Which proton would yield the most stable conjugate base?
  • Thread starter Thread starter MechRocket
    Proton
The discussion centers on the stability of conjugate bases formed by de-protonation of protons A, B, and C. Protons A and B are identified as more acidic than C, but the user argues that de-protonation of C leads to a more stable conjugate base due to greater electron delocalization. The conversation highlights the importance of resonance structures in determining stability and suggests that the proximity of alpha hydrogens to electron-withdrawing oxygen affects acidity. The debate also touches on the concepts of kinetic versus thermodynamic control in acid-base reactions.
  • Understanding of acid-base chemistry and conjugate bases
  • Familiarity with resonance structures and their role in stability
  • Knowledge of keto-enol tautomerism
  • Basic principles of thermodynamics and kinetics in chemical reactions
  • Research resonance structures for various conjugate bases
  • Study the principles of keto-enol tautomerism in detail
  • Explore the concepts of kinetic control versus thermodynamic control in acid-base reactions
  • Examine examples of electron-withdrawing groups and their effects on acidity
Chemistry students, organic chemists, and anyone interested in understanding acid-base stability and resonance effects in organic compounds.
MechRocket
[PLAIN]http://img638.imageshack.us/img638/5747/asdfnt.jpg
My workbook says that protons A & B are both more acidic than C, with the answer being A (I do get that A should be more acidic than B).
[PLAIN]http://img52.imageshack.us/img52/9800/asdfmi.jpg
I chose C though because de-protonation of C would access the more conjugated system. I would think there is more electron delocalization if you de-protonate C compared to A or B.
I posted this question on another forum and got the response that the reason is because the alpha hydrogens are closer to the Oxygen (electron-withdrawing), but I am not entirely convinced. In my undergrad Orgo course, I was told to always go with the proton that yields that more stable conjugate base, and I would think the base that results from de-protonation at C is clearly much more stable than the one that results from either A or B.
Is this a matter of kinetic control vs. thermo control or something? That's the only thing I can think of, where at low temperatures the proximity to the Oxygen makes A & B more acidic while at higher temperatures the yield would increasingly favor de-protonation of C. Just something I'm putting out there, but it's really just a shot in the dark.
Chemistry news on Phys.org
.. I would think the base that results from de-protonation at C is clearly much more stable than the one that results from either A or B.
I think you have come to that conclusion a little hastily. Have you tried to draw resonance structures for deprotonation at A or B? The key stabilizing feature of the resonance system you drew for deprotonation at C is that it includes a structure where the negative charge is localized on the oxygen in the anion.
All three deprotonation sites result in enolate anions ... you might want to look up keto-enol tautomerism to help understand this a little better.
I do think I have a good handle on keto-enol tautomerism. If you draw those resonance structures out (de-protonation of A & B), you will see that the conjugated system upon de-protonation of C is still much more extensive because the aldehyde is a Beta-unsaturated aldehyde.
I drew these side by side for you to compare (de-protonation of A #1 vs. de-protonation of C, #2):
[PLAIN]http://img692.imageshack.us/img692/1476/asdfhug.jpg
13K
