- 8,500
- 2,136
Epicurus3 said:Bell was Irish and Irish physics is bound to be wrong.
Ah, but Padraig Harrington is Irish and he won 2 major golf championships this year!
Sorry but I cannot agree to that.ThomasT said:So, I guess we'll have to agree to disagree a little bit here
Epicurus3 said:So Bell's Inequality is incorrectly assuming cos B instead of cos squared B and so proves nothing at all! I knew it all the time!
I'm claiming, first, that for a classical polariscopic setup the classical model of polarization works ok, and that it doesn't present a weird picture. I don't see how the classical model of polarization is weird or strange. If anyone thinks it is, then I'm interested to see why they think so.RandallB said:You are claiming classical “polariscopic” assumptions as an acceptable “not weird” or “Not Non-Local” solution that is as scientifically complete as QM.
Photon detections require light emissions/transmissions of some sort, don't they? Given a polariscopic setup where individual photons are being detected, the intensity of the light transmitted by the analyzing polarizer is the number of photon detections per unit of time. The analog of this in a simple optical Bell setup is the number of coincidental photon detections per unit of time.RandallB said:The cos2 shape of your “Model” is based on measurements of light – not the modeling of individual photons. You cannot just apply the cos2 to individual photons, it is not a “classically reasonable assumption”.
Hasn't quantum theory taught us that we can't effectively model, and predict the outcomes of, individual trials? The polariscope analogy isn't a solution to the hidden variable problem. It just provides a way of looking at Bell tests that seems to indicate that maybe experimental violations of Bell inequalities aren't telling us anything about nonlocality, because if one understands it as a rather more complicated polariscope, then FTL explanatory fictions are obviated.RandallB said:How does this “polariscopic” solution realistically model individual photon movements without even using a Einstein "local and realistic hidden variable".
No.RandallB said:Can you describe those movements for anyone photon?
The polariscope analogy isn't aimed at rebutting any claims made by qm. In fact, it provides a way of looking at why, after a qualitative result (a photon detection at one end), the transmission axis of the polarizer associated with the detection can be taken as the principle axis of the disturbance incident on the other polarizer.RandallB said:The “polariscopic” solution is simply an ineffective rebuttal against claims made by QM and the Bell proofs.
I'm not sure what you're saying, but it is true that Bell-type inequalities don't, taken by themselves, prove anything. They're mathematical identities. Tautologies.Epicurus3 said:The Malus Law comes from:
Actual_Amplitude = Initial_Amplitude CosB - classically reasonable assumption!
But intensity (related to number of particles observed)
Intensity = Amplitude squared
So classical AND quantum predicts:
Actual_Intensity = Initial_Intensity cos squared B - Malus AND QM predictions.
ThomasT said:The polariscope analogy isn't aimed at rebutting any claims made by qm. In fact, it provides a way of looking at why, after a qualitative result (a photon detection at one end), the transmission axis of the polarizer associated with the detection can be taken as the principle axis of the disturbance incident on the other polarizer.
Well; yah – duh.ThomasT said:Hasn't quantum theory taught us that we can't effectively model, and predict the outcomes of, individual trials? The polariscope analogy isn't a solution to the hidden variable problem. It just provides a way of looking at Bell tests that seems to indicate that maybe experimental violations of Bell inequalities aren't telling us anything about nonlocality, because if one understands it as a rather more complicated polariscope, then FTL explanatory fictions are obviated.
RandallB said:That you do not see what you have described as weird and non-local only means you have yet to grasp the full meaning behind what “Einstein Local” means.
I recommend that you and Epicurus3 take some time to ruminate on what “Local” means before continuing this pointless argument. Honestly if you cannot grasp the full meaning of Local you are not going to understand EPR; it will just be too advanced for you at this time.
No it won't. And we'll try very hard not to lose sleep after your devastating coup de grace.Epicurus3 said:Of course, this post will be deleted! (because the truth is unbearable)
DaveC426913 said:No it won't. And we'll try very hard not to lose sleep after your devastating coup de grace.![]()
This makes absolutely no sense at all, and does little to explain your position.Epicurus3 said:Bell's is NOTHING MUCH, and follows from superposition directly.
