When magnitude of addition is equals to
  • Thread starter Thread starter H.D. M A K
    Addition Magnitude
The discussion revolves around finding the angle between two vectors when the magnitudes of the vectors and their resultant are provided. The specific example given involves vectors with magnitudes of 3N and 5N, resulting in a vector of 7N.
  • Participants discuss methods to find the angle between the vectors using their magnitudes and resultant. Some suggest writing equations based on the given information, while others propose using the cosine formula for the angle between vectors.
There is ongoing dialogue about different approaches to the problem. Some participants express confusion about the calculations and seek further clarification, while others emphasize the importance of showing work as part of the homework help process.
Participants note that the original poster must demonstrate their attempts at solving the problem, as per forum guidelines. There is a recognition of the challenges faced by the original poster in understanding the mathematical concepts involved.
H.D. M A K
Mod note: Originally posted in a technical math forum, so missing the homework template.
How to find angle between two vectors when magnitude of both vectors and their resultant is given. for example The resultant of two vectors of magnitude 3n & 5n comes out 7N, the angle between vector is... please also explain how to solve it ...
Any help will be appreciated..
Thanks
Thanks
You have three vectors with magnitudes a, b, & c
Align the coordinate system so that the x-axis lies along one vector. v_1 = (a,0). Let the other vector define the x-y plane. v_2 = (b*cos theta, b* sin theta)
The resultant vector v_3 is the sum of these two vectors (also lies in the x-y plane).
(1) v_3 = (a+b*cos theta, b* sin theta)
The square magnitude of v_1 is a^2, the square magnitude of v_2 is b^2, the square magnitude of v_3 is c^2
From (1) you can also write the square magnitude of v_3: a^2 + b^2 cos^2 theta + 2ab cos theta + b^2 sin^2theta = c^2
simplifying: a^2 + b^ 2 + 2ab cos theta = c^2
<< 2 threads merged >>[/color]
There is a much simpler way than what Quantum Defect proposed. You are given the magnitudes of two vectors, as well as their sum.
Write two equations that represent this information, and you'll have two equations in essentially two unknowns. It is not necessary to find the two vectors themselves.
An important equation is the following:
$$\cos(\theta) = \frac{\vec{u} \cdot \vec{v} } {|\vec{u}| |\vec{v}| }$$
where ##\theta## is the angle between the two vectors.
@Mark44 ,, still i am confusing to solve it till last step, would you like to solve it step by step. Values are given in the question...
It is your schoolwork question. You need to show us your work on trying to solve it first. That's part of the PF schoolwork help rules (see the "Info" link at the top of the page). :)
@berkeman i am so bad in mathematics and even am stuck in simple calculations. Thanks for your sugesstion..
That's not how it works here -- we will help you, but we won't do the problem for you. What are the simple calculations you are stuck in? Show us what you have done, whether right or wrong, and we'll get you going in the right direction.
  • · Replies 21 ·
26K
