Who wants to help me maximize the area of a kite? (Optimization)
  • Thread starter Thread starter nietzsche
    Area Optimization
The discussion focuses on maximizing the area of a kite formed by four pieces of wood, two of length 'a' and two of length 'b'. The key equation for the area is given by P = (1/2)d1 * d2 = ab * sin(θ), where θ is the angle between the sides of lengths 'a' and 'b'. To find the maximum area, the derivative f'(x) = ab * cos(x) is set to zero, leading to the conclusion that the angle θ should be π/2 for maximum area, confirming that the kite should be a rectangle when a equals b.
  • Understanding of basic geometry, specifically properties of kites and parallelograms.
  • Knowledge of calculus, particularly differentiation and optimization techniques.
  • Familiarity with trigonometric functions and their applications in area calculations.
  • Basic understanding of computer algebra systems (CAS) and their relevance in solving mathematical problems.
  • Study optimization techniques in calculus, focusing on critical points and second derivative tests.
  • Learn about the properties of kites and parallelograms in geometry.
  • Explore the use of computer algebra systems (CAS) for solving complex mathematical problems.
  • Investigate trigonometric identities and their applications in area maximization problems.
Students studying geometry and calculus, educators teaching optimization problems, and anyone interested in applying mathematical concepts to real-world scenarios involving shapes and areas.
nietzsche
I just can't figure this problem out.
You have four pieces of wood, two with length a and two with length b, and you arrange them in the shape of a kite (pieces of equal length placed adjacent to each other). You want to build a cross in the middle as a support. How long should the middle pieces be to maximize the area of the kite?
Sorry, there was a picture in the textbook, but it should be pretty straight forward.
It's optimization.
I can't figure out how to relate the variables to each other. I know that you can cut the kite in half symmetrically, and rearrange the kite into a rectangle with length y and width x. That was what I tried to do, but I still couldn't figure it out. I ended up with a whole bunch of square roots and I couldn't isolate the variable.
I tried arranging the pieces in different triangles, but I ended up with too many variables.
Any hints would be appreciated.
Are you sure you have posted the information of this problem exactly as given? For one thing, you don't make a kite by building a frame around it. And besides, after you have used your four pieces of wood, what are you supposed to use to build the cross pieces?
For another thing, if a != b, your kite is in the shape of a rhombus; the angle formed by a short piece and a long piece is not 90 degrees. You can't cut the kite in half and form a rectangle. Instead, what you get is a parallelogram.
sorry, i meant cut the kite into four. then you can rearrange it into a rectangle.
i was looking at the problem in the textbook and i noticed a little symbol beside the number. it said "CAS". and so i searched the textbook for what "CAS" meant and it turns out it stands for "computer algebra system". in other words, my instructor assigned us a problem that she shouldn't have, because we don't learn how to use computer algebra systems in this course. thanks anyway.
No you can't, not of the values of a and b are different. For a rectangle, sides a and b have to meet at a 90 degree angle. This can't happen if a and b are different.
hehe
either way, the problem is too hard for the level I'm at. need a computer.
P = \frac{1}{2}d_1 d_2 = ab \sin(\angle ab)
If we represent is as function f(x)=absin(x), then to maximize the area f'(x)=0 and f''(x)>0.
So f'(x)=abcos(x) .
abcos(x)=0
cos(x)=0
And x=п/2.
f''(x)=absin(x)
f''(п/2)=ab>0 and for x=п/2 the area is maximized.
11K
