Which Organic Compound Is Most Acidic?
25 replies · 8K views
get_physical
Rank by acidity
Br is lower on the periodic table, hence more acidic. But in the first compound, it is also farthest away from the carboxylic acid, which one gets priority ?
I think The one with the bromo group closest to the carboxylic group is most acidic and then next would be the di-fluro, then one fluro and finally, the bromo since it is farthest away from the group? Or does bromo come first before the fluorine?
In HX compounds I would agree, but here what matters is the electronegativity - whatever is more electronegative will pull the electrons stronger, lowering electron density on the -COOH group and making the acid stronger.
how do I know that here is electronegativity that matters and not the rule where going down is more acidic?
Can you list examples where this rule works?
BR-CH2-COOH vs. F-CH2-COOH
Would the one with fluorine be more acidic because it is more electronegative? But I thought when they are in the same column, acidity in the haloacids increases as we move down the column. Does that mean only if we are comparing haloacids on their own without attached to a COOH group.
I have a feeling you are mixing up several separate trends (each limited to another kind of compounds). As far as I can tell "haloacid" is a name used for halogenated organic (carboxylic) acid, so how can you have haloacid that is "without COOH group"?
Strength of HX acids is HI > HBr > HCl > HF - that's where the acidity grows down the period. But it doesn't mean haloacids will behave the same way, as their acidity depends on completely different effects.
Yes I am quite confused at this moment.
So for Br-CH2-COOH and F-CH2-COOH, which one is more acidic? We said that F-CH2-COOH is more acidic because F is more electronegative, but at the same time, "Strength of HX acids is HI > HBr > HCl > HF "
I would expect fluoroacteic acid to be stronger. But this is just applying rule of thumb, so the reality can be s little bit more complicated.
FCH2COOH is not the same as HF, these are completely different classes of compounds.
Is F-CH2-COOH a haloacid??
If it is a haloacid, then shouldn't the haloacid with Br be more acidic? according to the "Strength of HX acids is HI > HBr > HCl > HF "
These are not haloacids. You have ignored what I wrote earlier:
Borek said:
HF is not. It is a hydrogen halide.
I know HF is not a haloacid and that it is a hydrogen halide.
but it says ""Strength of HX acids is HI > HBr > HCl > HF " "
Strength of HX acids = haloacids? no??
If so, Can you give me an example where ""Strength of HX acids is HI > HBr > HCl > HF " "
You are confusing the stabilization due to the inductive effect in the haloacid case versus the concept of anion charge density in the case of hydrogen halides.
Yes I am. Could someone please explain it? Thank you
HX was meant to mean "any molecule in which X is a halogen". So, X can stand for F, Cl, Br or I (or even At), but not anything more complicated.
That's rather common use of the notation, so I thought it will be obvious. Sorry if it wasn't.
I can't just give you an answer but I'll try and help guide you to a, hand-wavy, way to remember this stuff.
Take a look at the anions produced when a proton dissociates from some molecule/atom/ion. You can judge the strength of the conjugate acid by analyzing the stability of the anion. For the hydrogen halide case, you can look at the size of the anions produced, hand-wave a bit and convince yourself that charge density ~ energy. Remember that each halide will have a charge of +1.
For the case of the haloacids, you have to remember that the inductive effect falls off greatly with distance. Neglecting through-space interactions and considering only effects working through bonds, you can get a simple trend going right off the bat. Also consider that the explanation of the inductive effect relies on polarization of sigma bonds due to electronegativity differences. So try to consider these things and see if you can come up with the basic trends.
You can also look up a table of pKa's and compare chloroacetic acid, bromoacetic acid, fluoroacetic acid and the di- and tri- variants etc.
Yes, I know HX means any molecule in which X is a halogen. BUT they said "HX acids" ! so that means haloacids??
I have no idea what you are talking about. I have explained what I mean by haloacids and what I mean by HX, and I told you you can't use the same rules for both, yet you are still mixing these things. I don't know how to get more precise.
I can only repeat it again: HX is NOT a haloacid.
I know exactly what you are saying that HX is NOT a haloacid. What I am talking about is what you said earlier. You said
You said strength of HX acids . Doesn't that refer to HALOACIDS? HX ACIDS = HALOACIDS.
Thank you!
get_physical, please refer to my first response to this thread. The links I provided explain the difference between the two terms.
In summary: Haloacid refers to a halogen substituted carboxylic acid such as chloroacetic acid, for example, or more generally RCOOH where the halide will be somewhere in the "R" group. Hydrogen halides, or hydrohaloacids, refer to HX.
Please take a bit of initiative and at least read links that people post up. The philosophy around here is for us to help you help yourself. Not just write up answers.
You are just trolling now.
HX is not a haloacid. What I wrote about HX is about HX, not about haloacids.
EOT
EOT
No,I'm not trolling.
Like I said many times, I know HX is not a haloacid. But you didn't say HX. You said HX acids. That's where I got confused.
You said HX acids, not just HX. Since HX = halogen then I thought HX acids was referring to haloacids.
Anyway, I think I get it now...
Thanks for all your help.
So do you want to check if you really understand? Maybe just give us the rankings with a sentence or two regarding the rationale?
get_physical said:
HX = halogen
No. X2 = halogen. HX = hydrogen halide, = HX acid (if the HX molecule is dissolved in water) = hydro-x-ic acid (if the HX molecule is dissolved in water)
