- 37,031
- 16,053
Wormholes, a rotating universe, etc. They are called "closed timelike curves".GrayGhost said:What situ in GR would allow for a successful "time travel" in theory?
DaleSpam said:Wormholes, a rotating universe, etc. They are called "closed timelike curves".
Yes.GrayGhost said:When you say the "rotating universe", are you talking Goedel's theory?
DaleSpam said:Yes.
GrayGhost said:bobc2,
I'm curious, how would you apply your method of determining the spacetime interval under the situ per the attached figure, which is not a Loedel figure?
GrayGhost
GrayGhost
bobc2 said:Having completed the new diagrams, I understand why you showed it the way you did--I have added many more lines to the picture, and you were trying to keep it simple.
GrayGhost said:I mentioned that it was not a Loedel figure, upfront. The reason I drafted the diagram as such, was to see whether you could apply your method of determining the spacetime interval (via right triangles) on a diagram which was not tactically symmetric. The fact is, it doesn't ... although this is not to say that the Loedel figure is not useful.
GrayGhost said:My position is that the Loedel figure determines the spacetime interval length (via your method) by the "luck of symmetry". Therefore, it's lacking in its ability to explain the total picture of the invariant spacetime interval length. One might ask ... why does your method not work if the Loedel symmetry is not strategically selected?
GrayGhost said:BobC2,
Ahhh, but no matter how you slice it, your method does not work unless you force the Loedel symmetry. The Minkowski model (using imaginary time) works everytime no matter how its presented.
The reason Minkowski's model is-not-so-restricted resides in the fact that ict' (which is the spacetime interval length s) is derived from real spatial axes orthogonal to the direction of motion (eg y=y' =ct' or z=z' =ct').
GrayGhost
GrayGhost said:I should also have added, for the benefit of others, that ...
after determining y=y'=ct', subsequently multiplying by i serves to rotate this resultant ct' distance vector 90 degrees (away from y') into what is the ict'-axis on the Minkowski illustration. That is, time is orthogonal to real space.
GrayGhost
The orthogonality of two vectors depends on the metric. The i has nothing to do with it.GrayGhost said:I should also have added, for the benefit of others, that ...
DaleSpam said:The orthogonality of two vectors depends on the metric. The i has nothing to do with it.
bobc2 said:Could you illustrate that graphically so we can be clear which axes you're talking about?
This is not correct either. The multiplication by i makes the time axis timelike, not orthogonal. Consider an orthogonal metric:GrayGhost said:I'm not suggesting that real axes cannot be orthogonal wrt one another, nor that metrics which require orthogonal axes produce non-orthogonal axes instead. I'm merely pointing out that mathematically, and as per the Minkowski model, the multiplication by i corresponds to a 90 deg rotation of the distance vector within the coordinate system, which is a complex system in Minkowski's model.
DaleSpam said:This is not correct either. The multiplication by i makes the time axis timelike, not orthogonal. Consider an orthogonal metric:
[tex]g=<br /> \left(<br /> \begin{array}{cccc}<br /> 1 & 0 & 0 & 0 \\<br /> 0 & 1 & 0 & 0 \\<br /> 0 & 0 & 1 & 0 \\<br /> 0 & 0 & 0 & 1<br /> \end{array}<br /> \right)[/tex]
and a non-orthogonal metric:
[tex]h=<br /> \left(<br /> \begin{array}{cccc}<br /> 1 & 1 & 0 & 0 \\<br /> 1 & 1 & 0 & 0 \\<br /> 0 & 0 & 1 & 0 \\<br /> 0 & 0 & 0 & 1<br /> \end{array}<br /> \right)[/tex]
with the basis vectors:
[tex]q=(1,0,0,0)[/tex] and [tex]r=(i,0,0,0)[/tex] and [tex]s=(0,1,0,0)[/tex]
Then:
[tex]g_{\mu\nu}q^{\mu}s^{\nu}=0[/tex] and [tex]g_{\mu\nu}r^{\mu}s^{\nu}=0[/tex]
while
[tex]h_{\mu\nu}q^{\mu}s^{\nu}\neq 0[/tex] and [tex]h_{\mu\nu}r^{\mu}s^{\nu}\neq 0[/tex]
So the multiplication by i does not have anything to do with orthogonality. It does not make two orthogonal vectors non-orthogonal and it does not make two non-orthogonal vectors orthogonal. What it does is to make the one axis timelike, meaning that
[tex]g_{\mu\nu}q^{\mu}q^{\nu}=1[/tex] but [tex]g_{\mu\nu}r^{\mu}r^{\nu}=-1[/tex]
This is a different concept than orthogonality.
Here is what I am objecting to, this is not correct. It can be projected as a length ct onto the Euclidean xyz space, but it already exists as a null-length path in the Minkowski txyz spacetime.GrayGhost said:Consider a real light ray's pathlength from origin thru (say) the +x+y quandrant over time t. It exists as a length ct in the real xy plane.
