What to do with 1 year+ expired bleach?
  • Thread starter Thread starter kyphysics
    Year
The discussion revolves around the safety and proper disposal of bleach that has expired for over a year. Participants explore whether it is safe to open, use, or pour down the drain, considering factors such as concentration, potential hazards, and local regulations regarding hazardous waste.
  • Experimental/applied
  • Some participants suggest that the bleach may still be safe to open and use, arguing that it likely retains some effectiveness despite being expired.
  • Others caution against pouring it down the drain without checking local regulations, noting that it may be classified as household hazardous waste.
  • A few participants propose using the bleach for cleaning purposes, indicating that it might still work adequately for less critical applications.
  • Concerns are raised about the environmental impact of disposing of bleach improperly, with some advocating for using it rather than discarding it without purpose.
  • There are mentions of the chemical stability of sodium hypochlorite and its decomposition over time, leading to a reduction in available chlorine.
  • Some participants share personal experiences with expired bleach, noting the absence of chlorine smell and their decision to discard it after testing.
Participants do not reach a consensus on the best course of action regarding the expired bleach. There are multiple competing views on its safety for use and disposal, with some advocating for its use while others recommend caution and adherence to local waste disposal guidelines.
Participants express uncertainty about the exact concentration of the expired bleach and its potential effectiveness. There are also references to local regulations that may vary by location, affecting how to dispose of the bleach safely.
kyphysics
Mine expired in March 2020...I had it "hidden" under a laundry area sink and was using newer ones and forgot about it...
Safe to open?
Safe to pour down drain?
Chemistry news on Phys.org
Just guessing the concentration as the hypochlorite is now too weak to do anything. You have just an alkaline solution, and you should be able to run it down the sink with running water. I would still take care to not touch it, not splash it, and not allow any to get into eyes.
Definitely safe to open, if it wasn't left opened it is most likely still active and OK to use.
Regulations require expiration dates even on things that have infinite shelf life. The only bad thing that can happen to bleach is it can lose activity if the chlorine seeps out.
About that bleach... Likely it's just as good as a new one.
  • Haha
Maybe check your local city/county website to see if they consider it a "household hazardous waste". If it is, you should be able to find a free drop-off/recycling center where you can take it (and any other stuff you are wanting to get rid of). This is for where I live:
https://www.sccgov.org/sites/rwr/hhw/Pages/What-is-Household-Hazardous-Waste-and-How-do-I-Dispose-of-it-.aspx
Can you not use it in circumstances where the exact free chlorine concentration is not critical?? It is likely just a little less potent than advertised. Wash your deck or your white clothes. Don't just pour it down the sink! Save our planet, please.
hutchphd said:
[...] Wash your deck or your white clothes. Don't just pour it down the sink! Save our planet, please.
Umm,... wouldn't it just end up down the drain anyway?
( I suspect COVID-19 is doing far more to save the planet -- by reducing the human population. :oldfrown: )
Sink will be sparkling clean!
Yes, but you would have poured one gallon down the drain. If you pour it down the drain without using it, and then buy a new bottle to use, so it ends up down the drain, you would have done the same cleaning at a cost of two gallons down the sink.
1.) Thanks everyone for the input.
2.) I think I'll take this approach first...THEN see what else I can do.
3.) This may sound "bad," but I thought of taking it to my local library and pouring it down THEIR sink with running water if it was safe to open and pour down sinks. LOL. Figured if it damaged something, it'd be THEIR sink/pipes/etc. Who knows...maybe they'd arrest me or something.
Aww... come on folks! At around 7% sodium hypochlorite you would have to dump a significant amount on a fair sized surface for real problems to occur. For instance covering the bottom of a kitchen sink straight out of the container would NOT be a good idea.
About a week ago I went to use some bleach that had been sitting around for roughly a year. When opened there was NO Chlorine smell at all (yes, the cap was tight.) I dumped it down the drain, trashed the bottle, and bought a fresh bottle.
For super safety, you can take it outdoors, with it pointed away from you and the wind to your back, and open it. Then cautiously smell it. If it smells like Chlorine, use it, else discard and replace.
Been there, done that
Tom
Safe to open?
Use it as normal. It may not work as well as fresh stuff, but it probably will.
It is OK to put it down the drain 1 cup at a time in the wash so why not pour it down the drain in dilution unless you have a septic tank. Can't imagine it being considered hazardous as it is an oxidizer, right? So it is going to find some yummy turds to oxidize before it gets to the waste treatment plant.
However it turns out that hot water can be detrimental to sewer systems. Many years ago an industrial operation in an industrial park near the sewage treatment plant shut down their boilers and drained 70K+ gallons of 180+ degree water into the sanitary sewer. No throttling, they just dumped it as fast as the tanks would drain. Heard later that the treatment plant guy were complaining that someone killed all their "bugs".
Guess I better check the expiration date on those U-238 pellets I bought.
Guess I better check the expiration date on those U-238 pellets I bought on Amazon last year.
It's not going to hurt anything.
Flush it down the drain with ample water.
That's what happens to bleach when using it to clean the toilet or other household applications, isn't it?
Sodium hypochlorite bleach decomposes over time, and you'll gradually end up with less available chlorine in the solution, mainly just NaCl and NaOH.
(In applications where you really need to have confidence that it has germ-killing potency, like in hospital labs, microbiology, or anywhere where biohazards are handled, safety regulators insist that bleach must be carefully monitored for expiry date and replaced, so that it is known to still be active to do its job.)
Your getting a little carried away there aren't you?
Out of sight - out of mind :rolleyes:
Or, if person is equipped, actual bleach (hypochlorite) can be measured.
Tom
Did you get the same bleach? What product was it? It would be interesting to see what it was and to look at the label. Thanks.
43K
9K
  • · Replies 34 ·
147K
  • · Replies 21 ·
