High School Why constant speed for light is so unique?
PLAGUE
TL;DR
Doppler shift shows that speed of sound is same even if the source is moving. Then why don't we consider it of the same importance as the constant speed of light?
I was studying doppler shift yesterday and found out that the speed of sound wave remains the same even if the source is moving. To compensate that, the wavelength and frequency are adjusted. I know that this is also true for light which results in red and blue shift. Then why in special relativity, this constant speed of light is given so much importance?
Or, is it entirely some different topic? My knowledge of Michelson-Morley experiment doesn't give me any clue whatsoever.
PLAGUE said:
TL;DR: Doppler shift shows that speed of sound is same even if the source is moving.
Only in the rest frame of the medium you have sound propagating at the same speed in all directions.
Light propagates at the same speed in all directions in all inertial frames.
As A.T. says, the speed of sound is constant with respect to the medium. In air it's about ##330\mathrm{ms^{-1}}##, but if you are running at ##10\mathrm{ms^{-1}}## (congratulations, that's a good 100m time) you will measure the speed of the wave as between ##320\mathrm{ms^{-1}}## and ##340\mathrm{ms^{-1}}##, depending if the wave is moving in the same or opposite direction to you, or at an angle.
We initially assumed this would be the case for light when wave solutions to Maxwell's equations were found and we realised the speed of such waves was the speed of light. Michelson and Morley carried out an experiment to detect the variation in the speed of light due to the Earth moving in different directions through light's medium (named "the ether"), but found no variation. Light had the same speed no matter what direction the Earth was moving, different from the sound case I described above. That kicked off a series of attempted explanations and experiments that ruled the explanations out one by one until Einstein came up with relativity. In relativity, the speed of light is always ##c## for all inertial frames - its frequency and wavelength and direction of travel may vary depending on how you are moving, but its speed doesn't.
Odd as that sounds, it turns out that you can have one speed that is invariant like that. And the resulting theory simplifies to Newtonian physics as long as you never experiment with anything travelling anywhere near that speed - which is why it took us two centuries to notice Newton was subtly wrong. It also turns out that anything massless (such as light waves and gravitational waves) travel at that invariant speed - which is why the speed of light is important to relativity.
Likes dextercioby and PeroK
It's not. The speeds of sound and light are fundamentally different.
The speed of sound relative to the moving source, measured by that source, is not the same as it is relative to a stationary object, measured by the stationary object. In fact, an airplane which exceeds the speed of sound actually goes past the sound that it has made.
The speed of light, relative to any inertially moving object, is measured the same (speed = c) by that object.
In this video I can see a person walking around lines of curvature on a sphere with an arrow strapped to his waist. His task is to keep the arrow pointed in the same direction How does he do this ? Does he use a reference point like the stars? (that only move very slowly) If that is how he keeps the arrow pointing in the same direction, is that equivalent to saying that he orients the arrow wrt the 3d space that the sphere is embedded in? So ,although one refers to intrinsic curvature...
  • · Replies 60 ·
  • · Replies 45 ·
