Who is carrying the most weight?
  • Thread starter Thread starter aud11888
    Weight
The discussion focuses on calculating the load supported by two delivery men carrying a 200 kg crate up a 45-degree staircase. The weight of the crate, which is 1962 Newtons (calculated using W = mg), is evenly distributed between the two workers. Each worker exerts a vertical force straight up, and the free body diagram should reflect this with vertical arrows at each end of the crate. The conclusion is that both workers support equal weight, approximately 981 Newtons each.
  • Understanding of Newton's laws of motion
  • Basic knowledge of free body diagrams
  • Familiarity with weight calculation (W = mg)
  • Concept of center of gravity in physics
  • Study the principles of static equilibrium in physics
  • Learn how to draw and interpret free body diagrams
  • Explore the effects of angles on force distribution
  • Investigate real-world applications of load distribution in logistics
Physics students, logistics professionals, and anyone interested in understanding load distribution and force calculations in practical scenarios.
aud11888
Two delivery men carry a crate up a flight of stairs that have an angle of 45 degrees. You may assume the crate is loaded evenly and has a mass of 200kg. Assuming the workers can only exert a force strait up with their hands on the boz, calculate the load that each worker is supporting. Who is carrying the most weight?
ok.. so for my free body diagram, i have the dot at the center of gravity of the box, which would be the geometric center because it's loaded evenly. i have the force of the W in Newtons going strait down and the force of the guy on the high stair going from the dot on an angle to the upper right.. How would i draw the force of the guy on the lower step on my free body diagram?
Good. The weight of the crate acts at its center and points straight down.
The problem tells you that both men exert their forces straight up at each end of the crate, not at an angle. So your free body diagram should show a vertical arrow at each end representing these forces.
yea, i realized that.. i got the answer now, but thank you for the help.
12K
