Where can i find tensor analysis expained physically in simplest words?
The discussion revolves around the understanding of tensor analysis, particularly in the context of general relativity. Participants explore how to grasp the concept of tensors beyond purely mathematical definitions, seeking physical interpretations and applications.
  • Some participants assert that tensor analysis is essential for understanding general relativity but acknowledge its mathematical complexity.
  • One participant suggests that a complete understanding of tensors requires mathematical knowledge, citing that tensors are geometrical concepts that relate vectors.
  • Another participant describes tensors as mappings from vectors to real numbers, using the metric tensor as an example to illustrate this relationship.
  • A correction is made regarding the classification of tensors, clarifying that 4-vectors are first-rank tensors, while the dimensionality of a tensor does not equate to its rank.
  • Some participants recommend various physics texts that cover tensors from a physical perspective, including works by Misner, Thorne, and Wheeler, as well as intermediate mechanics texts.
  • One participant provides an analogy involving a sailboat to explain how tensors can represent physical forces and their relationships to other vectors.
  • A detailed explanation of linear operators and their relation to tensors is presented, emphasizing the importance of understanding tensors in different coordinate systems.
Participants express differing views on the necessity of mathematics for understanding tensors, with some insisting it is essential while others suggest physical interpretations can be developed. There is no consensus on a singular approach to grasping tensor analysis.
Some discussions involve complex mathematical concepts and definitions that may not be fully resolved, highlighting the dependence on specific mathematical frameworks and the potential for confusion regarding terminology.
G.S.RAMYA
Tensor analysis is backbone of General theory of relativity... But it is a difficult mathematical concept. How can i know more about tensor analysis not in just a pure mathematical way?
Space news on Phys.org
Hi,
Unfortunately, I don't think there is a way to fully understand the concept without mathematics.
If you don't already know what a tensor is, it's geometrical concept that explains the relationship between vectors. For example, a straight line gives two pieces of information, magnitude, and direction. So it is a second order tensor. In relativity Einstein used 4-tensors for the three dimensions of space and one for time.
For example, if you wanted to specify a location in spacetime, you would need to specify 4 things, the regular three directions, and then what time it would occur.
Though, if your willing to take the mathematics, here is an excellent explanation of tensors for physics put out by NASA:
http://www.grc.nasa.gov/WWW/k-12/Numbers/Math/documents/Tensors_TM2002211716.pdf
Tensors are mappings from vectors to real numbers. Take the metric tensor as an example. It takes two vectors as its arguments and returns a value which is the inner product between the two vectors. Mathematically you would write
[itex]V \cdot U = g(V,U)[/itex]
where V and U are vectors and g is the metric tensor.
The metric tensor is called rank two tensor, because it maps two vectors to a number. Likewise a rank N tensor maps N vectors to a number. Vectors are rank 1 tensors and numbers are rank 0 tensors.
A rank N tensor has d^N degrees of freedom (numbers, which define the mapping) where d is the number of dimensions. Usually d=4. In this case, rank 0 tensor has 1 (duh, it's a number so you clearly need one number), rank 1 tensor has 4 (one number for each dimension, like giving the coordinates), rank 2 tensor has 16 and so on.
The reason why tensors are convenient to use in relativity is that you always know how they transform from one coordinate system to another.
This is not correct. You are confusing the dimensionality of the mathematical object with its rank: in relativity, we use 4-vectors, not 4-tensors. The 4-vector is simply a 4 dimensional vector specifying, as you say, the 3 dimensions of space and 1 of time. All vectors, regardless of their dimension, are 1st-rank (or 1st-order, not 2nd-order) tensors. The rank of the tensor is given by the number of indices: for example, a matrix is a 2nd rank tensor because its elements can be represented as [itex]a_{ij}[/itex] where i labels the row and j labels the column. The rank of the tensor corresponds to the dimension of the vector space on which it acts.
To answer the OP, tensor analysis is indeed dry mathematics. The famous tome "Gravitation" by Misner, Thorne, and Wheeler expends quite a lot of effort describing tensors as intuitive "machines" that act on vectors. It's an at times exceedingly verbose text, but it might satisfy your needs.
Any reasonable intermediate or advanced mechanics text will cover tensors from a physical point of view. Books such as Symon or Goldstein. Or you could try texts on mathematical methods for physicists, such as Arfken.
http://www.infoocean.info/avatar1.jpg I don't think there is a way to fully understand the concept without mathematics.
Imagine a sailboat. The wind pushes against the sail, and that causes the sailboat to have a force in a certain direction. The important thing is that this force doesn't *have* to be in the same direction as a wind.
You can write a set of equations that describe how the force on the boat varies with the wind, and that looks like
Force = (magic box) * (wind direction)
The reason that tensors are important in GR, is that you can use these magic boxes for things like calculating distances.
That magic box is an matrix of numbers, and this is a tensor.
In linear algebra, you studied linear operators on vector spaces. These were functions that mapped vectors to vectors in a linear way, specified by the fact that if u and v were any two vectors in V and r was any scalar, then T is linear if T(ru + v) = rT(u) + T(v).
