What's the meaning of the norm of Poynting 4-vector?
  • Context: Graduate
  • Thread starter Thread starter andresB
    4-vector Norm
The discussion centers on the interpretation of the Poynting 4-vector, defined as ##P^{\mu}=u_{\nu}T^{\mu\nu}=\left(\frac{E^{2}+B^{2}}{2},\mathbf{E}\times\mathbf{B}\right)##, where ##u_{\nu}=(1,0,0,0)## represents the four-velocity. Participants assert that while ##P^{\mu}## has a time component representing energy density and spatial components representing the Poynting vector, it is not Lorentz invariant and thus lacks physical meaning as a flow of energy-momentum. The discussion references the Maxwell Energy-Momentum Tensor and highlights the distinction between rank-2 tensors and vector cross products in the context of relativity.
  • Understanding of four-vectors in relativity
  • Familiarity with the Maxwell Energy-Momentum Tensor
  • Knowledge of the Poynting vector and its physical significance
  • Concepts of Lorentz invariance and rank-2 tensors
  • Study the properties of the Maxwell Energy-Momentum Tensor in detail
  • Explore the implications of Lorentz invariance in electromagnetic theory
  • Read "Classical Electrodynamics" by J.D. Jackson, focusing on sections discussing covariant definitions of electromagnetic energy and momentum
  • Investigate the paper "A Proposed Electromagnetic Momentum-Energy 4-Vector for Charged Bodies" by J.W. Butler for advanced insights
Physicists, particularly those specializing in electromagnetism and relativity, as well as students and researchers interested in the mathematical foundations of energy-momentum in electromagnetic fields.
andresB
Assuming a four velocity
we can use the Maxwell Energy-Momentum Tensor to build a 4-vector in the following way
So, we have a vector whose time component is the energy density of the field and the spatial components the 3d Poynting vector.
Easy to check that ##P^{\mu}P_{\mu}## is positive definite, and I wonder what is the meaning of this last quantity?
Is it? Try it for a pure radiation field, where ##\mathbf{E}## and ##\mathbf{B}## are equal in magnitude and perpendicular to each other. You should get that ##P^\mu P_\mu = 0##.
First you might want to think about the question, what is the physical meaning of ##P^\mu## itself?
A better way to think about it is that the manifestly relativistic version of the Poynting vector is simply the stress-energy tensor itself. In general, anything we express as a vector cross product in three dimensions is really a rank-2 tensor in relativity.
I like this suggestion, but there are two flies in the ointment:
(1) The 1-1 correspondence between cross products of vectors and rank-2 tensors only holds in 3 dimensions, not 4;
(2) The rank-2 tensor corresponding to the cross product (in 3 dimensions) is antisymmetric, whereas the stress-energy tensor is symmetric.
Duh, you are correct, to think that the it was positive definite was my mistake, for some reasons I thought that the mass term will come up non-zero for radiation. So, nevermind.
Right, I mean "is" in a loose sense.
Hawking and Ellis has a nice discussion of this sort of thing on p. 62. In their discussion, the reason for singling out the vector that the OP notates as u is that it's a Killing vector. Minkowski space has 10 Killing vectors, so we have 10 different flux densities such as P. The reason we care about a flux is that we can integrate it and apply Gauss's theorem to it. We don't normally care about the square of a flux, so I don't see any strong physical reasons to believe that the square of P would have any useful physical interpretation.
##P^{\mu}## is not a energy-power flow 4-vector even in free-space, because it is not consistent with the principle of relativity; in other words, ##P^{\mu}## is not invariant in form in all inertial frames of reference. Thus ##P^{\mu}## itself does not have physical meaning, just a pure math 4-vector.
This logic doesn't quite work. We can't conclude, just because something isn't Lorentz invariant, that it has no physical meaning. For example, velocity is frame-dependent, but it does have physical meaning.
In fact we do have a measure of the flow of energy-momentum, which is the stress-energy tensor. The stress-energy tensor isn't Lorentz invariant, but it does have physical meaning.
I think you misunderstood what I mean. What I mean is that ##P^{\mu}## as a 4-vector in OP does not have physics meaning; namely ##P^{\mu}## can not taken as a "physical law". The words "velocity is frame-dependent" is ambiguous. For a massive particle, the velocity is given by the space component of a 4-velocity that is Lorentz invariant in form; however, a photon does not have a 4-velocity, which is not violating the principle of relativity, because the principle of relativity does not require every physical quantity to be a Lorentz invariant, 4-vector, or tensor...
The Poynting vector combined with the Maxwell energy density only transforms between frames of reference like a four-vector energy-momentum density in the absence of sources, although it works as a local description for relative flow of energy and momentum. For a discussion of this, see the paper "A Proposed Electromagnetic Momentum-Energy 4-Vector for Charged Bodies" by J.W.Butler, or section 17.5 "Covariant Definitions of Electromagnetic Energy and Momentum" in Jackson "Classical Electrodynamics", second edition (which references the Butler paper in a footnote on page 795).
Reading the abstract of the Butler paper, I don't understand why he considers it "a most remarkable anomaly" that the density of energy-momentum in an electromagnetic field doesn't transform as a four-vector. The density of energy-momentum shows up in relativity as the stress-energy tensor, which transforms as a rank-2 tensor. You can pick out the top row of the matrix and make it look like an object with four components, but of course it's not going to transform as a vector.
I don't know what you mean by this. A vector is a physical object. A physical law is a prediction.
Your logic doesn't make much sense to me here. Nobody claimed that the principle of relativity required every physical quantity to transform as a tensor. I don't see the relevance of your example about the photon.
bcrowell said:
I don't know what you mean by this. A vector is a physical object. A physical law is a prediction.Your logic doesn't make much sense to me here. Nobody claimed that the principle of relativity required every physical quantity to transform as a tensor.
But this article (Can. J. Phys. 93: 1510–1522 (2015) dx.doi.org/10.1139/cjp-2015-0167) claims:
Traditionally, “Lorentz invariance” refers to all mathematical equations expressing the laws of nature must be invariant in form only under the Lorentz transformation, and they must be Lorentz scalars, four-vectors, or four-tensors... (see p. 540 of ref. 25, for example). In other words, the Lorentz invariance is a single requirement that combines the two postulates together, and it is equivalent to the two postulates [45].
25. J.D. Jackson. Classical electrodynamics. 3rd ed. John Wiley & Sons, Hoboken, NJ. 1999.
45. W. Pauli. Theory of relativity. Pergamon Press, London. 1958. p. 21.
bcrowell said:
... it "a most remarkable anomaly" that the density of energy-momentum in an electromagnetic field doesn't transform as a four-vector.
It is exactly what I mean.
This article also claims the same thing: "... the momentum and energy densities themselves cannot directly constitute a four-vector, ..."
Can. J. Phys. 93: 1510–1522 (2015) dx.doi.org/10.1139/cjp-2015-0167.
  • · Replies 21 ·
  • · Replies 16 ·
  • · Replies 38 ·
