Where does gravitation of earth and sun cancel
The discussion focuses on determining the distance from Earth at which the gravitational forces of the Earth and the Sun cancel for a spacecraft traveling towards the Sun. Participants clarify the variables involved, specifically distinguishing between 'r' as the distance from the Earth to the Sun and 'r_e' as the distance from the Earth to the spacecraft. They emphasize the need to set the gravitational forces equal using the formula F=Gm1m2/r^2. After some confusion regarding the variables, the correct equation is established, leading to a successful solution of the problem. The conversation highlights the importance of accurately defining variables in gravitational calculations.
robvba
For a spacecraft going from the Earth toward the Sun, at what distance from the Earth will the gravitational forces due to the Sun and the Earth cancel?
Earth's mass: Me
the Sun's mass: Ms
Earth-Sun distance: r
F=Gm1m2/r^2
a bit brain dead. please help
Earth's mass: Me
the Sun's mass: Ms
F=Gm1m2/r^2
It says where forces cancel. Hmmm... Cancel equal cancel equal which to choose.
I figure that F has to equal 0 and that one equation has to equal another.
Perhaps try this,
\frac{GM_e}{r^2} = \frac{GM_s}{(r_e - r)^2}
Can you explain to me why this is the case?
Rake-MC said:
Perhaps try this,
gravity experienced due to Earth on the sun = gravity experienced due to sun on the earth...?
No, this equation is slightly different.
It's from a = \frac{GM}{r^2}
So you can see it only takes into account 1 mass. It's saying that at distance 'r', this is the acceleration caused by mass M. Regardless of the mass of the object it's acting on.
Rake-MC said:
Perhaps try this,
It's impossible to "explain" without knowing what the variables mean! I can guess that "re" is either the radius of the Earth distance from the Earth to the space ship, but neither of those makes this formula true. Once denominator should be the distance from the Earth to the space ship, squared, and one should be the distance from the sun to the space ship, squared. Is r the distance from the Earth to the sun and re the distance from the sun to the earth? Robva initially designated r as the distance from the sun to the earth. If you meant re as the distance from the Earth to the space ship, then the denominator on the left has to be re2.
Sorry yes I should have explained. I think G and the two masses speak for themselves. r is the distance you are solving for (where gravitational force of both masses are equal). re is the mean distance from the centre of the Earth to the centre of the sun.
But by re-reading his variables I realize I got r and re backwards.
<br /> \frac{GM_e}{r_e^2} = \frac{GM_s}{(r - r_e)^2} <br /> &lt;br /&gt; &lt;br /&gt; So I re-wrote it with his variables. r being the distance from Earth to sun. r_e being distance we&amp;#039;re solving for.&lt;br /&gt; &lt;br /&gt; Apologies.&lt;br /&gt; &lt;br /&gt; EDIT: I&amp;#039;ve solved the equation and it works.
  • · Replies 18 ·
