference frames in that lecture everyone has, and I’m pretty sure that is taught in the context of an inertial observer at rest with respect to the source.
c = λ f
No, but that equation turns out to be valid in any frame. The wavelength and frequency are transformed when changing frames in such a way that their product is invariant.
Grasshopper said:
c = λ f
The formula is true in every frame (which is why no mention of the frame needs to be made). Both ##f## and ##\lambda## are frame variant such that ##c## is invariant. That is, the Doppler shift factor for ##f## is the reciprocal of the factor for ##\lambda##.
The Doppler effect follows simply from the Lorentz transformation properties of the electromagnetic field as a tensor, and since it is a massless field its propagation speed is ##c## in any reference frames and independent of the speed of the source emitting the waves. The (quite simple) calculation can be found in my FAQ
https://itp.uni-frankfurt.de/~hees/pf-faq/srt.pdf
sect. 3.2.1.
pervect said:
Tests that special relativity holds locally also test GR - for instance, the Michelson Morely experiment. Wills describes this as "tests of local Lorentz invariance". So if any of the standard SR tests of the speed of light failed, GR would also be falsified.
Α simple test could be to measure the speed of light derived from a surernova.
As the universe is expanding,a supernova at the edge is apparently moving with a speed of 3c or even 4c.They could measure the speed of its light and if they find it as c,then we could say that really the speed of light is independent of the frame.
Did they measure the speed of light derived from an airplane as it lands?
I'm not sure that this particular experiment has been done. Measuring the speed of light from moving sources has certainly been done, both from astronomical sources like binary stars and lab sources. See posts #103-#105.
There's a problem though - space isn't a vacuum, and the light from the supernova would probably interact with atoms along the way. The usual theoretical framework is that the light is absorbed and re-emitted, so the effective source of any scattered light would be from particles it encountered along the way in many theoretical frameworks.
Lab experiments of the speed of light from the decay of various rapidly moving particles have been done however to get around this issue. No effect on the speed of light has been observed.
Wiki mentions that there were some tests measuring the constancy of the fine structure constant from quasars, though, which found a variation with time. These results were not confirmed by other tests, though. More sensitive later tests did not find such a variation. The speed of light is one of the constants that determine the fine structure constant - I've talked at some length about how the speed of light is related to the fine structure constant and why it's better to measure the fine structure constant and not c directly. The short answer to this is units, the fine structure constant is dimensionless, so it has a direct physical meaning independent of any framework based on units and measurment standards. This avoids the whole issue of needing to think about the basis of such standards, and whether the standards could themselves be varying.
See http://www.edu-observatory.org/physics-faq/Relativity/SR/experiments.html#moving-source_tests for discussion about measuring the speed of light from moving sources, and https://en.wikipedia.org/w/index.php?title=Time-variation_of_fundamental_constants&oldid=994755304 for a discussion of variation of fundamental constants.
These "speeds" are not relative velocities in the SR sense (those must always be less than ##c##). So you can't use these speeds to define a "frame".
You can't directly measure the speed of light going from place to place inside a very distant object.
  • Skeptical
Richard R Richard said:
Is there an exact solution to the Einstein field equations for "n" gravitating masses?
No. This case can only be solved numerically.
Nugatory said:
So no, your premise is not true, at least not in a way that would lead to the your later concerns and conclusions.
I confess I do not understand it, but it is true, as given in the quote by Einstein below.
" Here is how Einstein formulated the idea in his major, 1916 review article, written just after the completion of the general theory of relativity. Einstein points out that his considerations lead coordinates to lose their direct metrical significance. " (my emphasis)
More of it here : http://www.pitt.edu/~jdnorton/teach...nce_GR_relative/significance_GR_relative.html
The way I used to understand it is that, since all manner of transformations are possible, "length" does not have to go into "length" also, if you know what I mean. Likewise, time can go into ##\text{time}^{\text{squared}}##. Or some product of space and time. Either way, the spatial significance is gone, and since no coordinate system is preferred, all observers have to admit that space and time measurements become meaningless. Or am I mistaken?
Nugatory said:
A cautionary note: You should not be trying to learn relativity from that book, for about the same reasons that we don't teach classical mechanics from Newton's Principiae.
Very different things. Newton's Principia is a scholarly presentation where he uses Euclidean geometry to show, among other things, why the gravitational force has to be central. Einstein's book is an expository one. Of course no one should learn classical mechanics from there. Likewise, no one can learn general relativity from Einstein's exposition, but can develop an idea about it. Either way, it does not answer the philisophical questions I raised - namely, do space and time become mere illusions and matter and fields the really fundamental entities that give space and time their extstance. I understand these are very subtle matters.
I think, Einstein's book is still a good starting point to learn general relativity, but of course today the subject is much more advanced.
It's also true that coordinates are just labels of space-time points. They usually do not refer directly to observable quantities. What's observable in GR is given by coordinate and frame-independent tensors, particularly space-time "metrics" like lengths and times.
Concerning your philosophical questions I'd say today everything is on the fundamental level described by (quantized) fields.
The quote does not say that "space and time" lose their physical meaning. It says that "coordinates" lose their physical meaning. Big difference.
You are most definitely mistaken. Does the lack of a preferred coordinate system mean you can't use a ruler to measure how long an object is, or a clock to tell you how much time has passed? Of course not.
You can measure a space-like interval with rulers. You can measure a time-like interval with clocks. No need to bring coordinates into it. Measurements that you make remain objective and invariant. In that sense, time and space remain firmly physical.
If you choose to apply coordinates to the endpoints that you are measuring, you are not required to choose coordinates in which varying the fourth coordinate value while holding the other three fixed always results in describing a time-like path. Nor are you required to choose coordinates in which varying the first coordinate value while holding the other three fixed always results in describing a space-like path.
You can use coordinate systems that are quite strange. You can even use null coordinates. The formula for the metric (when cast in terms of the coordinates you choose) will change depending on the coordinates you choose. The inability to pick out a particular element of your coordinate tuples as being "the time coordinate" does not stop you from using the coordinate system to calculate the elapsed proper time from event A to event B along a prescribed path.
