Which spot on earth would have the fewest # of satellite's visible?
  • Thread starter Thread starter bigmac
    Earth
The discussion revolves around identifying the location on Earth with the fewest visible satellites, particularly focusing on geostationary satellites and their visibility from different latitudes. Participants explore the implications of satellite orbits and their relationship to geographic locations.
  • Participants attempt to reason whether the poles or the equator would have fewer visible satellites, with some suggesting that visibility is influenced by the population distribution and satellite technology usage. Questions arise regarding the nature of geostationary satellites and their visibility from various points on Earth.
The conversation is ongoing, with various interpretations being explored. Some participants provide hints and guidance without reaching a consensus on the main question. There is a mix of confusion and attempts to clarify the concepts involved.
Participants are navigating homework constraints, including the need to understand satellite orbits and visibility without providing direct answers. There are references to specific satellite types and their operational characteristics, which may influence the discussion.
bigmac
I'm suppose to explain that...
none...
Well I tried to explain it but I'm not sure if its right. I think that if you are near the south pole, there would be less satellites visible because the population that uses the satellite technology the most is in the northern part of the globe? lol can someone help me with this.
One more question:
1. What do you notice about the mean motion and the inclination of geosynchronous satellites? Explain why each value is what it is.
I don't get that question at all...any help! thanks!
Suppose a satellite is directly over the North pole. What spot on the Earth will be directly underneath the satellite half an orbit later?
umm the spot between the north and the south pole? I'm not sure if I understood you correctly...
anything?
Halfway between the north and south pole is the equator, and that is where it will be in a quarter of the orbit, not half an orbit.
So, you're saying that the fewest sats are visible when they are at the equator? can you explain it please! thanks!
I would think the fewest would be viewed at the poles.
Wouldn't all geostationary satelites be visible from the pole while only half of them would be visible from the equator?
No, I'm not saying that. I am trying to help you do your own homework. Our job here is to help you do your homework, not do it for you. Begging for answers is not a good ploy here.
A satellite's orbit is in the shape of an ellipse with the center of the Earth at one focus of the Earth. A circular orbit is even easier to imagine: It is a circle with the center of the Earth at the center of the orbit. Satellites can be in equatorial orbits because the equator forms a circle around the Earth with the center of the Earth at the center of the circle.
A satellite in an equatorial orbit will never be over the North Pole. What does a circular orbit that passes over the North Pole look like? What point is diametrically opposed to the North Pole?
This is homework, mgb_phys.
Geostationary satellites are not visible from the poles. Why not?
I know, pick me.
kellenm said:
I know, pick me.
Don't tell, please. This is a homework thread.
I know...
I wasn't begging for an answer. I just didn't understand it...I'm still confused
This is key.
A couple more hints:
A satellite cannot be permanently stationed over the North Pole, or over Washington DC, or over Mexico City. Why not?
A truly geostationary satellite must necessarily be in an equatorial orbit. Why?
GSO is 36,000km above the equator so the pole is at an angle above the plane of:
asin ( Earth radius / Earth radius + 36,000km ) = 8.8deg
But then I had a m / km swapped in the rule for the distance to the horizon, so they would be above the horizon if you were 1.7km tall !
That 8.8 deg: positive or negative?
Hey! This is a homework problem you guys are dorking around with.
Stop that!
It's a dumb question.
From a point on the equator you can see roughly half of the Geostationary band but these aren't uniformly distributed around the equator - do you need to check the current positions? Are dead satelites counted.
Anything like GPS or Iridium is going to have even coverage over all points on Earth.
Same with a sun synchronous Earth resources platform.
A Molniya orbit is going to spend most time visible from the north are you supposed to take into account time averaging?
Which spot on Earth would have the fewest # of satellite's visible?
How would you go about placing satellites in low orbit such that at no time is any area not in line-of-sight communication with at least one satellite? --or four? How many are required for gps positional data? How many would you need in 250 kilometer orbits to obtain this? Should more than one satellite be in an orbit? These are the practical questions of orbital surveillance or gps-ing. Where on Earth does your question come from? It has no unique answer.
Do you know what Platonic solids are?