Epicurus3 said:If you understand superposition - as Bell did - then his Theroem follows from that with a bit of Sudoku level statistics.
The correlation between the states of two entangled particles is random for both particles as is clear from the wave equation. (not that they have secret states that only 'appear' when observed)
Bell realized that this statement (or similar, - better worded than mine) would not make a career for him, so he devised his joke intelligence test after a couple of beers and managed to make a career out of it. One of the guys in the same bar gave him the idea.
I have seen Bell interviewed - it was clear he had nothing more to contribute to physics than his little superposition side bar - and actually had a thin understanding of physics generally.
<flames on>
So let's hear no more about the subtley of Bell's Theorem PLEASE. Try AOP and pattern programming if you like convolution. Bell's is NOTHING MUCH, and follows from superposition directly.
<flames off>
RandallB said:This makes absolutely no sense at all, and does little to explain your position.
Other than having an irrational bias against the Irish exactly what is your scientific position.
1) Local Realism is correct – and the Bell proofs against Local Realism are simplistic and flawed.
vanesch said:We've been through this already. But in as much that this is a very plausible picture when it is *the same photon* that went through the first polarizer (and hence "got its principle axis turned into the polarizer direction" by interaction with that polarizer) it is not a surprise that when it arrives at the second polarizer, we find a relationship as given by Malus' law which depends on the difference of the axes of the first polarizer (now integrated into the photon itself after interaction) and the second polarizer (next interaction with the modified photon), I don't see how this can be an evident picture for two separate photons - even though they might start out with the same "principle axis" in the source. In what way will the twisting of the photon axis of the first photon by the first polarizer twist and turn the photon axis of the second one which is far away, so that it gets aligned with the orientation of the first polarizer, before it meets its own (second) polarizer ?
NOThomasT said:This is what happens in Bell tests also. For essentially the same reason.
ThomasT said:We're assuming that the optical disturbance (associated with each pair of detection attributes) between the two polarizers is one and the same thing during any given coincidence interval (although it is assumed to be varying randomly from interval to interval). That is, in a simple optical Bell setup, whatever is incident on polarizer A during a given coincidence interval is identical to what is incident on polarizer B during that same interval. The polariscopic (not necessarily classical per se -- ie. we could be accumulating single photon detections) analog of this assumption is that the optical disturbance transmitted by the first polarizer is identical to the optical disturbance incident on the second, or analyzing, polarizer.
I don't think this is the correct way to analyze the situation. Nothing can be said about the orientations of the incident disturbances or for that matter about anything that's qualitatively going on in individual trials independent of instrumental behavior. We only know if a detection is registered or not during a certain interval.vanesch said:Well, that's not going to work, as we discussed already. Imagine the polarizers at 90 degrees with respect to one another. As the incident disturbances are random, some will have "45 degrees", no ? Well, a 45 degree disturbance (which will be part of the set of random disturbances sent out) should have 50% probability (intensity whatever) to get through each polarizer. So in half of the cases where we saw something "left", we should also see something "right" for these distrubances, right ?
In either case (Bell test or polariscope), extending between the two polarizers is a disturbance or disturbances with common properties.vanesch said:Again, the reason why we have a cos^2 law in the *successive* polarizers, is that the disturbance AFTER the first one has been aligned with the orientation of the first polarizer (and has "forgotten" its original incident orientation).
No once again – it is your way of analyzing the situation here that eliminates it from having any meaningful relation to BELL or “Entangelement”.ThomasT said:I don't think this is the correct way to analyze the situation.
….. As the polarizer at B is rotated away from alignment with the polarizer at A, the amplitude of the transmitted component of the wave incident on the polarizer at B will vary as the cosine of the angular difference.
That's a definite possibility.RandallB said:NO
I suspect you still do not have a proper grasp of what Bell is asking an experiment to show and a LR (Local Realistic) description to explain.
Intensity in Bell tests is the rate of coincidental detection per unit of time. The probabilities of coincidental detection refer to large numbers of individual trials. As the unit of time (and the number of trials) increases, the experimental results more closely approximate the predicted values.RandallB said:Bell tests measure and summarize results from individual photons – NOT intensirtly levels from large groups of Photons (polariscopic method).
