Why colonize Mars and not the Moon?
  • Thread starter Thread starter lifeonmercury
    Mars Moon
817 replies · 89K views
I do agree that the Moon is much easier. We need to prospect for water first, just to confirm what many people suspect, that it's there underground in some spots. But even with that delay, it's a much quicker project.
Astronomy news on Phys.org
phinds said:
Did you READ that powerpoint? It's for vehicles in space, not for colonies on the ground.
Yes, but at Deimos, the base would be kind of still in flight. It could just stand off the surface on a thin rod, supported at it's centre point, rotating away. You would come and go from the station using tiny jets, like they use for a spacewalk.
I think you are vastly oversimplifying the whole thing but again, I'm just seriously pessimistic about all of this and think the whole concept of colonization in the near future is silly at this time.
Cool sci-fi idea, and I mean that as a complement actually. I'm waiting for someone to say why it isn't practical. lol
Well one thing that would be difficult would be attaching the thin rod spoken of on to the surface of Deimos.
Since initially the rod will be rotating along with the rest of the spacecraft .
Since initially it will be rotating along with the rest of the spacecraft .
I figured you wouldn't start rotating the thing until everything was hooked up.
I might have missed this in a previous post but has anybody looked at Robert Zubrin's Mars Direct proposal. He carries some credibility as an aeronautical engineer and entrepreneur and is at least carrying out Earth based studies on the issue of working on Mars. He has a solution for zero gravity at least in transit.
Looking at the Mars Direct website, you get a real feel for the "surviving on the edge" element that is lost on the more optimistic posters on this thread. The pictures on their website should be a reality check. With current technology it is obviously basic expedition living and, hopefully, getting back alive.
With current technology, would it be possible to create breathable air inside a facility using tha gases in the Martian atmosphere? Obviously a lot of nitrogen would be needed in addition to the oxygen.
The atmosphere is mainly CO2, it's not hard to extract the Oxygen and dump the Carbon. but is fairly energy intensive.
This technology is already in use for the ISS.
There is some Nitrogen in the atmosphere of Mars, there is also Argon which like Nitrogen is inert chemically if breathed in.
Deimos has a day/night cycle of 30 hours, that doesn't sound healthy.
Al_ said:
How about artificial gravity?
So we go to Deimos to have a lower gravity, and then we need a mechanism to get artificial gravity? Why not just land on Mars and get gravity for free? Plus CO2, water much more.
The "rotating station on a stick" approach gets impractical with sufficient radiation shielding. It also leads to a large minimal station size, and expansion is problematic.
This thread is not about a first mission. It is about a possible global, large-scale effort to establish a permanent and eventually self-sufficient colony.
On Earth, this has been done many times: Groups of people moving to a new, previously uninhabited area, and starting there basically from scratch. Going to Mars permanently will be orders of magnitude more challenging, but we won't arrive with sticks and stones.
All previous migrations were to a new part of the Earth, often with better resources for survival and development and everything they needed was freely available: animals to hunt, edible vegetation, water. Mars is not anything like the Earth. The essence of your analogy is that if a European can migrate to Australia or North America to start a new life, then he can surely migrate to Mars. That is an absurd comparison. Not least because nothing we have learned from those migrations helps us to any extent with a migration to Mars. There are many areas on Earth that are not inhabited because of their relative hostility to human life. Mars, by comparison, is many times more hostile to human life than anywhere on Earth.
Anyway, if you don't mind my asking, are you signed up to go?
In the spirit of Private Eye:
Dear Sir, have you ever noticed the resemblance between a Martian Colony and Abu Dhabi?
Mars:
Abu Dhabi:
I never said that.
Earth was not colonized with 2050 technology, it was colonized by foot and with sailing ships. Surely we can do better with 2050 technology?
