Why Denote 1 Form as dx? - Sean Carroll's Lecture Notes on GR
The discussion centers on the notation and significance of the 1-form basis represented by dxμ in Sean Carroll's lecture notes on general relativity. Participants clarify that dxμ serves as a basis for 1-forms, which are defined as linear maps from tangent vectors to real numbers, while ∂μ represents the basis of vectors. The exterior derivative df is established as a 1-form, with the relationship df = ∂μf dxμ derived from vector calculus. Key points include the independence of dxμ as a basis and its transformation properties, which affirm its role in the formalism of differential geometry.
  • Understanding of differential geometry concepts, particularly 1-forms and exterior derivatives.
  • Familiarity with vector calculus and the chain rule.
  • Knowledge of tensor transformation properties in the context of general relativity.
  • Basic comprehension of coordinate systems and their role in defining bases for vector spaces.
  • Study the properties of exterior derivatives in differential geometry.
  • Learn about the transformation properties of tensors and forms in general relativity.
  • Explore the relationship between 1-forms and tangent vectors in the context of manifold theory.
  • Investigate the implications of linear independence in the basis of 1-forms and their applications in physics.
Students and professionals in theoretical physics, particularly those focusing on general relativity, differential geometry, and mathematical physics. This discussion is beneficial for anyone seeking to deepen their understanding of the formalism of 1-forms and their applications in modern physics.
Ron19932017
Hi everyone I am reading Sean Carrol's lecture notes on general relativity.
link to lecture : https://arxiv.org/abs/gr-qc/9712019
In his lecture he introduced dxμ as the coordinate basis of 1 form and ∂μ as the basis of vectors.
I understand why ∂μ could be the basis of the vectors but not for the dxμ. I have several confusion with the 1 form basis.
1. Is the 1 form basis dxμ really have a meaning for infinitesimal change in xμ?
2. How to convince ourselves that dxμ(dxν)=δμν?
3. Am I correct to understand the formalism of 1 form like this :
Given that a. ) df = ∂μf dxμ from vector calculus,
b.) ∂μf is identified to be component of 1 form because it transforms covariently.
Therefore we realized df is a 1-form with dxμ as its basis.
4. (more general open question though) The most puzzling part for me is to understand the formalism of 1 form basis. I follows well in realising the basis vector as ∂μ not but for dxμ. I also appreciate anyone to explain why dxμ can be a 1 form basis.
1. It is a 1-form, not an infinitesimal change, although the two are related. For any tangent vector ##X## and function ##f##, the exterior derivative ##df## is a one-form such that ##df(X) = X^\mu \partial_\mu f##. If you let ##f## be the coordinate functions, you get N independent one-forms and therefore a basis.
2. You don't. As you wrote it it has no meaning. One-forms act on tangent vectors, not other one-forms. With the above in mind, you will find that ##dx^\mu(\partial_\nu) = \partial_\nu x^\mu = \delta_\nu^\mu##.
3. a) is just the chain rule. No vector analysis needed. You really do not need coordinates or coordinate bases to define ##df##. However, expressed in coordinate basis, you would have ##df = (\partial_\mu f) dx^\mu## directly from the chain rule.
4. See above. By definition, the exterior derivative of a coordinate function is a one-form. If you have a good coordinate system then all the ##dx^\mu## are linearly independent and therefore form a basis. You can express any one-form in this basis.
Thank you for you reply. I understand ##df## is a map from tangent vector to real number by ##df(X) = X^\mu \partial_\mu f## and how you get the ##d x^\mu## as 1-form basis.
1.)However how can you make sure all ##df## can be expressed in linear combination of ##d x^\mu##? My intuition tells me this has to be related to the chain rule but I am not sure how to work out the formalism.
2.) Why do we adopt the notation ##df, dx_\mu##, such that they looks similar to infinitesimal change? Why don't we just use ##f, x##
2. Because that d is actually an operator called exterior differential.
I see. Sorry I have a few more questions.
1. The logic is like : Exterior derivatives are p-forms -> df is the exterior derivative of a scalar function -> df is a 1 form?
2. How can we make sure exterior derivative are a (0,p) tensor at the beginning?
3. Which way we do formally testify something is a 1-form?
a.) show it transform covariently?
or b.) show it is a linear map of tangent vectors into real numbers and form a vector space?
I see both ways appear in various lecture notes so I am not sure if these two are equivalent criterion.
1. Yes.
2. By the way the exterior derivative is defined.
3. (a) A p-form is a p-form. It does not transform. It is always the same p-form. However, its components have some particular properties, including their transformation properties, that you can check.
(b) Is better. By definition, a 1-form is a dual vector. A single 1-form does not form a vector space. It is an element in a vector space.
Note that a one form, which some (but not all) texts denote with boldface as dx is a map from some vector space V to a scalar. This notation makes explicit the difference between dx and dx, the former operates on vectors and returns a scalar, the later is just a change in a real number (a coordinate).
So the value of both is comparable, But one operates on vectors, the other doesn't - it stands alone.
The boldface not/boldface thing is not necessarily done all the time, sometimes the reader is expected to know what is meant.
  • · Replies 31 ·
