Staff Emeritus
Homework Helper
- 66
Russ let me point out that early in this thread I conceded chimneys, see post #3 . The title of the thread is “breaking chalk” . I have further specified; dropped from “several feet” I will refine that to 36” +/- 12”(1m+/- 30cm with zero initial velocity, I believe that this falls into the “several feet “ category. So that should rule out chimneys right there.
Beyond that I claim that your photos do NOT disprove my conjecture. and indeed even support my claim. Note that in the first 3 pictures the top of the chimney is at the level of the top wires, the first break occurs in frame 5, in frame 6 the chimney tip has dropped significantly look at the power lines. It is not a rotation but a direct vertical fall. We see piece 1 in frame 5, in frame 6 we see piece 2. Frames 7 and 8 show the last major unit and the .14 This is not exactly high speed video and, by the way, your video shows nothing of interest, it is impossible to tell how the chimney breaks. Your other photos are inconclusive. I say that your second video the chimney is fall directly in line with the camera, it is impossible at this angle to judge when and where the chimney breaks. Rather then make a claim, I will simply say, I can't tell.
Note in post #9 that I did allow that difference in length was not ruled out.
Moonbear has brought in density as a valid parameter, that, with the radius to length ratio will be some of the critical factors.
Indeed the chalk will shatter due to impact, with the shock wave traveling though the clock at speed of sound in chalk. What is the speed of sound in chalk?
