dansmith170
- 45
- 11
Why can't satellites be equipped with radar systems so that they can detect (and then avoid) impending collisions?
The automatic collision avoidance radar on most satellites would not be needed before the satellite was out of date and out of fuel. Then, when a collision occurs, the collision avoidance radar becomes part of the fragments that must be avoided by other satellites.dansmith170 said:Why can't satellites be equipped with radar systems so that they can detect (and then avoid) impending collisions?
Counterpoint: "The growth in the number of objects in space has created challenges for the Space Force. These include gaps in the geographical distribution of global sensors that collect data and limited sensor capability for objects in deep space." GAO-23-105565mfb said:In low Earth orbit, most objects are closer to the ground than they are to other satellites. To catalog objects a ground-based radar system is much cheaper and much more powerful than a system you could put on a satellite.
According to Space.com "Since the launch of the first Starlink spacecraft in 2019, the SpaceX satellites have been forced to move over 50,000 times to prevent collisions." And it appears that half those maneuvers were in the past 6 months. Does that answer your "why" question DaveC426913?DaveC426913 said:And the big one: Why? How often does this scenario actually come up?
Why should a big satellite move out of the way of a small satellite, or fragment, if it was easier to swat, or deflect the small one?dansmith170 said:Perhaps an onboard radar system may be appropriate for a larger satellite with greater power consumption that is beyond geosynchronous orbit (assuming the radar can detect a 10km/s collision in sufficient time).
Ok, so I see the issue.dansmith170 said:According to Space.com "Since the launch of the first Starlink spacecraft in 2019, the SpaceX satellites have been forced to move over 50,000 times to prevent collisions." And it appears that half those maneuvers were in the past 6 months. Does that answer your "why" question DaveC426913?
Keep in mind what we know from our killer asteroid dodging studies.dansmith170 said:Perhaps an onboard radar system may be appropriate for a larger satellite with greater power consumption that is beyond geosynchronous orbit (assuming the radar can detect a 10km/s collision in sufficient time).
Thanks for your replies Dave. Part of what is motivating my question about onboard radar systems for satellites is that ground based detection is not as good for xGEO orbits; thus the need for some kind of space situational awareness (SSA) mechanism for such orbits.DaveC426913 said:Ok, so I see the issue.
I thought you were concerned about whether or not we had the ability to track and avoid collisions.
We do; your concern is why not upload the tracking heavy-work to the satellites themselves, as opposed to where we have it now, which is ground-based?
And the answer, as others have pointed out, is that tracking potential collisions in real-time is impractical to the point of impossible. By the time a satellite could detect a potential collison, it is too close and can't move out of the way fast enough. Orbits are very predictable and any potential collisions can be seen well in advance, which means the logistics of it can be handled easily from the ground.Imagine it as similar to air traffic control near an airport. If every plane departing or arriving were responsible for maintaining its own clear airspace (which it would have to do in real time by radar) then there would be a lot more near misses, and a lot more planes hitting the brakes hard or hitting the gas to wildly dodge a near-miss (and sending it off course). Better to have the whole thing orchestrated by the tower, where they have better radar and the ability to see planes coming for scores of miles (minutes) instead just a few miles (seconds).
(Admittedly, it's a bit of a contrived analogy. For example, you'd have to imagine the radar and fuel required for planes was a prohibitive fraction of their mass/volume/cost.)
What mechanism would you suggest for deflecting a smaller satellite? And would that even be legal? Would it be safe to go around deflecting satellites off their original course?Baluncore said:Why should a big satellite move out of the way of a small satellite, or fragment, if it was easier to swat, or deflect the small one?
How often do impending collisions come as a surprise?dansmith170 said:...ground based detection is not as good for xGEO orbits...
@mfb 's point still stands except now instead of being hundreds of miles away from earth/each other, now they are thousands or tens of thousands of miles apart. And the number is much, much smaller.dansmith170 said:Perhaps an onboard radar system may be appropriate for a larger satellite with greater power consumption that is beyond geosynchronous orbit (assuming the radar can detect a 10km/s collision in sufficient time).
dansmith170 said:starlink
That's not a counterpoint. It's an argument for more ground-based radar stations.dansmith170 said:Counterpoint: "The growth in the number of objects in space has created challenges for the Space Force. These include gaps in the geographical distribution of global sensors that collect data and limited sensor capability for objects in deep space." GAO-23-105565
... and no collision happened. That shows how good the existing ground-based detection is.dansmith170 said:According to Space.com "Since the launch of the first Starlink spacecraft in 2019, the SpaceX satellites have been forced to move over 50,000 times to prevent collisions." And it appears that half those maneuvers were in the past 6 months. Does that answer your "why" question DaveC426913?
Probably not, and even if we could we wouldn't put it on a satellite. If you see a range quoted for a radar system then it's looking for aircraft and similar sized objects.dansmith170 said:In my opinion, the question then becomes: can we build a radar system that is less than a ton, that uses kilowatts or less of average power consumption, and that has an effective range of about 400 km?
You should consider the distances properly. For a ground based radar system to reach the most 'dense' LEO orbits is at most a few thousand km range. To do it from geosynchronous orbit, it's around ten times the range required.dansmith170 said:Perhaps an onboard radar system may be appropriate for a larger satellite with greater power consumption that is beyond geosynchronous orbit (assuming the radar can detect a 10km/s collision in sufficient time).
I don't understand why you didn't continue on. From the same article: ""SpaceX currently conducts an avoidance maneuver every time orbital models show a probability higher than 1 in 100,000 that one of the Starlink satellites will cross another object's path. That threshold is 10 times lower than the standard upheld by NASA and other international agencies."dansmith170 said:According to Space.com "Since the launch of the first Starlink spacecraft in 2019, the SpaceX satellites have been forced to move over 50,000 times to prevent collisions."
Well, there is the question of which satellite moves to avoid the collision. The answer seems to be "the one with the smaller laser".Bandersnatch said:Putting a radar on a satellite brings it one step closer to a full-fledged space fighter,
I'm guessing you've never designed a satellite or a radar, either. Rive has the correct answer in post #5 above.mfb said:Essentially all satellites have power, almost always via photovoltaics. Batteries are used to make it through the shadow of Earth. Almost all satellites have propulsion to maintain their orbit and attitude.
The two things you want to add are already essential components of almost all spacecraft.
I think orbital mechanics has been ignored in most of the comments in the thread. The problem is not as easy as for flying in busy air space. The requirement for a 'radar' system is very much three dimensional. Forward - looking is not enough. You need to look several orbits in the future to decide on the risk of collision and, except for space junk, you need to negociate between craft owners about who gives way. (Nothing like as simple as deciding who is the stand-on vessel in the Dover Strait - an even there you get collisions).DaveC426913 said:Unforgiving orbital mechanics - that harshest of mistresses - may be the single biggest showstopper as to why we don't leave collision-avoidance to the individual.
