Why Did My Capacitance Measurement Exceed Expectations?
23 replies · 3K views
flyingpig
Basically we did a lab on charges, capacitors and voltages. We used a 2200uF capacitor and we hooked it up with a 10kΩ Resistor connected in series with a DC Supply. The DC Supply was turned down to 0V and all the other senors were "zeroed" out.
Simultaneously, when we clicked on our computer data collecting device we turned the DC Supply on to raise the voltage to 1.0V steadily. The voltage had to keep going up steadily so we could get a straight line, y = mx + b, where m is the slope of the graph. The graph was Charge vs Voltage.
At the end, we did a line that best fits curve and our slope was 0.002262, which translates to 2262uF
Now my question, how come I got something big...?
The voltage and resistance. The "current" data was calculated using it. Then it was graphed against capacitance.
I think it is voltage across the capactor. Basically we had to hold the voltage "constant" by steadily increasing it (by changing the power supply's voltage), if we lose the rhythm we basically would screw up our own graph (we want a voltage vs time graph to be linear)
No I meant Charge vs Potential of the capacitor
Sammy stay with me...my TA has given up on me
In order to explain experimental results, it's important to understand what's being measured and also have a good idea about how those quantities are measured.
So, before trying to answer your basic question, I wanted to get some sense of what all was involved.
Having worked with these systems which use a computer to monitor and sometimes control an experiment, I now think I have a good sense of what you were monitoring.
The computer was monitoring the voltage across the resistor and also was monitoring the voltage across the capacitor. Knowing the resistance of the resistor, the voltage across the resistor could be converted to current via Ohm's Law. Then the current was integrated by the computer to find the charge on the capacitor - no doubt, assuming the capacitor started out in an uncharged state. The computer could then produce a Charge vs Voltage graph for the capacitor. This graph should be linear, the slope being the capacitance of the capacitor.
Why was this set up so the power supply voltage was linear in time? So that current current would flow at a reasonable rate throughout the data collection time - not be too large at the beginning - not tapering off too much over time.​
Now for your basic question, which I think is: Why was the capacitance that was determined by the experiment, 2262μF, larger than the actual capacitance, 2200μF ?
Components like resistors and capacitors are manufactured to a given tolerance. Your capacitance measurement is a little more than 3% higher than the specified capacitance. Not bad! Moreover, unless you measured the resistance of the resistor, that's probably also in error. If its resistance was higher than the 10kΩ assumed in the computer program, the current and thus the charge would have been less than that computed, so that the capacitance might actually be less than 2262μF, perhaps even less than 2200μF.​
I am a freshman, I am not sure if the word "tolerance" of a capacitor exists in our course...although I can understand what that means.
SammyS said:
LOL !
I came close a couple of times, but your persistence is amazing, (probably also annoying to your TA).
=( Don't give up on me...
Oh darn it...why do people hate me?
Wait how does the "tolerance" relate to the 62μF?
It's over for me. Thanks for helping me anyways (and always!) Sammy, I don't know what I'll do without this forum
Sammy, I've learned more about a capacitors in the last two days than ever lol
Yeah I have! But i just haven't even thought about that. Wait does that mean resistance = tolerance?
Although we only did it once...
You tested a 2200uF capacitor and found it to be 2262uF?
Get the manufacturer's name and part number off the side of the capacitor. Enter it into a search engine and pull up the data sheet for it. Find the specification called "tolerance" expressed as a +/- percentage. Most capacitors are either 5, 10 or 20 percent.
It would seem your capacitor is ok.
Edit: oops. I made a stale post. Tge tolerance issue is addressed.
It is a "nichicon" 2200uF
unfortunately the results thta came up are beyond me...
Can I just ask one last question? If the tolerance level were lower, would that have make my data better?
Sorry about the delay in answering.
The only way I can think of to determine whether your data were (The word "data" is actually plural.) good or not --- is to measure the capacitance by some other means. You also would need to measure the resistance of the resistor. I'm pretty sure the computer program assumes the resistance was 1 kΩ. I suspect that if the resistance were 1% lower than specified, then the capacitance you determined would be 1% higher than the true capacitance, etc.
When I checked out your link to the capacitor's manufacturer, the tolerance was ±20%.
Your result showed the capacitance to be about 3% higher than the specified value.
All that is beside the point.
If the capacitor AND resistor each had a tolerance of ±1%, then finding the Capacitance to be 3% high MIGHT mean your data were not too good.
