Kiyal
- 15
- 0
The universe is expanding: Why is it that the further galaxies and stars are away from us they appear to be moving away at a much faster speed than ones closer to home?
The discussion centers on the phenomenon of the expanding universe, specifically addressing why more distant galaxies and stars appear to be moving away at faster speeds compared to those that are closer. The conversation explores various analogies, mathematical models, and the implications of gravitational binding in relation to cosmic expansion.
Participants express a mix of agreement and disagreement regarding the analogies used and the implications of gravitational binding. While some concepts are accepted, there is no consensus on the adequacy of certain analogies or the specifics of gravitational effects on galaxy clusters.
Participants note limitations in their understanding of the quantitative aspects of gravitational binding and expansion, with some expressing uncertainty about the calculations involved in estimating pressures within galaxies and clusters.
wabbit said:Kiyal, you ought to visit http://www.phinds.com/balloonanalogy/
Kiyal said:This helped me a lot, thank you!
So gravity and electromagnetism holds together atoms and solar systems because the slow expansion of space can't overcome the forces of gravity/electromagnetism? So distances among solar systems etc get further apart, though we don't as we're held together by said forces? I think this is making sense, if I'm on the right tracks.
wabbit said:. It is as if you tried stretching a metal coin by attaching a rubber band to each side and pulling on that rubber band - only weaker, empty space is not as strong as rubber:)
As wabbit already pointed out, solar systems do not get farther apart because they are part of the same galaxy. It goes even farther than that though. "Bound systems" include galactic clusters as well, so galaxies that are all in the same cluster are not affected by the expansion.Kiyal said:So distances among solar systems etc get further apart...
Right. To get a quantitative estimate of the relative "strength of expansion" vs "strength of gravitational binding" I was trying, following one of marcus' many enlightening calculations, to compare the corresponding pressures: the negative pressure of expansion turns out to be about 2×10-15 atmospheres IIRC - but I couldn't find an estimate of the average positive pressure of gravity (or equivalently the average energy density including matter and radiation but excluding DE) within a galaxy, a cluster, etc... My guess is that the ratio of such pressures would give a "precise" equivalent of the rubber-strength to metal-strength ratio in the above example.phinds said:"Bound systems" include galactic clusters as well, so galaxies that are all in the same cluster are not affected by the expansion.
Yeah, I've never gotten into the details at that level. It seems that some galactic clusters, very large ones but with relatively low density, ARE affected at the outer galaxies because their gravitational attraction to the cluster center is not enough to overcome expansion, but I have no idea how one computes that in specific cases.wabbit said:Right. To get a quantitative estimate of the relative "strength of expansion" vs "strength of gravitational binding" I was trying, following one of marcus' many enlightening calculations, to compare the corresponding pressures: the negative pressure of expansion turns out to be about 2×10-15 atmospheres IIRC - but I couldn't find an estimate of the average positive pressure of gravity (or equivalently the average energy density including matter) within a galaxy, a cluster, etc... My guess is that the ratio of such pressures would give the "precise" equivalent of the rubber-strength to metal-strength ratio in the above example.
My guess here is that it just amounts to dividing the mass of the cluster (converted to energy through E=mc2) by its volume, but perhaps that is (far) too simplistic.phinds said:but I have no idea how one computes that in specific cases.
No, not at all, because the analogy fails completely to show that normal galactic clusters do NOT drift apart and ones where the outer galaxies do drift off don't have the rest of the galaxies drifting apart.Blackberg said:If we drop ping pong balls in an ocean, they will drift apart. Wouldn't that be an acceptable analogy?
The ping pong balls being galaxy clusters. The water being "expanding space".
(water molecules may be playing the role of a particle someone else may be able to identify).
phinds said:No, not at all, because the analogy fails completely to show that normal galactic clusters do NOT drift apart and ones where the outer galaxies do drift off don't have the rest of the galaxies drifting apart.
Sorry this is wrong wrong wrong. Let me try again I don't know if I'll get this right this time either, but at least there should be one error removed.wabbit said:Right. To get a quantitative estimate of the relative "strength of expansion" vs "strength of gravitational binding" I was trying, following one of marcus' many enlightening calculations, to compare the corresponding pressures: the negative pressure of expansion turns out to be about 2×10-15 atmospheres IIRC - but I couldn't find an estimate of the average positive pressure of gravity (or equivalently the average energy density including matter and radiation but excluding DE) within a galaxy, a cluster, etc... My guess is that the ratio of such pressures would give a "precise" equivalent of the rubber-strength to metal-strength ratio in the above example.
Doug Huffman said:Beggars the meaning of galaxy cluster. Either they are gravitationally bound or not.
Yes, that is exactly what I said in post #12Blackberg said:At some sufficiently large radius for a galaxy cluster, I would expect gravity to be sufficiently weak for the outer galaxies to drift away with expanding space.
I would say dense clusters, not large clusters, since it is the gravitational attraction of the outer galaxies to the cluster center that matters, and that depends more on density than size.wabbit said:... negligible for a galaxy, bately noticeable for the largest clusters
Perhaps the distinction in a way similar to "where does the Earth atmosphere end"? There is no sharp limit - even if Earth were strictly alone in space, at some point random thermal movement gets some molecules kicked out (though one molecule kicked out might still come back after hitting another one)?Blackberg said:I see. The assumption seems fair to me that they lie on a threshold between a gravity well and space expansion.
Agreed, a large but very dense cluster could be "tightly bound".phinds said:I would say dense clusters, not large clusters, since it is the gravitational attraction of the outer galaxies to the cluster center that matters, and that depends more on density than size.
yeswabbit said:Agreed, a large but very dense cluster could be "tightly bound".
George Jones said:A technical reference on the effect of the universe's expansion on gravitationally interacting systems is "The influence of the cosmological expansion
on local systems" by Cooperstock, Faraoni, and Vollick,
http://arxiv.org/abs/astro-ph/9803097A reference (somewhat less technical than the reference above) on electrically interacting systems (e.g., atoms) is "In an expanding universe, what doesn’t expand?" by Price and Romano,
http://arxiv.org/abs/gr-qc/0508052
wabbit said:this is bound to be better
No, that was completely unintentional- thanks for the laugh !George Jones said:Pun intended?![]()
phinds said:Yes, that is exactly what I said in post #12
