When Will the Boeing 787 Finally Take Flight?
- Context: Boeing
- Thread starter Ivan Seeking
- Start date
110 replies · 20K views
Staff Emeritus
Homework Helper
2025 Award
- 16,110
- 8,491
Ivan Seeking said:This has a direct impact on my income so this is great news for me personally as well as everyone at Boeing.
And for a lot of people here in South Carolina. Boeing is going to build a second assembly plant for the 787 near Charleston.
- 2
Borek said:According to Boeing it will use up to 20% fuel less plus it will be much quieter than other planes.
Notice the chevrons on the jet nozzle. That is very state-of-the-art right now with a lot of work being to done to understand exactly how they even work. For acoustic reasons btw.
Also, did anyone notice as the plane flew over the camera, the change in perspective gave the eerie illusion that the wings were being swept back?
p.s. As far as the differences between the 707 and 787. Well the 707 was like a 180 passenger airline, where the 787 is almost twice that. Sure, similar shape, way different scale. Lots of difference there.
Mentor
- 29,211
- 4,638
Wallace said:Ah okay, I had though they were essentially direct competitors. Is the Dreamliner aimed at smaller, shorter flights than the A380?
I think A380 is more aimed at the idea of large hubs supported by local networks of short flies, while Dreamliner is aimed more at the peer-to-peer type of airport network. But I can be wrong.
- 11
I thought the 787 only had secondary nozzle chevrons because of the large bypass ratio. I can't tell from the videos that Ivan linked to.minger said:Notice the chevrons on the jet nozzle. That is very state-of-the-art right now with a lot of work being to done to understand exactly how they even work. For acoustic reasons btw.
I always thought they were! I thought they were going with a kind of hybrid delta wing configuration. I never looked into it though.minger said:Also, did anyone notice as the plane flew over the camera, the change in perspective gave the eerie illusion that the wings were being swept back?
Lower emissions, greater range with less fuel consumption, quieter (in both the cabin and surrounding areas).minger said:p.s. As far as the differences between the 707 and 787. Well the 707 was like a 180 passenger airline, where the 787 is almost twice that. Sure, similar shape, way different scale. Lots of difference there.
tmyer2107
- 76
- 0
chaoseverlasting said:So what really are the advantages of the 787?
I recently flew on one of Continental's new airplanes. Wasn't near as noisy and had much less turbulence than anything else I've flown in. Also had outlets at every seat and tvs in the seat in front of you, it made for a much more enjoyable flight. I would definitely pay a few extra dollars to fly in that plane again rather than another flight on another airline. I think that is going to be the biggest advantage for the 787. It will attract customers to the airlines that have them because they know they will have a more comfortable, enjoyable experience.
Cyrus
- 3,246
- 17
So.....why don't I just upgrade the engines on my existing airplanes and save hundreds of millions of dollars?
In other words, I want to see the Cd of this airplane in a wind tunnel compared to other airplanes. If it is indeed 20% lower, I'll buy Boeings marketing ploy. Otherwise, they should just say it has 20% more efficient engines and thank whoever makes the engines. This is exactly what boeing does when selling their hummingbird helicopter. Its engine has a very low SFC, but they attribute it to its 'optimum speed rotors'...woooo optimum speed rotors yeah sure...
- 2
FredGarvin said:I thought the 787 only had secondary nozzle chevrons because of the large bypass ratio. I can't tell from the videos that Ivan linked to.
They've found the chevrons to reduce acoustical waves, but don't really (that I know of) successful numerical models. From what I know they experimentally found that x number of chevrons reduced noise while y increased. If they were angled at a they reduced and b they increased.
I was recently at a conference a NASA rep was presenting some stuff on it (among other aeroacoustic research). Pretty cool stuff. They may be there for another reason, but that one I do know of.
- 2
Cyrus said:So.....why don't I just upgrade the engines on my existing airplanes and save hundreds of millions of dollars?
Even if the Cd is the same, it has a bigger cross sectional area. In order to be bigger and consume less fuel, I would imagine the Cd would be lower. We have MUCH better tools today to help with design, which helps with that.
Cyrus
- 3,246
- 17
minger said:Even if the Cd is the same, it has a bigger cross sectional area. In order to be bigger and consume less fuel, I would imagine the Cd would be lower. We have MUCH better tools today to help with design, which helps with that.
I'll believe that when I see some actual numbers. Companies are notorious for marketing things in a shady way. I can show you plots of tilt rotors on helicopter websites that make them look like a godsend. I don't believe Boeing. I'm pretty sure the guys that build the 707 did a pretty good job, I don't see much difference in aerodynamic shape between those two pictures. Looks like business as usual to me. I still think its the same airplane, made of different materials (ok, kudos on that at least) with better engines (thats where the fuel savings comes from).
If their airplane is really that good and they are really proud of what they did, give a plot of Cd*A compared to other airplanes.
- 11
I have had the chance to see a lecture from one of the head gurus at Boeing. They do have predictive models but they are still working on aspects of it. It had some really good insight into the design of the chevrons. One thing we went into a fair amount of detail on was the fact that, as bypass ratio increased, chevrons on the jet nozzle became less effective and chevrons on the bypass duct took over. One of the major tradeoffs apart from performance of the engine, was that the chevrons always slightly increased higher frequencies while helping to attenuate the lower.minger said:They've found the chevrons to reduce acoustical waves, but don't really (that I know of) successful numerical models. From what I know they experimentally found that x number of chevrons reduced noise while y increased. If they were angled at a they reduced and b they increased.
I wonder if you ran into any of the folks from Glenn that we have done work with. I liked working there. What a great facility.
