When is Moment Reduced in Reinforced Concrete Design?
  • Thread starter Thread starter niz
    Concrete Design
Moment reduction in reinforced concrete design typically occurs over supports in continuous beams due to higher bending moments in those areas. For simply supported beams, moment reduction is generally not applied. In cantilever beams, it is generally accepted that moment reduction is not necessary, as the design does not typically account for it. The discussion emphasizes the importance of understanding when and where to apply moment reductions based on beam type and support conditions. Clarifying these points can aid in effective design practices for reinforced concrete structures.
niz
Hi!
I'm having some difficulty trying to clear some things when designing r.concrete slab and beam.
My question is : when do you reduce moment ?
I am aware we reduce moment over support...but when that support is in middle of beam .(continuous beam)
For simply supported beam we don't make reduction of moment.
Then i read on one place that we do not reduce moment over support in cantilever beam...is this true..?
can anyone give me cases when we do reduction of moment for beams and slabs..?
Thanx in advance!
Niz
niz said:
Hi!
Thanx in advance!
Niz
You do moment reductions over supports on continuous beams (middle supports) in general because the bending moment function you get (by using a simple statical system approximation for your beam) has greater values (in the neighbourhoods of these points) and a different 'shape' than a more realistic moment function.
what about cantilever beam and cantilever arm?
do we make moment reduction for these two cases as well?
or...because of the safty we dont..?
I think there is no need to do moment reduction in the case of a cantilever beam, at least I didn't see a case/argument to do so yet.
thank you so much for your help :)
No problemo, I'm glad I helped. :wink:
Hi all, I have a question. So from the derivation of the Isentropic process relationship PV^gamma = constant, there is a step dW = PdV, which can only be said for quasi-equilibrium (or reversible) processes. As such I believe PV^gamma = constant (and the family of equations) should not be applicable to just adiabatic processes? Ie, it should be applicable only for adiabatic + reversible = isentropic processes? However, I've seen couple of online notes/books, and...
Thread 'How can I find the cleanout for my building drain?'
I am a long distance truck driver, but I recently completed a plumbing program with Stratford Career Institute. In the chapter of my textbook Repairing DWV Systems, the author says that if there is a clog in the building drain, one can clear out the clog by using a snake augur or maybe some other type of tool into the cleanout for the building drain. The author said that the cleanout for the building drain is usually near the stack. I live in a duplex townhouse. Just out of curiosity, I...
