Which is more effective in this case, elastic or inelastic collision?
The problem involves a weight-pile collision scenario where a 2.9 ton weight falls and drives a 0.5 ton pile into the ground. The discussion focuses on determining the average force of resistance during an inelastic collision and exploring the implications of an elastic collision under constant resistive force conditions.
  • Mixed
  • Participants discuss the calculation of resistive force in an inelastic collision and the subsequent effects on the pile's penetration depth. There are attempts to clarify the distinction between inelastic and elastic collisions, with some questioning the need for multiple equations.
The discussion is ongoing, with various participants offering insights into the mechanics of both collision types. Some guidance has been provided regarding the equations relevant to elastic collisions, but there is no consensus on the approach to part B or the overall effectiveness of the collision types.
Participants express uncertainty about the energy loss during inelastic collisions and how it affects calculations. There is also mention of potential energy considerations after the collision, indicating a need for clarity on the assumptions being made in the problem setup.
oreo
A 2.9 ton weight falling through a distance of 6.5 ft drives a 0.5 ton pile 1.5 in. into the ground
A) Assuming that the weight-pile collision is completely inelastic, find the average force of resistance exerted by ground
B) Assuming that the resistive force in (A) remains constant, how far into the ground would the pile be driven if the collision were elastic?
C) Which is more effective in this case, elastic or inelastic collision?
P.E of 2.9 ton mass =Work done by resistive force
To find resistive force in inelastic collision, the K.E imparted due to P.E of 2.9 ton mass= Work done by resistive forces
=> m*g*h=F_r*(0.0381m(1.5 inch))
=> F_r = 1.47 x 10^6
(Is it right?)
B) No idea because it says Elastic collision with resistive force constant ( Don't understand how to solve)
C) No idea (Depends on (b))
Those are two different things. First you have an inelastic collision between weight and pile, afterwards the combination of two moves down. You have to consider the processes separately.
The same applies to (B).
But how I am going to write two equations for Inelastic collision. It is understood that all the P.E is dissipated in work done against resistive force
Why do you need two equations? One is sufficient.
No, some parts are converted to heat (or something else) in the inelastic collision.
But that is ignored in solving such problems.
Please any equation for part B
The details of the energy loss are ignored, but the energy loss itself is not. Otherwise the inelastic collision would be an elastic collision.
Start with the inelastic collision, otherwise this thread won't lead anywhere.
You should have formulas for elastic collisions. If not, you can derive them from energy and momentum conservation.
A) m1v1 + m2v2= (m1+m2)V
V= Common velocity, v2=0
Then, 1/2(m1+m2)V=Fr*d
Fr= Resistive force
d= Depth of penetration
(Is that right)?
B) v1f= (m1-m2)*v1/(m1+m2)+2m2*v2(m1+m2)
v1f (velocity after collision)
v2f=(m2-m1)*v2/(m1+m2)+2m1/(m1+m2)
Then, 1/2m*v1f+1/2m*v2f= Fr*d
(Is that right)?
Then, (1/2)(m1+m2)V 2 = Fr*d
Fr= Resistive force
(Is that right)?
You didn't square the velocity, V . Maybe a typo.
There is a v1 missing.
m1 won't participate in the ramming process any more, and I think there is a square missing again.
After the inelastic collision, do you need to account for the potential energy available as the combined mass drops the 1.5"?
  • · Replies 21 ·
  • · Replies 27 ·
  • · Replies 16 ·
