Which came into existance first: Energy or Mass?
  • Context: Graduate
  • Thread starter Thread starter jacket
    Energy Mass
The discussion centers around the relationship between energy, mass, and gravity, particularly in the context of the Big Bang and the origins of the universe. Participants explore whether energy or mass came first, how they relate to gravity, and the implications of these relationships in physics.
  • Some participants propose that energy, mass, and gravity all came into existence simultaneously at the Big Bang, while others challenge this notion, suggesting that the terminology implies separateness that may not be accurate.
  • It is suggested that mass cannot exist without energy and vice versa, indicating a fundamental connection between the two.
  • One participant explains that energy can be quantified and relates to work done on objects, raising questions about how energy can have mass.
  • Another participant asserts that energy is not a physical object and cannot be attracted by forces, while questioning how mass, which is also not a physical object, can be affected by gravity.
  • Some participants discuss the conservation of energy and how energy can transform between forms, such as in chemical reactions, while still being conserved within a system.
  • There are claims that gravity is a property that arises with mass and energy, and that it has always been present since the beginning of the universe.
Participants express differing views on whether energy and mass came into existence together or if one preceded the other. There is no consensus on the implications of gravity's relationship with mass and energy, and the discussion remains unresolved.
Some participants highlight the complexity of defining energy and mass, noting that their interactions and definitions may depend on specific contexts or assumptions. The discussion includes various interpretations of how energy and mass relate to gravitational forces.
jacket
The universe began with the Big-bang and then formed into today's state. But which came first?
Mass or Energy?
Also what about Gravity?
Space news on Phys.org
they come together , +gravity is a property of whatever has mass and mass is a property of matter , mass gravitates aka attracts other mass so if you have mass you have gravity , if you have mass you also have energy , have energy you probably have mass , and it goes like this.
in daily life we usually take energy as something abstract and different from the res but in physics that all coems together and is not so different as we may think.
You are saying Energy, Mass and Gravity all came together, at once, right at big-bang?
Energy has mass, so they are not capable of existing separate of each other.
Since gravity is the result of the metric tensor of spacetime, and is bent by the presence of energy in any form, gravity is also present with energy or mass.
Came together? I don't quite like this terminology, it implies that they may have been separate at some point, which is not true.
If we assume that the big bang was the creation of the universe (which we don't actually know) then mass, energy, and gravity were all created at the exact same time. Of course it is possible that the big bang was not the creation of the universe, and that all three have existed forever.
Well, actually by came together I meant 'came into existence together' but thanks for killing any possible confusion.
How come Energy have Mass? Can I say 'mass of this energy is x kg' ?
Absolutely.
You can find the mass of an amount of energy by using the equation: e=mc2
Note that energy NOT in the form of rest mass will only be apparent when you measure the mass of the system as a whole.
By that I mean that the kinetic energy of a baseball will not add to the mass of the baseball itself, but to the mass of the whole system the baseball is in. If we could take the whole baseball field and measure the mass and energy of everything within it, we would find that the kinetic energy of the ball adds to the mass of the whole system.
Drakkith said:
Absolutely.
Then if energy has mass then does energies attract one another? Or does matter attracts energy?
Energy is not a physical object, it is a quantity. As such, it cannot be attracted by forces, only physical objects like particles can. You cannot have "energies".
Mass is also not a physical object (am I correct?). Then how can mass be attracted by gravitational force?
By 'energies' I mean - suppose we have a system with energy E1 and another with E2. Will E1 and E2 attract each other?
Mass or Energy?
Mass cannot come before energy, nor vice versa.
You mean energy came first, then mass? What about gravity?
No, I don't mean that and I didn't say that. Neither came before the other. Mass and energy always come together. You cannot have one without the other.
It may help to understand what energy is. Let me try and come up with a decent explanation.
Let's say we have object A that we want to accelerate. So I go ahead and apply a force until this object reaches whatever velocity I want. Applying this force over a distance is what we call work. Using math, I can quantify everything I just did by the formula w=fd. So let's add some numbers.
Let's say I applied 10 Newtons of force over 10 meters. 10 x 10 = 100 joules of work done.
So I've done work, accelerated this object, and used math to calculate exactly what occurred. But what if I want to figure out how much work I COULD have done without actually performing it? This is where energy is useful. It let's us know how much work, of any type, we are able to perform given a systems initial conditions.
For example, if I have a pool ball rolling along the table at X velocity, knowing the mass and velocity of the ball I can determine what will happen when that ball hits another ball. In other words, I am predicting how much work that ball can perform on another in the future based on the conditions of the ball (and everything else on the table) in the present. A useful concept, eh?
Now, as we've observed, when objects move around and interact these quantities move around also. That object I performed 100 joules of work on can now be said to have 100 joules of kinetic energy that can be transferred to other objects and even turned into other types of energy, such as radiation or thermal energy.
Let's say we place that moving object in a system where nothing else is moving. Let's also say that our kinetic energy will remain kinetic energy and never be anything else. (Which isn't the case in the real world, but works for our example) If we watch the object collide with other objects we will see that as the energy gets transferred around between everything in the system, we will NEVER have any more or any less than 100 joules of total energy within that system. So while it may get split up between objects, with perhaps one having 50 joules, another having 30, and another having 20, the total will always be 100. So we say that energy is conserved. It never just disappears.
Does all that make sense so far?
Sorry, I took your 'Nor' as 'Not'.
Anyway, so mass and energy came into existence together. What about gravity?
That was nice. So any system can 'have' energy. But then what is meant by 'Energy has mass' ?
jacket said:
What about gravity?
Mass has energy, so it gravitates.
gravity is like the shadow of a man walking on the sunny side of the road , wherever he goes the shadow follows him.
Just as mass/energy came so came gravity it was there since the very first instant if there ever was one.
energy is just one form of mass , when you burn wood you get a flame which produces heat so you can say cook your food or make a hot water to wash yourself.Now when something burns it's a chemical reaction in which part of the mass turns into energy of various kinds , so a little bit of that mass gets lost in the process , it goes away as energy and smoke etc etc.
Not only any system can have energy but all systems have atleast some kind of energy in them.
imagine a tank of gasoline it has mass , you can feel it when you try to pick it up.
Now if you burn it it releases it's energy in a chemical reaction and you end up with no gasoline , so mass has been turned into energy but that mass doesn't disappear the energy it created goes into other systems and interacts with them and adds to their energy , like the heat from the gasoline goes into the surrounding air and the temperature rises , even though it's small and we cannot see it but it is so.
energy is just one form of mass,
Thanks.
So, Energy / Mass and Gravity originated together.
yes indeed , but don't think gravity stands on it's own , where there is no mass and energy there will be no gravity , gravity kinda logically follows wherever there is mass/energy.
Just like the shadow of a man, wherever there is one.
Think of mass as the energy content of an object at rest. Whatever its temperature is, whatever is going on inside it, however fast the molecules are bouncing around with their energy, all of that is taken into account with our term "mass". This mass does not change, unlike something like kinetic energy which WILL change depending on how different observers are moving. A proton moving at 0.99c relative to the Earth will see our planet as having an enormous amount of kinetic energy. However, both that proton and another proton moving at 0.5c will agree on how much MASS the Earth has.
Now, that being said, if we shoot a rocket off at 0.01c, that rocket will have a certain amount of kinetic energy. Since that rocket left Earth, the mass of the planet will be reduced by an amount equal to both the mass of the rocket AND an amount of mass equivalent to the rocket's kinetic energy.
So we say this energy has left Earth, our system, and the mass of the system is reduced because it lost energy.
Thanks everyone.
  • · Replies 19 ·
  • · Replies 37 ·
