Mentor
- 23,905
- 11,363
Agreed. A similar argument is made for other space fantasy projects, like asteroid mining and lunar colonies. It is framed to sound like a chicken-or-the egg problem, when it is really just a chicken or the chicken problem: Building a city (or mining facility) from scratch on Mars or another body is really really hard, and saying it would get easier if you had all the manufacturing base locally is true...but just shifts the problem over a column. Building an industrial base on another world to use to manufacture the parts to build a city is itself a massive (and perhaps even bigger) project like building the colony.PeroK said:You may say that the existing global manufacturing base and supply chain on Earth is irrelevant, as everything on Mars can be built from scratch; but the global supply chain is essential for 21st century projects. Abu Dhabi, or any city on Earth, cannot be build without it. If Abu Dhabi had had to bootstrap itself and build all its own steel foundries and chemical plants first, and excavate its own raw materials from the ground before it could even start building, then it wouldn't and couldn't have been built.
The construction of a city like Adu Dhabi on Earth, without full access to our existing global manufacturing base, is virtually impossible.
And unlike building a fresh city in the middle of nowhere no Earth, we also have to invent a huge amount of new technology to make it happen. I assume we could, but whereas you can spend a hundred billion dollars and get a shiny new city in the desert, you'd need to spend a trillion dollars (or 10?) just to invent the technology before even starting the project itself!
[edit] For example, a single or small number of exploratory missions to Mars would probably cost at least a trillion dollars. These would do some preliminary research into whether or not it would be possible to farm on Mars. Assuming the results look promising, we'd spend another trillion dollars+ (and a decade or two) just on prototype/test farming operations, which would then tell us if it is feasible to farm on Mars, and how exactly we would do it. Then after that, we could start actually building farms (for trillions more).
