Which bulb will get fused first?
  • Thread starter Thread starter zorro
    Bulb
When two bulbs rated at 25 watts and 100 watts are connected in series to a 440-volt supply, the bulb that will fuse first is determined by calculating their resistances. The formula P=I²R is used to analyze the current through each bulb. The bulb with the lower power rating, in this case, the 25-watt bulb, will fuse first due to exceeding its power rating when subjected to the total voltage.
  • Understanding of electrical power calculations using P=I²R
  • Knowledge of series circuits and voltage distribution
  • Familiarity with the concept of power ratings in electrical components
  • Basic skills in calculating resistance from power and voltage
  • Study the principles of series and parallel circuits in electrical engineering
  • Learn how to calculate resistance using Ohm's Law
  • Explore the effects of voltage on electrical components
  • Investigate the safety measures for working with high-voltage electrical systems
Electrical engineering students, hobbyists working with circuits, and anyone interested in understanding the behavior of electrical components under varying voltage conditions.
zorro
If two bulbs of power 25 watt and 100 watt each rated at 220 volts are connected in series with a supply of 440 volts. Which bulb will be fused?
This is what I think I have to do-
Find out the resistances of each bulb from the data given.
Use P=I2R for each bulb and find out if it is greater than its power rating. The one with higher power rating will get fused.
Is this right?
Hi Abdul! :wink:
That's right! :smile:
(I assume you're finding I from the total resistance)
  • · Replies 19 ·
  • · Replies 17 ·
