Why Are Riemann Sums Confusing Without Function Curves?
3 replies · 5K views · last reply
guynoone
Alright, I started doing Riemann sums and I am ripping my hair out in frustration. I just can't wrap my head around how I'm supposed to do it, and my woefully vague textbook isn't helping either. I'm wondering how I'm supposed to solve a Riemann sum question with sigma notation (no limits), and with only the width and height of the rectangles provided (no curve function). I used the image as an example. I have absolutely no clue how/why they get the 30 and 27. If anyone could provide a step by step explanation, it would be great. Thanks
Welcome to PF!
guynoone said:
… I have absolutely no clue how/why they get the 30 and 27.
Hi guynoone! Welcome to PF! :smile:
ok … for some reason, the 0th Riemann sum, from 1 to n, is defined as being 1/n times the ∑, and the 1st Riemann sum as 1/n² times ∑.
In this case, you're expecting 10/3 times the 0th sum, and 1/3 times the 1st, but this particular definition means that you multiply the 0th one by 9, = 10/3 * 9 = 30, and the 1st one by 81, = 81 * 1/3 = 27. :smile:
(it isn't the only way of working out this problem … it's only really useful if you happen to have tables of Riemann sums :wink:
personally, i prefer to remember ∑i = n(n+1)/2)
Thanks for the answer. To be honest I still don't really get what is happening for the solution I posted, but I just plan on sticking to the ∑i = n(n+1)/2) method which is way better (they must be trying to confuse us on purpose with these identities!)
''ok … for some reason, the 0th Riemann sum, from 1 to n, is defined as being 1/n times the ∑, and the 1st Riemann sum as 1/n² times ∑.''
Little abuse of notation here, even though I'm sure tiny-tim understands the entire problem.
The 0th order term refers to a sum which involves [tex]i^0[/tex], or [tex]1[/tex], a first order term involves [tex]i^1 = i[/tex], and so on. Writing [tex]\sum[/tex] without any explicit is common, but writing it without any arguments (summands) is not.
Actually, all that is done in this work a (very poor, in my opinion) condensation of the basic steps.
[tex] \begin{align*}<br /> \sum_{i=1}^9 {\frac{10-i} 3} & = \frac 1 3 \sum_{i=1}^9 {(10-i)}\\<br /> & = \frac 1 3 \left(\sum_{i=1}^9 10 - \sum_{i=1}^9 i \right) \\<br /> & = \frac 1 3 \left( 10 \sum_{i=1}^9 1 - \sum_{i=1}^9 i \right)\\<br /> & = \frac 1 3 \left(10 \cdot 9 - \frac{10\cdot 9}{2} \right) \\<br /> & = \frac 1 3 \left(90 - 45\right) = \frac{45}{3} = 15<br /> \end{align*}[/tex]
Note that the formula
[tex] \sum_{i=1}^n =\frac{n(n+1)} 2[/tex]
was used, with [tex]n = 9[/tex], was used.
As I indicated at the top of my post, I believe the solution for this problem (the one posted by the OP) is very poorly presented and typeset