- 11
I see a bunch of differences in the wing planform and the way the engines are hung. I see a bit in the fuselage, especially in the front.Cyrus said:I don't see much difference in aerodynamic shape between those two pictures.
Plus look at the differences in max takeoff weight and range. The 787 is heavier and can go as far if not farther while carrying less fuel. That is partially engines, but there has to be some good airframe improvements for that.
http://en.wikipedia.org/wiki/Boeing_707
http://en.wikipedia.org/wiki/Boeing_787
Staff Emeritus
- 614
tmyer2107 said:I recently flew on one of Continental's new airplanes. Wasn't near as noisy and had much less turbulence than anything else I've flown in. Also had outlets at every seat and tvs in the seat in front of you, it made for a much more enjoyable flight. I would definitely pay a few extra dollars to fly in that plane again rather than another flight on another airline. I think that is going to be the biggest advantage for the 787. It will attract customers to the airlines that have them because they know they will have a more comfortable, enjoyable experience.
Configuration (e.g., seat width) and amenies are decided by the airline, not the plane manufacturer.
Andre
- 4,296
- 73
Yes lower weight --> less air to push down to keep flying, -->s a lower angle of attack, ---> less induced drag --> less trust required
But the effect is largest at low speeds. Als less weight means less energy/fuel required to climb to cruise altitude
mugaliens
- 197
- 1
Cyrus said:They all look like the same ole B-707 from 1960!
In this case, looks are definitely deceiving...
Cyrus
- 3,246
- 17
mugaliens said:In this case, looks are definitely deceiving...
How so? In what way is it aerodynamically different than any other school bus they make?
http://img682.imageshack.us/img682/9573/jglt.jpg
Yeah, not impressed by the 787 so far...
Hooray for substandard improvements in technology! Hey, at least it has a fancy paint job...
Staff Emeritus
- 2,666
jimmysnyder said:These airport delays are getting out of hand. This flight was two years late.
I told a slightly modified version of that joke to a buddy at Boeing. After a silent pregnant pause, he said he was going to hang up now.
Staff Emeritus
- 2,666
Cyrus said:How so? In what way is it aerodynamically different than any other school bus they make?
What is the kts for the 787?
Cyrus
- 3,246
- 17
Anyone remember this brilliant idea?
http://flyingelectrons.com/page7/page18/files/page18_2.jpg
Boeing decided it would be a good idea to cruise right at the edge of ma 1, i.e where drag is the absolute highest. I talked with a former Boeing engineer who told me the entire airplane was a marketing gimmick they had no intentions of making.
Hmmmm, let's make an airplane cruise at that peak...brilliant idea.
Staff Emeritus
- 2,666
The answer from Cyrus is "I don't know"?
Staff Emeritus
- 2,666
It is pretty tough to fake 20% better mileage.
Of course I'm sure none of the buyers have anyone who knows what they're doing. God knows that none would have a newby college grad to keep them straight.
Sorry!
- 416
- 0
Cyrus said:Anyone remember this brilliant idea?
Well there are a lot of factors consider when talking about the drag caused by mach divergence... I'm not saying that it didn't impact the particular air liner your talking about but I'm sure boeing would probably have looked into technologies to further reduce the effect than the modern supercritical airfoil does.
Cyrus
- 3,246
- 17
Ivan Seeking said:The answer from Cyrus is "I don't know"?
What "answer from cyrus"? I didn't answer any specific question.
Cyrus
- 3,246
- 17
Ivan Seeking said:It is pretty tough to fake 20% better mileage.
Yeah, because its not like a leading aerodynamicist wrote the book I scanned for you. Or that I gave you something I was told by an aerodynamicist at boeing. Perhaps we should do more reading on this subject?
Cyrus
- 3,246
- 17
Borek said:What is specific productivity?
It is defined as:
[tex]SP = \frac{(\mbox{Max Payload})x\mbox{(Transport speed)}}{\mbox{Max T/o Weight}}[/tex]
Sorry!
- 416
- 0
Cyrus said:It is defined as:
I figured it was something like this, I've only ever seen the term used in biology to do with cells. So I wasn't exactly sure how it applied here. However is this diagram based on the 'low-end' models of the planes or the 'high-end' because the gap in specific productivity between even the 3 models of 787 is quite large... or does it maybe average it out or something?
turbo
- 57
Prime motivation for sales. Fill the seats on popular longer runs and save a pile of money on fuel. And yes, that kind of efficiency is impossible to fake. A higher-capacity plane can also help relieve congestion in the skies and on the ground. If I were operating an airline and a manufacturer offered me a new plane that could cut fuel costs by 20% on runs like NY to LA, NY to LV, LA to Honolulu, etc, I'd sure have some orders in place. You're still going to have fees to pay at airports, catering costs, etc, but if you can make fewer flights, spreading the costs over the same number of passengers (or more passengers, perhaps) AND save 20% on fuel, that's a game-changer. I hope that Boeing gets the plane certified soon and starts cranking them out - a little bright spot in the economic gloom.Ivan Seeking said:It is pretty tough to fake 20% better mileage.
Andre
- 4,296
- 73
mugaliens said:Yeah!
Observation: The chase plane wasn't exactly in the safest location, wingtip vortex-wise! Would have been tragic to get off the ground only to loose a wingtip...
Well wing tip vortices are always below the flightpath and I never say the chase that low.
Boeing How Does the Boeing 787's Wing Shape Enhance Flight Dynamics?
- verdigris
- · Replies 4 ·
- Aerospace Engineering
- Replies
- 4
Boeing 787 construction: 50% carbon fiber and monocoque design
- Ivan Seeking
- · Replies 12 ·
- General Engineering
- Replies
- 12