Yes, that's a hypothesis that seems to be supported by certain experimental results. I've got to think about this some more.RandallB said:But the well known facts are quantum photon energy level don’t change intensity! You observe 15% of the photons not 15% of their each photons energy.
I'm just talking about the similarities between the experimental setups.RandallB said:No once again – it is your way of analyzing the situation here that eliminates it from having any meaningful relation to BELL or “Entangelement”.
As I mentioned, the polariscopic setup can be one that counts individual photon detections.RandallB said:The only way you can use “amplitude” to allow your polariscopic to work is to select a detection coincidence interval at A that measures 1000 photons, and compare that to the same detection coincidence interval at B and use the B photon count as a measure of amplitude. Sure that will work ...
I agree. Even if the analogy is valid, it still doesn't explain what entanglement is. But, if it is valid, then it's a stepping stone to understanding what it probably isn't and what it might be.RandallB said:... But is not an explanation entanglement ...
I don't know what you mean by this.RandallB said:... and not at all what Bell is talking about as Bell requires quantum level (individual photon) comparisions.
Are you talking about the pairing process?RandallB said:Until you understand that you will not be on the same page as vanesch or anyone else.
ThomasT said:So, let's say that A detects first during some coincidence interval. The projected amplitude wrt the disturbance incident on B is assumed to be the same as A's which means that the probability of detection at B with polarizers aligned is 1, and with polarizers perpendicular to each other it's 0.
But you disrearded that when you earler said:ThomasT said:As I mentioned, the polariscopic setup can be one that counts individual photon detections.
peter0302 said:Hehe, I can't really tell what side you're taking. :) But my answer is collapse can't be a physical process; it's just that quantum statistics don't conform to the laws of macro-statistics.
Wouldn't you rather throw out classical statistics than throw out relativity? :)
moving_on said:'kay...
...that went down well.
What about this...
...I get two 'bosons' into a 'space' for which they are too big to 'fit' they conform to Bose-Einstein statistics.
...if I make two 'bosons' from something that was in a 'space' in which they are too big to 'fit' (presuming that two photons created as an entanged pair from a single
photon take more 'space' than the original) what happens?
Assuming, presumably, that 'all things are still equal' (i.e. there is conservation of energy/momentum) does this seem correctly time-symmetric?
If so, could we appeal to Noether's theorem? (I'm not quite sure of the logic!...might be the wrong way round... does a conservation law imply a symmetry?)
I'm not fully familiar with the fermionic version of entanglement so this might seem stupid as a result of the mechanics of that.
Is this crackpottery? Probably...
DrChinese said:I haven't seen a paper which answers this particular question, maybe someone else has... (I have scanned the preprint archive but to no avail so far).
Most Bell tests use polarizing beam splitters (PBS) to check photons at Alice and Bob. Typical are 2 detectors at Alice and 2 at Bob. Results of all 4 are correlated and analyzed. You would normally say the entanglement ends once we know which way the photon goes through the beam splitter.
What if we takes the 2 beams at Alice and merge them back very precisely together again? I.e. such that it is no longer possible to tell which path the photon took through the PBS. I would expect that the resultant reconstructed beam (Alice) is still entangled with Bob. If you tested Alice and Bob at this point, I would expect us to see the perfect correlations and the Bell inequality violations per usual. Is this correct?
So when does the entanglement actually end? If what I am saying is right, the PBS is not actually capable of ending the entanglement itself. Instead, it is the detection of the photon - and what we know about it at that point - which ends the entanglement. I believe this is fully consistent with the QM prediction.
AEM said:J. H. Eberly and Ting Yu, The End of an Entanglement , Science . 27 April 2007, page 555.
p764rds said:http://www.sciencemag.org/cgi/content/abstract/316/5824/579
from the above quote:
"Using an all-optical experimental setup, we showed that, even when the environment-induced decay of each system is asymptotic, quantum entanglement may suddenly disappear. This sudden death constitutes yet another distinct and counterintuitive trait of entanglement."
The disappearance of entanglement appears to be unpredictable but sudden, ummmm..
AEM said:Please, what's your point? Could you elaborate a little more?
