What's the most massive white dwarf in the MW?
  • Context: Graduate
  • Thread starter Thread starter AdamAutism1998
    White dwarf
The discussion revolves around identifying the most massive white dwarf in the Milky Way galaxy, exploring concepts related to stellar evolution, mass limits, and supernova mechanisms. Participants share various hypotheses and observations regarding white dwarf masses and their implications.
  • Exploratory, Technical explanation, Debate/contested
  • Some participants note that the most massive white dwarf currently identified is RE-J0217-853, with a mass of 1.35 solar masses, which is close to the Chandrasekhar limit.
  • Others discuss the upper mass limit for white dwarfs, known as the Chandrasekhar limit, and its implications for stability and potential supernova events.
  • There are mentions of different mechanisms for Type Ia supernova production, including the single degenerate model and the double degenerate model, which introduce complexity into the discussion.
  • Some participants express uncertainty about the behavior of oxygen-neon white dwarfs when exceeding the Chandrasekhar limit, suggesting they may collapse into neutron stars rather than explode as supernovae.
  • Questions arise regarding the applicability of mass limits to nonrotating versus rapidly rotating white dwarfs, with references to research suggesting rotation could increase the maximum mass limit.
  • A participant mentions the possibility of a brief helium flash occurring during the collapse of a white dwarf that does not undergo a supernova.
Participants generally agree that there is no definitive answer to the question of the most massive white dwarf due to observational limitations. Multiple competing views exist regarding the implications of mass limits and the behavior of white dwarfs under various conditions.
Limitations include the inability to observe all stars in the galaxy, leading to uncertainty in identifying the most massive white dwarf. Additionally, the discussion highlights unresolved questions about the effects of rotation on mass limits and the behavior of different types of white dwarfs.
AdamAutism1998
I'm curious. I want to model it to understand stellar evolution better. Does anyone know what the most massive single white dwarf is?
Astronomy news on Phys.org
We can't see every star in the galaxy so there can be no certain answer.
However, white dwarfs do have an an upper limit to their mass known as the chandrasekar limit.
If a white dwarf exceeds that mass it will become unstable and will detonate - a type 1a supernova.
https://en.wikipedia.org/wiki/Chandrasekhar_limit
However, white dwarfs do have an an upper limit to their mass known as the chandrasankar limit.
Ok
Usually this happens when a white dwarf is robbing material from a binary companion star.
It must have happened many times in the Milky Way, though only a few such supernovae have been visible to us.
We see this kind of supernova quite a lot when observing galaxies in general, and not just our own one.
RE-J0217-853 discovered by ROSAT was reported in 1998 is the current record holder with a mass of 1.35 solar [re: http://adsabs.harvard.edu/abs/1998AAS...191.1511B]. This is very near the Chandrasekhar mass limit. It is rapidly stealing mass from its companion star and is expected to reach the critical mass limit within about 4 million years. It is also a recurrent nova with a recurrence time of less than a year. White dwarfs are very difficult to detect beyond the MW for obvious reasons, although a few are known to exist. Most notable among these is probably RX J0045.4+4154 in the Andromeda Galaxy with a mass of slightly over 1.3 solar. It too is a recurrent nova feeding off a companion star with a period of right at 1 year .
Another factor to consider is there are two mechanisms for SN-1a production. One is the single degenerate model in which a white dwarf gains mass at the expense of a massive companion star. The other is the double degenerate model where a close binary white dwarf system suffers orbital decay via gravitational radiation [think Hulse-Taylor] and the two stars merge. The peak luminosity can obviously vary between these two models - which injects some doubt as to their reliability as standard candles. Another complication is the core composition of a white dwarf supernova progenitor. A white dwarf with an oxygen-neon core could, in theory, merely collapse to form a neutron star, or black hole as it would be unable to undergo carbon fusion. For futher discussion see http://astrobites.org/2015/04/07/super-bright-supernovae-are-single-degenerate/.
Carbon and carbon/oxygen white dwarfs detonate, because there is a suitable reaction for runaway fusion explosion.
I'm not sure this is true for oxygen/neon dwarfs and such. If runaway fusion isn't possible, then exceeding Chandrasekhar limit makes WD collapse into a neutron star, no supernova.
Yes I have heard of that possibility of a direct collapse with no supernova, though am uncertain if this kind of occurrence has been observed.
I guess there would be a brief helium flash due to fusion in the envelope of material acquired from the companion, but that's about all we would see.
About 1.38 times the mass of the sun is the largest for any galaxy; any bigger and it would explode.
Is that value applicable to a nonrotating white dwarf, or a rapidly rotating one?
Need an astrophysicist for that one, I have no idea. Is it possible for a white dwarf to not rotate? Usually highly compressed objects rotate like a bat out of hell to conserve angular momentum as it got crushed.
In http and //arxiv.org/abs/astro-ph/0301539, White Dwarf Rotation: Observations and Theory, the author notes:
..."Rotation could provide another “force” that could support the star, increasing the maximum mass for an electron degenerate configuration. Thus the hope was, in part, that by finding white dwarfs rotating at sufficiently high velocities, physics at the interface between classical and modern could be tested. One of the earliest efforts to explore this connection was by Ian Roxburgh (Roxburgh 1965), who showed that the maximum mass of a white dwarf could be increased by about 5% if rotating at near critical velocity of over 2000 km/s. As limits on rotation velocities of single white dwarfs began to be measured in the 1970s, it became apparent that they were rotating at much smaller velocities than that."
  • · Replies 27 ·
  • · Replies 0 ·
  • · Replies 33 ·
  • · Replies 49 ·
