Whats the characteristics of a photodiode?
  • Thread starter Thread starter mindagap
    Photodiode
Photodiodes exhibit nonlinear behavior, making the concept of resistance inadequate for their characterization. In reverse-bias operation, photodiodes have effectively infinite resistance in darkness, with negligible current flow. When exposed to light, charge carriers are liberated, resulting in increased current and decreased effective resistance. This behavior is consistent across all photodiodes, where higher light intensity correlates with lower resistance due to increased electron-hole pair generation.
  • Understanding of semiconductor physics
  • Knowledge of p-n junction behavior
  • Familiarity with reverse-bias operation in diodes
  • Basic concepts of charge carriers in semiconductors
  • Research the characteristics of photodiodes under varying light intensities
  • Learn about the reverse saturation current in photodiodes
  • Study the generation of electron-hole pairs in semiconductors
  • Explore graphical representations of photodiode I-V characteristics
Electronics engineers, physicists, and anyone involved in the design or application of photodiodes in optical systems.
mindagap
whats the characteristics of a photodiode?
what will its resistance be, if there is a high intensity of IR radiation falling on it, and what will its resistance be, if there is a low intensity of IR radiation falling on it?
"Resistance" is actually a rather poor concept to apply to a device like a photodiode, because diodes are highly nonlinear, yet the Ohmic concept of resistance involves current varying linearly with applied voltage. Diodes never behave like simple resistors.
Photodiodes are usually operated in reverse-bias, in which no current flows through them in darkness. (Well, there's always some leakage, but it's irrelevant.) A reverse-biased photodiode is thus an "infinite resistance," because essentially no current flows through it.
When you shine light on it, some charge carriers are liberated, and a current begins to flow. If the external applied voltage remains the same, the current increases, and so the "resistance" could be said to be lower.
When you shine more light on it, even more charge carriers are liberated, and a greater current flows. If the external applied voltage remains the same, the current increases, and so the "resistance" could be said to be even lower.
- Warren
so does all photodiodes behaves this way, like if the intensity of light or IR radiation shining on it is high, its resistance will decrease?
Photodiodes work in the opposite manner of an LED(light-emitting diode). Shining light on a suitably arranged p-n junction can produce a current in the circuit that includes the juction.
As Chroot pointed out, you cannot use the concept of "resistance" in the normal sense when dealing with diodes. In case of photo-diode, PN junction is connected in reverse bias. The electron-hole pairs resulting from the photons incident on the PN-junction add to the minority carriers due to reverse bias. The radiation when incident will create electron-hole pairs on both sides of the junction.
Photon-induced electrons in the conduction band of the p-type will move across the junction down the potential hill with the theramlly generated minority carriers. Similarity, holes produced in the valence band of n-type add to the current by moving across the junction to the p-side. When no light is incident the reverse current is simply the reverse saturation current due the minority carriers.
i have concern about the photodiodes as well, can anyone tell me where i can find a graph of the characteristic of a photodiodes please?
  • · Replies 28 ·
