Why can't light escape black holes?
The discussion centers on why light cannot escape a black hole's gravitational pull, emphasizing the role of spacetime deformation as described by general relativity. The presence of a massive object like a black hole significantly warps spacetime, creating a scenario where all paths lead back to the singularity. This deformation requires infinite energy to overcome, making escape impossible. The conversation also clarifies that the speed of gravity pertains to changing gravitational fields, while the static nature of a black hole's gravitational field prevents light from escaping once it crosses the event horizon.
  • Understanding of general relativity and spacetime concepts
  • Familiarity with black hole physics and event horizons
  • Basic knowledge of gravitational waves and their propagation
  • Concept of singularities in astrophysics
  • Research the mathematical foundations of general relativity
  • Explore the properties and implications of black holes in astrophysics
  • Study gravitational waves and their detection methods
  • Read Kip Thorne's "Black Holes and Time Warps" for a comprehensive overview
This discussion is beneficial for high school students interested in physics, educators seeking to explain complex concepts, and anyone looking to deepen their understanding of black holes and general relativity.
Ven
Hello, I am aware that this question was the subject of a topic on this site, but it did not fully answer my question.
My question is, why can't light escape from a black hole's gravitational pull, when, according to general relativity, the speed of gravity is equal to the speed of light?
My question may seem a tad elementary, but I'm in the ninth grade, and my school doesn't offer physic's classes until next year, so I'm a bit of an autodidact.
The presence of a large mass in a small area, the black hole, deforms space time itself a huge amount. It would take an infinite amount of energy to "overcome" this deformation, so all paths leading out of it end up back at the mass. Imagine a rubber sheet with a tiny little heavy marble, it'll deform the sheet. Now take the limit as the weight gets big and the size gets small and it will deform the sheet considerably at a point (a singularity).
It has nothing to do with the "speed" of the interaction.
The "speed of gravity" is only in reference to a changing gravitational field. The black hole solution is basically static, so no changes in the gravitational field need to propagate.
As the above notes, the geometry inside the event horizon of a black hole is such that even if you shine a flashlight directly outwards, the beam ends up traveling inwards towards the hole!
There are a couple separate things you're mixing up here. First, gravitational waves are what travel at the speed of light. If you have an area of flat space and suddenly introduce a large mass you create a disturbance that propagates away as a gravitational wave. This is like having a long rope, taking one end, and whipping the rope up and down once. You will see a wave going down the rope with some speed. Light is also a wave but a different type of wave. Swinging the rope side to side and seeing a horizontal wave go down the rope can represent light (note that light is actually an oscillation of the EM field, I'm just trying to convey the idea of two different types of waves with the whole vertical/horizontal wave on a string picture).
Secondly, you can have a mass that is just sitting in space without moving or disappearing and reappearing. In such a case the space around it is bent instead of flat. The space around a black hole is very bent. It is similar to pulling the string towards you. If you pull the string towards you fast enough, you'll be pulling it faster than waves can move down it. No matter how hard you swing the rope the waves will always travel at the same speed. Similarly no matter how energetic the light is it won't be able to travel across space faster than space itself is being sucked into the black hole.
Analogy:
Gravitational wave: Vertical wave on string
Light wave: Horizontal wave on string
No gravity (flat space): String is not moving
Gravity (bent space): Pulling the string towards you
Black hole's gravity (really bent space): Pulling the string towards you faster than any wave can move down the string.
Here's another way to look at it ... Once inside the event horizon, the direction of time is always toward the singularity at its center. All entities travel forward in time. Since nothing travels backward in time, everything including light must continue on toward the singularity, never escaping the black hole.
GrayGhost
Welcome Ven!
I think the above answers cover your question to the extent it can be. It is NOT elementary...consider that Einstein "proved" black holes could not even exist...so he was way, way further off...
Another analogy I like: a flat lake and sinkhole suddenly opens underneath and water begins running down into it in a rapid spiral...A bug floating on that water (that is light) can maybe swim fast enough to get away at first...that would be outside the event horizon of a black hole...but once the bug passes that theoretical point of no return, the event horizon, he just can't swim fast enough...neither can anything else.
A great book on this area of Physics is Kip Thorne's BLACK HOLES AND TIME WARPS...you should be able to find inexpensive used paperback copies online...like AMAZON...that's what I did...very little math, lots of detailed explanations of physical phenomen.
  • · Replies 22 ·
  • · Replies 21 ·
  • · Replies 40 ·
  • · Replies 62 ·
  • · Replies 20 ·
  • · Replies 17 ·
  • · Replies 17 ·
