When calculating Reynolds number, when do I use dynamic/kinetic viscos
When calculating the Reynolds number, dynamic viscosity is used in the denominator alongside density for fluid flow in a pipe. Kinematic viscosity, which is derived from dynamic viscosity divided by density, can also be used if it is more convenient. For air flowing in a pipe, the choice between dynamic and kinematic viscosity depends on the available data. Ultimately, both methods yield the same Reynolds number, so the decision is based on ease of calculation. Understanding the relationship between these viscosities is key to accurate fluid dynamics analysis.
PhyIsOhSoHard
When calculating Reynolds number, when do I use dynamic viscosity and when do I use kinematic viscosity?
In a pipe with air flowing inside it, what would you use when calculating Reynolds number and why?
The Reynolds number contains the density in the numerator and the dynamic viscosity in the denominator. The kinematic viscosity is equal to the dynamic viscosity divided by the density. So, if you know the dynamic viscosity and the density, you can calculate the kinematic viscosity. So, in practice, you use whichever is more convenient / available.
