Why are the axes taken as perpendicular to each other?
The discussion revolves around the reasons for choosing perpendicular axes in coordinate systems, exploring whether this choice is purely conventional, mathematically advantageous, or influenced by other factors. Participants examine implications for mathematical simplicity and visualization in various contexts.
  • Some participants suggest that having orthogonal basis vectors is a beneficial property that simplifies calculations.
  • Others argue that while non-orthogonal axes are possible, they complicate mathematical expressions and reasoning.
  • A participant notes that the choice of perpendicular axes is largely a convention, influenced by everyday experiences and perceptions of space.
  • There is mention of Pythagorean theorem as a reason for preferring orthogonal axes, as it simplifies distance calculations between points.
  • One participant humorously suggests that the complexity of non-orthogonal axes could be quantified, indicating a light-hearted debate on the topic.
  • Another participant raises a question about the mathematical expression for distance in non-orthogonal systems, indicating that it is more complicated than in orthogonal systems.
  • There is a philosophical angle discussed, questioning whether the choice of axes is more about human perception than mathematical necessity.
Participants express a mix of agreement on the convenience of orthogonal axes for mathematical clarity, while also acknowledging that non-orthogonal systems can be valid but more complex. The discussion remains unresolved regarding the philosophical implications of this choice.
Some participants highlight that the complexity of non-orthogonal axes may depend on specific applications, and there are unresolved questions about the implications of choosing different angles for axes.
murshid_islam
TL;DR
Why are the axes taken as perpendicular to each other rather than at some other angle?
Why are the axes taken as perpendicular to each other rather than at some other angle? Is it just a matter of convention? Is there any mathematical reason behind it? Is there some other reason?
Mathematics news on Phys.org
Having basis vectors orthogonal to each other is a nice property.
You certainly can make axes non-orthogonal. In most cases, though, it makes the math harder, not easier. Same principle as playing piano wearing mittens. I mean, you could...
Yes, I think so. Although it is a pervasive and really convenient convention. Streets in cities, and the walls in your house are mostly 90o angles, etc. It's what we are used to, for good reasons. The equation of a circle still works and you can still call it a circle. But when you display it this way, it won't look like a circle to you. The math will appear to us as more complex, but I'm not sure the people that live in "acute axes world" would see it that way.
It's nearly a pointless philosophical question. More about how we see and think about the world than "pure math". OTOH, I personally can't imagine learning analytic geometry or linear algebra with this picture, it would be sooo much harder for me to visualize anything.
PS: BTW, when/if you get to studying things like eigenvectors and normal forms, used in dynamic systems analysis (among other things). You will learn how to deal with systems that make more sense (i.e. easier) when you use non-orthogonal basis (axes). There are things in this world that look simpler with "tilted" axes.
I'll say Pythagoras. with orthogonal axes, distances are easy to measure using coordinates by his theorem.
@murshid_islam This is pretty much your answer. It is very convenient to be be able to calculate the distance between two points as ##\sqrt{\Delta x^2+\Delta y^2}## instead of the more complicated expression (probably involving trig functions) that we get when the axes aren’t orthogonal. So because we see no reason to make problems harder than they need to be, we draw the axes perpendicular because it’s simpler and clearer that way.
For an example, consider the equation for a circle (all points the same distance from the center point). It’s trivial with perpendicular axes, wildly confusing otherwise.
In other words, Pick the axes such that sin = 0 and cos = 1. Unless there is a good reason to do otherwise.
It's not that bad.
The distance is [itex]\sqrt{\Delta x^2 + \Delta y^2 + 2\Delta x \Delta y \cos \theta}[/itex].
Maybe we should put some standards organization to work quantifying how bad “that bad” is? :smile: :smile:
Vanadium 50 said:
not that bad.
I left my trig tables in my other briefcase.
Telling you how old I am without telling you...
Vanadium 50 said:
It's not that bad
Shouldn't there be a minus sign in front of the cosine part?
Sure, there isn't a straightforward answer to this seemingly simple question? Axes divide the surface into four quadrants, and that's where everything seems to begin:wink:.
