Why Can Every Element of SO⁺(1,3) Be Expressed as an Exponential?
The discussion centers on the ability to express any element of the proper orthochronous Lorentz group, SO⁺(1,3), as an exponential of an element from its Lie algebra. Participants explore the implications of this property, particularly in the context of non-compact Lie groups, and seek to understand the underlying reasons for this phenomenon.
  • Some participants note that while compact connected Lie groups allow every element to be expressed as an exponential of the Lie algebra, this does not necessarily apply to non-compact groups.
  • Others argue that the existence of the exponential mapping is linked to local compactness rather than compactness itself.
  • One participant suggests that the structure of SO⁺(1,3) can be described by a finite number of parameters, which may imply that every element can be expressed via the Lie algebra.
  • Another participant emphasizes that the exponential map provides a diffeomorphism from a neighborhood of the identity in the Lie algebra to a neighborhood of the identity in the group.
  • Some participants reference theorems regarding the surjectivity of the exponential map, noting that it is surjective for compact connected groups, while also discussing conditions under which it applies to connected non-compact groups.
  • There is a discussion about the implications of connectedness and path-connectedness for the generation of the group by the Lie algebra.
Participants express differing views on the implications of compactness for the exponential map, with some asserting that it is not necessary for the map's existence, while others argue that surjectivity is contingent on compactness. The discussion remains unresolved regarding the justification for the exponential representation in the context of SO⁺(1,3).
Participants acknowledge that while every Lie group is locally compact, the relationship between compactness and the ability to express group elements as exponentials remains a nuanced topic. The discussion highlights the need for further clarification on theorems related to the exponential map in non-compact settings.
parton
Hi!
I was wondering why it is possible to write any proper orthochronous Lorentz transformation as an exponential of an element of its Lie-Algebra, i.e.,
[tex]\Lambda = \exp(X),[/tex]
where [itex]\Lambda \in SO^{+}(1,3)[/itex] and X is an element of the Lie Algebra.
I know that in case for compact, connected Lie groups, every element of the group can be expressed by the exponential of an element of the corresponding Lie algebra. But this is not necessarily true for non-compact groups.
In case of [itex]SO^{+}(1,3)[/itex] we are dealing with the connected component of the full Lorentz group. But it is non-compact. So why is it nevertheless possible to express every element of [itex]SO^{+}(1,3)[/itex] by an exponential of an element of the Lie algebra?
I hope someone could help me understanding that.
Usually the restricted Lorentz group is denoted by SO[itex]\uparrow[/itex]+(1,3) and it's the component of the full Lorentz group connected to the identity.
Off the top of my head, the existence of the exponential mapping as a mean to link the Lie group to its corresponding Lie algebra is not determined by whether the group is compact or not, but rather if it's locally compact or not.
Thanks for your reply :smile:
I think the usual notation is [itex]\mathcal{L}_{\uparrow}^{+}[/itex] or [itex]SO^{+}(1,3)[/itex].
In the latter case, the arrow is not necessary, because the 'S' already expresses the fact that the determinant is 1.
The exponential map links the Lie group in a neighborhood of the identity to the Lie Algebra. So you can describe the a group element near the identity by the Lie Algebra.
But on the other hand you cannot reconstruct every element from the Lie Algebra in general.
If we have a compact connected group than every element of the group can be built by the Lie Algebra (via the exponential map). But it is clearly not sufficient to have a locally compact group.
By the way, every Lie group is locally compact.
So, I am curious why every element of the group [itex]SO^{+}(1,3)[/itex] which is clearly connected, but not compact, can be constructed from its Lie Algebra. Maybe anyone has an explanation.
Maybe, there is a way: if one determines the general structure of a matrix of [itex]SO^{+}(1,3)[/itex] one finds that it can be described by 6 real parameters. And this is a finite number which is not obvious because the group is not compact.
Maybe, one can argue that if the group can be described by a finite set of paramters, than every element can be described by its Lie Algebra (via exp).
But I am not sure about this.
I stand corrected for the notation. There's been a while since college.
The exponential mapping and its existence for a general Lie group has nothing to do with the group manifold being compact or not. Likewise, if the group is non-compact, then it doesn't mean that the number of parameters describing the local charts is infinite. Mathematicians simply do not study infinite-dimensional manifolds (in particular Lie groups) as <text-book material>.
The group SO+(1,3) is not only connected, but also path-connected, this means that every element of it can be reached through curves (uni-parametric subgroups) passing through the origin. Again, this has nothing to do with its compactness or lack of.
Thanks again for your reply.
Yes, your are right of course. But I did not say the opposite.
I was just saying that if a Lie group is compact and connected every element of the group (and not only locally, i.e., in a neighborhood of the identity) can be expressed as exp(X), where X is an element of
the Lie algebra. This is a typical textbook theorem.
But because SO+(1,3) is clearly not compact, I cannot use this theorem, so I need another reason to justify why every element of SO+(1,3) can be expressed as exp(X).
And this is the question.
Maybe you know a theorem or something which might help to justify that.
For any Lie group [itex]G[/itex], [itex]\exp[/itex] gives a diffeomorphism from a neighbourhood of [itex]0 \in \mathcal{ L }_{ G }[/itex] to a neighbourhood of [itex]e \in G[/itex]. Thus, using inverse function theorem, one can show that for any CONNECTED Lie group [itex]G[/itex], [itex]G[/itex] is generated by the subset [itex]\exp ( \mathcal{ L }_{ G } ) \subset G[/itex].
Sam
Not quite so. The exp:g->G is surjective iff G is compact, connected and linear, see theorem VII of page 390, 2. Volume of Cornwell (Group Theory). Then a generalization is given by theorem VIII (proved in Appendix E, Section 2), when G is connected, non-compact and linear.
The connected component of the Lorentz group in 4D is linear, so theorem VIII applies. In particular, the number of factors is 3, see page 175 of Fonda and Ghirardi.
Actually, what samalkhaiat is said is true. Any connected Lie group is generated by any neighbourhood around the identity ( that is, take an open neighbourhood U of the identity and consider all possible products and inverses ). This is because the subgroup generated by an open neighbourhood U will be both open and closed. Since the exp map is a local diffeomorphism, the image of an open nhood around 0 of the Lie algebra will be an open neighbourhood around the identity.
This is not the same as the exponential map being surjective. However, if your Lie group is both connected and COMPACT, then the exponential map is actually surjective. This comes from the fact that you can put a riemannian metric on your Lie group. Then, the exponential map will correspond to the usual exp map from differential geometry, and the 1-parameter subgroups and the geodesics. Then, by the Hopf-Rinow theorem, you can connect any two points with a geodesic, so the exp map is surjective.
  • · Replies 26 ·
  • · Replies 0 ·