The t axis is already 90 degrees from the x, y, and z axes.GrayGhost said:Mulitply ct by i, and that vector then rotates 90 deg from real space, and becomes colinear with Minkowski's ict axis (not ict').
It is not about your wording. I am trying to teach you something here. You don't seem to understand the difference between the orthogonality of two vectors and the signature of a metric. The purpose of i in the ict convention is not to make anything orthogonal to anything else (they are already orthogonal); the purpose is to make the signature (-+++).GrayGhost said:So I don't see why DaleSpam objected to it, but I suspect it had to do with my wording "that could have been stated better" in a prior post here.
DaleSpam said:Here is what I am objecting to, this is not correct. It can be projected as a length ct onto the Euclidean xyz space, but it already exists as a null-length path in the Minkowski txyz spacetime. The t axis is already 90 degrees from the x, y, and z axes.
DaleSpam said:If you want to add a 5th axis (3 real spatial axes, 1 real time axis, 1 imaginary time axis) then you can indeed claim that it rotates 90 degrees in a plane which is already orthogonal to xyz space. I.e. it starts out orthogonal to the x, y, and z axes and parallel to the t axis and after the rotation it is still orthogonal to x y and z, but is now also orthogonal to t. This is NOT Minkowski's approach AFAIK.
DaleSpam said:If you do not want to add a 5th axis then there is no rotation involved and the multiplication by i only serves to identify the signature of the metric.
DaleSpam said:It is not about your wording. I am trying to teach you something here.
DaleSpam said:You don't seem to understand the difference between the orthogonality of two vectors and the signature of a metric. The purpose of i in the ict convention is not to make anything orthogonal to anything else (they are already orthogonal); the purpose is to make the signature (-+++).
DaleSpam said:Do you understand how orthogonality is defined in a metric space?
DaleSpam said:Do you understand what is meant by the signature of a metric?
DaleSpam said:Do you see from the math above how multiplying by i does not change any orthogonality relationships (i.e. no rotation)?
DaleSpam said:Do you see from the math above how multiplying by i does change the signature?
GrayGhost said:Consider a real light ray's pathlength from origin thru (say) the +x+y quandrant over time t. It exists as a length ct in the real xy plane. Mulitply ct by i, and that (distance) vector then rotates 90 deg from real space, and becomes colinear with Minkowski's ict axis (not ict'). The length of that ray is in fact the length of the time interval, because time t = ct per Minkowski.DaleSpam said:Here is what I am objecting to, this is not correct. It can be projected as a length ct onto the Euclidean xyz space, but it already exists as a null-length path in the Minkowski txyz spacetime.
From Euclidean geometry you should already be familiar with the idea that a projection of a line segment will have a different length than a line segment. For instance the projection of a hypotenuse onto the x-axis is h cos(theta). The concept is similar in Minkowski geometry except that projections may be longer than the segment itself.GrayGhost said:Yet, I'm curious as to how you might respond to this ...
Q) How does a null (zero) pathlength in spacetime produce a non-null projection into real euclidean 3-space?
I know it does, but I'm curious as to how you'd explain that in layman's terms.
DaleSpam said:From Euclidean geometry you should already be familiar with the idea that a projection of a line segment will have a different length than a line segment. For instance the projection of a hypotenuse onto the x-axis is h cos(theta). The concept is similar in Minkowski geometry except that projections may be longer than the segment itself.
GrayGhost said:Yes, however I was interested in how you would answer that for the lightpath ...
Q) How does a null (zero) length produce a non-null projection unto 3-space, in layman's terms?
GrayGhost
Grayghost to DaleSpam said:Yes, however I was interested in how you would answer that for the lightpath ...
bobc2 said:GrayGhost, you set up a laser beam, pointed from one end of the room to the other along your x axis, then observe the projection.
Actually, you are wanting the projection of a single photon world line to project on your x axis. That would be difficult to do, even aside from quantum mechanical issues, because the sequence of photon positions along your x-axis occurs so fast. After all, you are moving along your own 4th dimension (X4) at 186,000 miles every second, so you are traveling enormous distances in a fraction of a second while trying to observe photon movement of just 20 ft or so.
That is exactly what I answered in post 143.GrayGhost said:Yes, however I was interested in how you would answer that for the lightpath ...
DaleSpam said:That is exactly what I answered in post 143.
Then you will have to be a little more detailed about why you think it falls short. It seems perfectly adequate to me capturing both the similarities with Euclidean geometry as well as the essential difference due to the (-+++) signature. Anything more specific will require math.GrayGhost said:I know. That's the traditional explanation, in general. I don't believe that explanation is enough to explain the projection of a lightpath onto perceptable 3-space. It definitely applies, but it just seems to fall short IMO.
