Jupiter60
- Messages
- 80
- Reaction score
- 22
If space and time are really related, why is it that we can see space, but we can't see time?
Jupiter60 said:I can see space right now. The space between me and my computer. I can see myself move through space, though not through time. I have to look at a clock to see my movement through time. Are space and time really related?
By not being able to see time, I assume what you mean is that you can't see into the 4th dimension, even though you can see in the 3 spatial dimensions. This is because you are inherently a 3 dimensional being, and suffer from the physical limitation that you cannot see into your own fourth dimension. You can however see partially into the 4th dimension of other reference frames and objects that are moving relative to yourself.Jupiter60 said:If space and time are really related, why is it that we can see space, but we can't see time?
DaleSpam said:We don't see either space or time, we see light.
Emilyjoint said:mmmmmm...I don't think we do see light ! we see what light shines on.
I look at a candle and I see the flame because of light. I look from the side but I cannot see 'the light' from the candle pass me. If we could see light the space in front of me would be covered with criss cross lines of light ! Like a spider web or a mesh of some kind.
The function of the human eye is well studied. We see light.Emilyjoint said:mmmmmm...I don't think we do see light !
That is a reasonable point. The brain "sees" time every bit as much as it "sees" space.A.T. said:The eyes see light.
The brain sees space.
DaleSpam said:The function of the human eye is well studied. We see light.
I quoted you exactly. Your quote, as it was stated, was wrong.Emilyjoint said:You have not given my quote as it was stated !
ModusPwnd said:I don't think so. Light is the only thing we can see.
Those described as having only light perception have no more sight than the ability to tell light from dark and the general direction of a light source.
Jupiter60 said:Not really. Well, not for most of us. There are some people though who have no more vision than to tell the difference between light and dark. Those people only see light. They have only light perception.
http://en.wikipedia.org/wiki/Blindness
Another excellent point (you are on a roll A.T.!)A.T. said:And the brain doesn't need eyes to see space. People born blind grasp 3D space just fine.
Drakkith said:I don't know what you're getting at. The eye detects one thing and one thing only. Light. The brain then interprets the signals sent by the eye to form an image that you "see".
Jupiter60 said:What about shapes? The eye detects shapes. Shapes aren't light though. Though people with very severe visual impairment can't see shapes, only light.
MrAnchovy said:Because although they are related, they are not the same thing. You may as well ask "if thunder and lightning are really related, why is it that we can see lightning, but we can't see thunder?"
The question remains why the concept of time seems different than the concept of space. Is it because they are objectively physically different, or because the way the brain works? Maybe it is because the thought process itself inherently requires the passage of time, and state changes over time.Algr said:But you don't really "see" space; it might be better to say that you infer it.
A.T. said:The question remains why the concept of time seems different than the concept of space.
They are objectively physically different. Space is measured with rods and time is measured with clocks. Since the same physical device cannot measure both it is clear that they are physically different.A.T. said:Is it because they are objectively physically different, or because the way the brain works?
For humans (and all other living creatures), it is impossible to use the tiny time differences to estimate any distances on earth. Light is just too fast. It is possible for sound, as that is slower.ZapperZ said:Actually, you don't see space. You see the object! And you do you know why you think you are seeing a 'distance'? Because (i) you have depth perception because of your two eyes and (ii) the light from the object reaches your eyes AT DIFFERENT TIMES! In other words, your sense of distance actually depends on some time differences! So if we apply your "logic" of seeing space, I could also argue that you're seeing time as well!
Zz.
