Which one is a correct statement about oscillation?
24 replies · 3K views · last reply
songoku
Please see below
Simple Harmonic Motion
##a=-\omega^2 x##
##F=m.a##
Diagram of a pendulum hanging from a pivot, with its bob shown at positions Y and X on either side of a dashed vertical line through the lowest point, with the text labels Y and X next to the bob positions.
The answer is (C), but in my opinion all options are wrong:
(A) is wrong because at X and Y the net force is maximum, not zero
(B) is wrong because the direction of net force can be in opposite direction to velocity
(C) is wrong because at the middle (equilibrium point) the acceleration is zero
(D) is wrong because they are not directly proportional
Why is (C) correct?
Thanks
Be careful. Can a particle have nonzero acceleration at an instant when its speed is not changing?
A pendulum will approximate simple harmonic motion only for small oscillations. The problem statement does not indicate small oscillations. So, you cannot assume the motion is simple harmonic. Nevertheless, you should be able to argue that only (C) is correct.
You are correct that the net force is not zero at X or Y. (However, for large enough oscillations the net force will not be maximum at these two points.)
Can you explain why the net force can't be zero at X or Y?
As @TSny points out, you should not be assuming SHM here.
That’s like saying it's wrong because it’s wrong.
The net force on the bob will never have a direction opposite to the velocity direction.
Try to see why the net acceleration and velocity never have opposite directions for the pendulum. (However, for small oscillations, they can be approximately opposite.)
A pendulum bob moves continuously along a circular arc between two turning points. Can you provide a simple argument why an object in continuous motion along a curved path must necessarily have non zero acceleration? The argument works for any curved path, not only a circular arc.
Diagram of a simple pendulum: a black rod hangs from a hatched ceiling support, with a dashed vertical line below the pivot, angle theta marked between them, a grey bob at the lower right, and a red arrow labelled a pointing down and to the left from the bob.
This animation from the pendulum Wikipedia article is quite informative. Note the relation between the acceleration and the velocity directions. You can also see that the velocity goes through zero at the turning points. However, the acceleration is never zero.
Something is zero at the lowest point of the motion, but it is not the net force. What quantity (other than the angular displacement ##\theta##) is it?
Edited for typo, see post #9.
Ah ok, so that's my mistake.
Since this is not SHM, so the motion of the bob can't be taken as straight horizontal line but will be an arc so I think there will be two accelerations; one is from the restoring force and one is centripetal acceleration
At the middle, the acceleration from restoring force is zero but there is centripetal acceleration so even though the speed is not changing, the acceleration is non zero.
It is because when velocity is increasing, acceleration is decreasing so they are not directly proportional.
The net force can't be zero at X or Y because there will be restoring force pulling the pendulum back to opposite direction but I don't know why the force is not maximum at X or Y
I think the answer is in the diagram posted by @kuruman
kuruman said:
A pendulum bob moves continuously along a circular arc between two turning points. Can you provide a simple argument why an object in continuous motion along a curved path must necessarily have zero acceleration? The argument works for any curved path, not only a circular arc.
Maybe you mean "must necessarily have non-zero acceleration"?
I suppose the reason is because the direction of motion is changing so velocity is changing. Rate of change of velocity is acceleration
Gravitational potential energy?
Yes. that's what I meant. I fixed the typo. Thanks for the catch and sorry about the confusion.
The zero of gravitational potential is arbitrary and can be chosen anywhere. What two vector quantities must be zero for an object to be in equilibrium? One is the net force. What is the other one?
The author of the question was likely thinking (correctly) that the tangential component of the acceleration is zero at the equilibrium point and wasn't thinking about the nonzero centripetal component. It's a common error.
As written, this is not exactly correct.
Linear damping (e.g. simple viscous drag) is a case where acceleration becomes increasingly negative as velocity becomes increasingly positive.
That said, an observation that the magnitude of velocity is increasing while the magnitude of acceleration is decreasing does indicate a lack of direct proportionality.
Yes.
Yes.
Take an extreme case where the bob is released with the string horizontal. Use energy conservation to find the speed at the bottom of the swing. Compare the centripetal acceleration at the bottom to the acceleration at X or Y. Compare the net force on the bob at X to the net force at the bottom.
Should be net torque
speed at bottom of the swing = ##\sqrt{2gL}## where ##L## is length of pendulum
Net force at bottom = ##T-W## where ##T## is the tension and ##W## is the weight of pendulum bob
Centripetal acceleration at bottom = ##\frac{T-W}{m}##
acceleration at X or Y is due to restoring force. Is restoring force the resultant of tension and weight at this position?
Yes.
The net force is the resultant of the tension and the weight. It generates the restoring torque (not force) about the point of support.
OK. So, what is the centripetal acceleration at the bottom expressed in terms of g?
What is the net force on the bob at the bottom expressed in terms of m and g?
When the bob is at X (where we are taking the string to be horizontal in this case), what is the acceleration of the bob? What is the net force on the bob at X expressed in terms of m and g?
Compare the net force at X with the net force at the bottom. You should see that the net force is not at a maximum at X.
Why can't I say it generates restoring force?
2g
2mg
I suppose it would be g
mg
Yes, the net force actually is bigger at the bottom. Is bottom the position where the force is maximum?
Because a torque is required to restore the angular displacement to equilibrium.
Is the term restoring force only appropriate to be used for SHM case?
Not necessarily. The term "harmonic" simply means that sines and cosines are used to describe the motion. It is the case when the restoring force (or torque) is proportional to the negative of the linear (or angular) acceleration. Read about anharmonicity here.
songoku said:
2g
2mg
mg
Yes to all of the above.
You can show that if the angular amplitude of the swing is greater than ##\tan^{-1}(4/3) \approx 53^\circ##, the maximum force during the oscillation occurs at the bottom of the swing.
For amplitudes less than this, max force occurs at X (or Y).
Here's an interactive animation. Click on "Lab" to explore the acceleration for different amplitudes.
Thank you very much for all the help and explanation TSny, kuruman, haruspex, Mister T, jbriggs444
If you look at the problem in one dimension (tangential) by discarding the irrelevant constraint force in the radial direction then yes, one could regard the tangential component of gravity as a "restoring force".
Whether radial force or torque from the pendulum arm are truly "irrelevant" may depend on the exact quantity one is trying to determine and the level of detail of the model.
Proof
If a restoring force is to be identified, then one should look for it as the negative gradient of the potential energy in which the mass finds itself. Here we have $$U=mgR(1-\cos\!\theta)$$. The potential energy is a function of ##\theta## only in which case $$\mathbf F=-\frac{1}{R}\frac{\partial U}{\partial \theta}\mathbf{\hat {\theta}}=-mg\sin\!\theta~\mathbf{\hat {\theta}}.$$
No, it's just that SHM is characterized by a linear restoring force.