A physical example of a linear operator is rotation. If we rotate the resultant of two vectors (by drawing a parallelogram), we expect the result to be the same as if we rotated each individual vector by the same amount and then found the resultant.
A more general idea is that of a linear map from a vector space to the set of real numbers. Some real numbers we associate with geometric objects that are useful are volumes and areas. For the area of a parallelogram spanned by two vectors, it can be shown that if A(u, v) is the function giving us the area, it must be linear in u and linear in v separately. That is, A(ru + v, w) = rA(u, w) + A(v, w) and A(u, rv + w) = rA(u, v) + A(u, w). A is then called a multilinear map, which is shortened to tensor.
It should be apparent from linear algebra that since A is linear in each vector argument, once we choose a coordinate basis, we can write components for A, and these components will differ in different coordinate systems.
In particular, if we choose (1, 0) = e1 and (0, 1) = e2 as a basis with Cartesian coordinates, then A((x1, y1), (x2, y2)) = A(x1e1 + y1e1, x2e1 + y2e2) = x1A(e1, x2e1 + y2e2) + y1A(e2, x2e1 + y2e2) = x1x2A(e1, e1) + x1y2A(e1, e2) + y1x2A(e2, e1) + y1y2A(e2, e2).
If we reasonably define the 2-dimensional area between a vector and itself to be 0, then we get A(e1, e2) + A(e2, e1) = A(e1 + e2, e1 + e2) = 0, which means A(e1, e2) = -A(e2, e1).
By choosing to represent area with a tensor, we are forced into contemplating negative areas, which correspond to changing the order of the vectors. This is useful in determining the orientation of the vectors with respect to a chosen coordinate system.
In our chosen system, if we choose units such that A(e1, e2) = 1, we have all 4 components for A: A(e1, e1) = 0, A(e1, e2) = 1, A(e2, e1) = -1, and A(e2, e2) = 0. This can be listed more concisely as A11 = 0, A12 = 1, A21 = -1, and A22 = 0 if we wish to put A in matrix form.
With a volume tensor in 3 dimensions, we use 3 vectors, and thus have 3 indexes instead of 2, one index per vector. This, and other tensors that take more than two vectors, cannot be put into a flat 2-dimensional matrix form for this reason, and are best dealt with by their index form, which represents dealing with their components when put into a specific coordinate system.
When we move the parallelogram around the plane, attaching the vector tails to points other than the origin, the area of the square does not change. For more general spaces, it is not hard to see that on a curved surface, a parallelogram attached to each point may actually have a different area, and thus an area tensor field should assign a different area tensor to each point.
To specify A as an object (ie., area of parallelogram spanned by two vectors) independent of its target's location in the plane, it is thus best to use a tensor field: a function which assigns a tensor A to each point in the plane. For Cartesian coordinates, the tensor field A(p) is a constant: it returns the same tensor A with the same components at each point p. Physicists tend to blur the distinction between tensor fields and tensors, which can confuse the layperson consulting non-physics oriented mathematical texts.
Talking about parallelograms changing area when attached to different points requires us to have a concept of "the same vectors attached to different points", which is where we get the concept of tangent space to a point (which is what tensors act upon) and the machinery of parallel transport to say how the vectors in the tangent spaces at different points are connected. Flat Euclidean space has a flat connection: the components of a vector attached to (in the tangent space of) a point remains the same if we parallel transport it to (the tangent space of) a different point.
There is a bit more going on. Ie., raising and lowering indexes has to do with the dual tangent space, or covectors, and so on, and there are many tensors where you do not want to actually get the real number by giving it the proper number of vectors, but use them to transform vectors from one space to another, since in general, a tensor need not act on two vectors in the same vector space; it may act on many vectors in many different vector spaces. The important thing to remember is that a tensor is just a multilinear map, and thus once you know linear algebra, you already have a good understanding of tensor algebra.
One useful tensor is a tensor that tells us how a vector changes in a curved space when we move it around a small parallelogram using parallel transport connections for that space's curvature rules back to its original tangent space. For example, if you move a tangent vector around a small parallelogram on the surface of a sphere, maintaining its angle with each curve representing each side of the parallelogram on the sphere, the vector no longer points in the same direction when it goes back to its starting point. That would take 3 vectors: the original vector and the two vectors defining the parallelogram, and give us the resulting vector, which may be different from the original vector if the space is not flat. This particular tensor is the Riemann curvature tensor that you will be using a bit.
Any good text on differential geometry or general relativity should give you a more than adequate introduction to tensor analysis, which is a bit more involved, and in far more detail than can be reasonably typed in this post. I would recommend Spivak's texts for a complete view, but I also like "Differential Forms and Connections", although it may be a bit too pure mathematical. I've found Schutz's "A First Course in General Relativity" to have a great section on tensors and motivates the Riemann tensor and connections well.
That magic box does not need to be a tensor in this example though. Only if wind direction and force are vectors (meaning they behave correctly under rotations, etc) is the magic box a proper tensor.
  • · Replies 22 ·
