When are two equal and opposite forces about an axis not a couple
The problem involves a vertical square coil in a horizontal uniform magnetic field and its behavior when subjected to forces. Participants are discussing the implications of equal and opposite forces acting on the coil and whether these forces constitute a couple.
  • Participants explore the nature of the forces acting on the coil and question why equal and opposite forces do not create a couple. There is discussion about the direction of these forces and the resulting torque.
Responses indicate that participants are actively engaging with the concepts, with some expressing clarity on the issue while others continue to seek understanding. Guidance has been offered regarding the direction of forces and their effects on torque.
There is mention of a mark scheme indicating a specific answer, and participants are reflecting on their understanding of the forces and torque in relation to the coil's orientation in the magnetic field.
mrcotton
A current flows in vertical square coil whose plane is at right angles to a horizontal uniform magnetic field B. The coil can rotate about a vertical axis.
Which is correct
A) The forces on the two vertical sides are equal and opposite.
B) A couple acts on the coil
C) No forces act on the horizontal sides of the coil
D) If the coil is turned through a small angle about the vertical it will remain in position.
The answer in the mark scheme is A
What I can't seem to see is why B is not true also. Why are these two equal and opposite forces about an axis not causing a couple?
Any help greatefully received
A couple implies there's something to couple with.
How would equal and opposite forces create a coupling?
hi mrcotton! :smile:
in what direction are these opposite forces? :wink:
Figure out the direction of the forces on the coil. What torque does each force exert about the given axis?
Thanks for the responses.
I think my sad old brain has got it.
In this picture the left hand is not orientated correctly. If it were it would show the forces given by the red arrows and they just push towards each other. So when at 90 degrees to the field there is no couple.
In my sketch I have tried to indicate the when at an angle between 90 degrees and 0 to the field the two wires experience forces that cause a torque and the wire will turn.
Thanks
Mr C
you nailed it! :biggrin:
Sad thing is I remember that jarrred with my brain initially but I just couldn't hold my hand in that position long enough for the thought to sink in.
Thanks again
Using the "left hand rule" would get me into trouble during exams, as I scrawled with pencil in right hand :wink:.
alas in exams my digits only ever perfomed the function of counting.
  • · Replies 25 ·
