Which of the subsets of R^3 is a subspace of R^3.
  • Thread starter Thread starter physics=world
    Subsets Subspace
The discussion centers on determining which subsets of R^3 qualify as subspaces, specifically analyzing W = {(x,y,z): x + y + z = 0} and W = {(x,y,z): x + y + z = 1}. It is established that W = {(x,y,z): x + y + z = 0} is a subspace because it contains the zero vector and is closed under addition and scalar multiplication. In contrast, W = {(x,y,z): x + y + z = 1} does not qualify as a subspace since it does not contain the zero vector and fails the closure properties. The discussion emphasizes the importance of using arbitrary vectors from the set when proving closure under addition and scalar multiplication. Ultimately, W = {(x,y,z): x + y + z = 0} is confirmed as a valid subspace of R^3.
physics=world
1. Which of the subsets of R3 is a subspace of R3.
a) W = {(x,y,z): x + y + z = 0}
b) W = {(x,y,z): x + y + z = 1}
I was wondering if my answer for A is correct.
A) W = {(x,y,z): x + y + z = 0}
Since, x + y + z = 0. Then, the values for all the variables have to be zero. Therefore, the only vector in W is the zero vector. So, W is nonempty and a subset of R3.
Furthermore, because W is closed under addition and scalar multiplication, it is a subspace of R3.
Testing for closure under addition:
Let a = (a1, a2, a3) and
Let b = (b1, b2, b3)
a + b = (a1, a2, a3) + (b1, b2, b3)
= (a1 + b1, a2 + b2, a3 + b3)
where x = a1 + b1, y = a2 + b2, z = a3 + b3.
= (x,y,z) Closure under addition.
Testing for closure under scalar multiplication:
c is any real number
c(x1, y2, z3)
= (cx1, cy2, cz3) Where x1, y2, z3 = 0
= (0,0,0)
That just means (0,0,0) is one member of the set. Another member would be (1,1,-2) since 1+1-2=0 as well.
What about (-2,1,1)?
c(x1, y2, z3)
= (0,0,0)
You need to redo the closure arguments. The results of the operations have to satisfy x+y+z=0.
If I wrote the first part like this:
Since, x + y + z = 0. Then, the values for all the variables could equal to zero. Therefore, the zero vector is in W. So, W is nonempty and a subset of R3.
would it work?
and I might need some help on the closure arguments.
Restate the sentence that starts with "Then, the values ..." as If we let x = y = z = 0, then the zero vector is in this set, and W is nonempty.
You don't need "and a subset of R3." This is given in the problem statement.
physics=world said:
would it work?
Assume that u and v are two arbitrary vectors in your set. Show that u + v must also be contained in this set. The key here is arbitrary. You can't pick and choose specific vectors.
Assume that k is an arbitrary scalar. Show that ku is in the set.
Suppose (x, y, z) satisfies x+ y+ z= 0 and (a, b, c) satisfies a+ b+ c= 0. What can you say about (x+ a, y+ b, c+ d) and (ax, ay, az)?
There closed under addition and scalar multiplication.
Would this work?Let u = (u1, u2, u3) and
Let v = (v1, v2, v3)
u + v = (u1, u2, u3) + (v1, v2, v3)
= (u1 + v1, u2 + v2, u3 + v3)
where x = u1 + v1, y = u2 + v2, z = u3 + v3.
No, this won't work. Your u and v vectors are just arbitrary vectors in R3. You need to start with vectors in set W.
Your OP gives a precise but terse definition of W. With this definition, one can distinguish between vectors in W and vectors in R3 that aren't in W.
To get your intuition working, can you come up with specific vectors in W? Note that in proving that a set is a subspace, you can't use specific vectors, but this exercise might help you understand a little better what you need to do in your proof.
mark44 said:
to get your intuition working, can you come up with specific vectors in w?.
(0,0,0)
(1,1,-2)
Back to basics.
W is the set of all triples (x,y,z) which satisfy the condition C: x+y+z=0.
You know that (0,0,0) is a member of W because it satisfies the condition that x+y+z=0
Therefore W is not empty. So far so good...
It should be easy to find other members ... how many members are there altogether?
hint: more than 4 - see if you can come up with a few more, i.e. is (4,-1,7) a member of W?
This is the exercise suggested by Mark44.
If z=0, what possible values of x and y will work?
What if z=1? z=-1?, z=1/2,1/3,10?
If (x,y,z) were plotted on x,y,z axes, what geometric object would the members of W make?
You cannot use specific vectors to prove the subspace...
u=(a,b,c) and v=(e,f,g) are two representative members of W,
this means that a+b+c=0 and e+f+g=0
W is closed under addition if w=u+v is also a member of W.
How would you go about showing this is the case?
hint: find the components of w in terms of the components of u and of v, then see if they satisfy the condition C.
  • · Replies 61 ·
  • · Replies 20 ·
