What's the Probability of Finding Cake in the Last Box?
  • Thread starter Thread starter GlobalDuty
The probability of finding cake in the last box after opening four empty boxes is 1, assuming the cake is present in one of the boxes. The discussion highlights that if four boxes are empty, the fifth must contain the cake unless there was no cake in any box. Some participants suggest that the question's wording could be clearer to avoid confusion. Others explain the calculations for the probability of not finding the cake in the first four boxes, ultimately reinforcing that the probability for the last box is 1/5 before confirming it is indeed 1 if the cake exists. The consensus is that the question's ambiguity led to unnecessary complexity in the discussion.
GlobalDuty
you open box after box until you get the cake.
what's the probability that after opening 4 empty boxes, you open the last box with cake?
i know that the probablity of finding cake in the first box is 1/5.
i think for the 5th box you multiply: (1/5)(1/4)(1/3)(1/2) to get the answer. is this right?
But you don't want the probability of cake, you want the probability of no cake.
Depending on how you interpret the question there are two (or more?) possible answers.
This looks like a trick question. Simply put, if you have already opened 4 boxes and no cake, then the fifth box MUST have the cake (unless someone was fooling around and there was no cake at all). Therefore the probability is 1.
yeah, this is bothering me
the wording is bad, but its not a trick question. i guess better wording would be:
what's the probability that you open all the boxes and then find cake in the last one?
If we assume what you write in the following paragraph, there is no ambiguity.
Here is the easy way to do it: by deciding which box to open first, which second, etc., you are specifying which box you will open last. Since the cake is equally likely to be in any of the 5 boxes, the probability that the cake is in that particular box is 1/5.
If you are not convinced that that answers the question you posed, then you can do it the hard way: the probability of NOT finding the cake in the first box is 4/5, the probability of NOT finding the cake in the second box (given that it was not in the first box) is 3/4, the probability of NOT finding the cake in the third box (given that it was not in the first or second boxes) is 2/3, and the probability of NOT finding the cake in the second box (given that it was not in the first, second, or third boxes) is 1/2.
The probability that the cake is in the fifth box is exactly the probability that it is NOT in the first box and NOT in the second box and NOT in the third box and NOT in the fourth box: (4/5)(3/4)(2/3)(1/2)= 1/5.
That, of course, is just the probability that it was in that particular box a-priori.
o ok, thanks for the responses.
the problem was bad to begin with.