If that would be true, why did you ask how to get the first steel foundry on Mars? How did we get the first steel foundry in the Americas? Someone built it. With tools built there, which were probably built with tools built there, and if you go back long enough you arrive at tools from Europe. The details are a lot of engineering work, but they are no fundamental problem.
Your second photo is close to Abu Dhabi 1960, by the way, just without the space suit imitation. Then humans found a reason to build a town there (oil). And see how it looks now, a few decades later.
There won't be any oil on Mars unless our assessment of the planet so far is completely mistaken.
There is Iron, but we don't have a shortage of Iron on Earth.
It would be a miscalculation to write off Elon and SpaceX concerning Mars, that outfit seems to have an impressive learning curve. For the moment let's focus on NASA's research regarding putting 20 metric tons on Mars per landing, using the SLS (PDF recommended).
https://ntrs.nasa.gov/search.jsp?R=...0&Ntk=All&Ntt=mars&Ntx=mode%20matchallpartial
Abstract:
"Current NASA Human Mars architectures require delivery of approximately 20 metric tons of cargo to the surface in a single landing. A proposed vehicle type for performing the entry, descent, and landing at Mars associated with this architecture is a rigid, enclosed, elongated lifting body shape that provides a higher lift-to-drag ratio (L/D) than a typical entry capsule, but lower than a typical winged entry vehicle (such as the Space Shuttle Orbiter). A rigid Mid-L/D shape has advantages for large mass Mars EDL, including loads management, range capability during entry, and human spaceflight heritage. Previous large mass Mars studies have focused more on symmetric and/or circular cross-section Mid-L/D shapes such as the ellipsled. More recent work has shown performance advantages for non-circular cross section shapes. This paper will describe efforts to design a rigid Mid-L/D entry vehicle for Mars which shows mass and performance improvements over previous Mid-L/D studies. The proposed concept, work to date and evolution, forward path, and suggested future strategy are described".
The Mars rover Curiosity EDL was fascinating. though based on known stuff that works. That was 1 metric ton.
20x that needs more fingers to be crossed.
We have a system that can land 25 ton rockets on a concrete pad with a precision of a few meters, I would expect that modified feet would work on the Martian surface.
Make a guess which company developed it.
That was not my point at all, and we discussed the motivation a few pages ago already.
http://www.spacenewsmag.com/feature/why-nasa-is-hitching-a-ride-on-red-dragon/
"When NASA and SpaceX announced April 27 that they had modified an existing unfunded Space Act Agreement that involves the company’s "Red Dragon" Mars lander concept, it was, unsurprisingly, SpaceX that got all the attention. No company has ever flown a private Mars lander, and not even NASA has landed a spacecraft as large as SpaceX’s Dragon. Moreover, Red Dragon is the latest sign that SpaceX and its founder, Elon Musk, are serious about pursuing a long-term goal of Mars settlement".
Is there not a way where the retro-propulsion trick could be done BEFORE the vehicle gets to Mars' atmosphere.
All it needs then is some very heavy duty parachutes, but then heavy parachutes are heavy, and more fuel needed for the retro.
Here's some reading that can answer your questions better than I can. :smile:
http://www.universetoday.com/7024/t...ge-payloads-to-the-surface-of-the-red-planet/
http://mars.nasa.gov/msl/mission/timeline/approach/
http://mars.nasa.gov/msl/mission/technology/insituexploration/edl/
I'm still stuck on the problem of making a Mars mission economical. Even as little as 5K/kg is still enormously expensive given any reasonable payload demands. A moon base launch facility still looks more promising, assuming we can efficiently mine basic minerals and manufacture launch vehicles there. And as already noted, an emergency resupply mission is much more realistic on the moon. No need to shoot for Mars, when the moon is sitting right in our back yard and offers most of what we probably need to leap frog our way across the solar system. Either way, its an effort centuries in the making. I fully expect we will someday look back and chuckle at our primitive flailing efforts to colonize other worlds. I get a faint semblance of hope from that thought. Humanity has historically employed existing technology to bridge the gap towards new technology.
mfb said:
I never said that.
