Why are core electrons removed from atoms on X-ray irradiation in XPS?
In summary, Cu Kα can be used for XPS, as mentioned in this paper. However, even monochromated Cu Kα suffers from having a fairly large line width at ≈2.4 eV, in comparison monochromated Al Kα has a resolution <1 eV. XRD experiments using a lab source would usually be done in ambient conditions, so you wouldn't detect the emitted photoelectrons.
madhusoodan
[Mentor's note: Post moved to its own thread]
Hi
Please let me know why core electrons are removed from the atoms on x-ray irradiation in XPS, though it was easier to outer electrons?
Weakly bound electrons can be treated like free electrons, as the binding energy is much smaller than the X-ray energy.
For free electrons, scattering from x-rays is not possible as this would violate momentum conservation.
So scattering or excitation of electrons is only possible if they are appreciably bound to the nucleus.
Hi
I think there is a misunderstanding here.
The core level electrons is used to distinguished the electrons that are highly localized to the parent atoms or ions of the solid, as opposed to the "band" electrons that are due to the overlapping of the outer orbitals in the formation of the solid. These band electrons usually show a dispersive feature that are not observed in the core-level electrons. So these are not simply "outer electrons" as in outer shell. There are no isolated "outer shell" electrons anymore in a solid.
XPS will excite all electron levels that are possible. However, the cross-section for absorption is different for different levels and different photon energies. There is also a difference in the density of states, or the density of levels. All of these will dictate the signal or peak strength for each level. You CAN see the Fermi edge at low binding energy. This means that you do get photoemission from the band electrons ( your outer electrons), but the signal is often weak when compared with the core level electrons, which usually dominate.
Zz.
Likes madhusoodan
Thanks for clearing my earlier doubt.
Why can't Cu K alpha eject electrons from atoms of the sample in XRD?
As everyone knows, Al K alpha photon with 1486 eV energy is used for XPS to remove electrons from core levels. My doubt is why can't Cu K alpha photon with 8000+ eV do that?
Typically for high energy x-rays, people go to a synchrotron light source (and in the future, probably an x-ray free electron laser source) instead.
Thanks for the reply. Still I doubt whether electrons are ejected out from the atoms of sample or not during the xrd. Since energy of the Cu Kα photons is huge compared to Al kα photon,it seems electrons seems to be get ejected, however it is not observed and mentioned anywhere. Please help me to get clear picture of their differences.
Related to Why are core electrons removed from atoms on X-ray irradiation in XPS?
1. What is X-ray spectroscopy?
X-ray spectroscopy is a scientific technique used to analyze the chemical and physical properties of materials by measuring the energy and intensity of X-ray radiation that is emitted or absorbed by the material.
2. How does X-ray spectroscopy work?
X-ray spectroscopy works by exposing a material to X-ray radiation and then measuring the energy and intensity of the X-rays that are emitted or absorbed by the material. This information can then be used to identify the elements present in the material and analyze its chemical and physical properties.
3. What are the applications of X-ray spectroscopy?
X-ray spectroscopy has a wide range of applications in various fields, including materials science, chemistry, physics, and medicine. It is commonly used for elemental analysis, identifying unknown substances, studying the crystal structure of materials, and medical imaging.
4. What types of X-ray spectroscopy are there?
There are several types of X-ray spectroscopy, including X-ray fluorescence (XRF) spectroscopy, X-ray absorption spectroscopy (XAS), and X-ray photoelectron spectroscopy (XPS). Each type has its own unique advantages and is used for different purposes.
5. What are the benefits of using X-ray spectroscopy?
X-ray spectroscopy is a non-destructive and highly sensitive technique that allows for the analysis of a wide range of materials. It provides valuable information about the chemical and physical properties of materials, and its applications in various fields make it a valuable tool for scientific research and industrial processes.
  • Atomic and Condensed Matter
  • High Energy, Nuclear, Particle Physics
12K
  • Biology and Chemistry Homework Help