Earth was not colonized with 2050 technology, it was colonized by foot and with sailing ships. Surely we can do better with 2050 technology?If that would be true, why did you ask how to get the first steel foundry on Mars? How did we get the first steel foundry in the Americas? Someone built it. With tools built there, which were probably built with tools built there, and if you go back long enough you arrive at tools from Europe. The details are a lot of engineering work, but they are no fundamental problem.
You really do believe that a few decades from now there will be a city on Mars that looks like Abu Dhabi? Extraordinary!
Out of interest, which country do you think will build it? China, USA, Russia, EU?
mfb said:
I never said that.
Here are the fundamental differences between Abu Dhabi and Mars. Although, the fact that I have to explain this shows just how far into pure science fiction this thread has gone:
1) Food. Abu Dhabi had no problem with food, because it could import food from anywhere in the world. On Mars,. there is no option to regularly import food from Earth. In fact, Abu Dhabi probably couldn't support itself without the outside world.
2) Construction. Abu Dhabi did not need any factories or manufacturing base, because it could import everything it needed from the existing global manufacturing base. Mars can only import a relatively small amount, at huge cost.
3) Human labour. Abu Dhabi had access to a global labour market, to skilled and unskilled workers at all levels. These workers could be fed and housed using the existing global resources. Mars can only use labour that is transported there at a relatively enormous cost and with little or no flexibility.
4) Travel time. Abu Dhabi is only a few hours flight from Europe and Asia. Mars is approximately 6-12 months away.
5) Medical Facilities. Until Abu Dhabi had built its own hospitals, it had access to existing medical facilities elsewhere for serious illness and emergencies. The early Mars settlements will have access to only basic medical facilities. For an early Mars settler, something like appendicitis (or anything that requires major surgery) will most likely be fatal. Serious cases in construction sites on Earth can be airlifted to existing medical facilities within that or a neighbouring country.
6) Hostility to Human Life. Humans can live, eat and breathe normally in the UAE. On Mars, a significant life support infrastructre is required for all humans based there.
These are fundamental differences. These are differences that make one project feasible (at large, but affordable cost) and another project infeasible both technically, logistically and financially.
You may say that the existing global manufacturing base and supply chain on Earth is irrelevant, as everything on Mars can be built from scratch; but the global supply chain is essential for 21st century projects. Abu Dhabi, or any city on Earth, cannot be build without it. If Abu Dhabi had had to bootstrap itself and build all its own steel foundries and chemical plants first, and excavate its own raw materials from the ground before it could even start building, then it wouldn't and couldn't have been built.
The construction of a city like Adu Dhabi on Earth, without full access to our existing global manufacturing base, is virtually impossible.
The construction of a city like Adu Dhabi on Mars, with limited access to our global manufacturing base, is actually impossible.
But, the thing is, Adu Dhabi was built there because of a valuable resource. Can we find valuable resources on Mars? I guess we could, but shipping them back to markets on Earth is going to be, well, interesting. Let's see what Elon Musk can do with that problem! He is developing the ITS - https://www.physicsforums.com/threads/on-spacex-interplanetary-transport-system.889203/
I figure we would find it much easier to ship back resources that we find on the Moon. Therefore - colonize the Moon first!
Just land on Mars? See what NASA says about landing on Mars: -
“Basically flying into the plume at supersonics speeds, the rocket plume is acting like a nose cone; a nose cone that’s moving around in front of you against very high dynamic pressure. Even though the atmospheric density is very low, because the velocity is so high, the forces are really huge.”
For large craft, it's not a solved problem.
Perhaps all together (just like they try to work on the space station) ...
But EU is not a country (yet ...).
Mars:
Hey, a guy can dream! ... (why not)
Note: picture etc. taken from earlier PeroK post (didn't use official quote because it wasn't meant as a reply to that particular post).
