Why do absolute values appear in the simplification of square roots?
6 replies · 3K views
Rably
Simplify.
a) [tex]\sqrt{x^6}[/tex]
b) [tex]8 \sqrt{x^7y^{10}} - 10 \sqrt{x^7y^{10}}[/tex]
For b, it's y^10. I can't make it look right for some reason.
Mod note: Fixed the exponent.[/color]
I can simplify all of them but I don't know when or where I need to put in absolute value symbols to the solution. I know the solution because my book shows me, but I don't understand why the absolute values are where they are.
For instance, the solution to a is [tex]|x^3|[/tex] but I can only get to [tex]x^3[/tex] without becoming confused.
For b, i can get to [tex]-2x^3y^5 \sqrt{x}[/tex] but the solution is [tex]-2x^3|y^5| \sqrt{x}[/tex]
So how do you know when an absolute value is required?
Rably said:
Simplify.
Use y^{10}
[itex]\displaystyle \sqrt{u^2}=|u|[/itex]
Also, remember that if n is a positive integer, then [itex]u^{2n}\ge0\,,[/itex] so there is no need to use absolute value.
So in my scenario, x has to be positive because it's still underneath the square root so I don't need to put an absolute value around x^3, whereas y can be either positive or negative because it's not still beneath the square root so an absolute value is required?
No. x can be any real number.
Like SammyS said,
$$ \sqrt{x^2} = |x|$$
so
$$ \sqrt{x^6} = \sqrt{(x^3)^2} = |x^3|$$
This is also the same as |x|3.
Which scenario ?
If x is to an even power, that result is non-negative. So that can be under a radical -- actually one signifying a square root -- no matter what value x has.
SammyS said:
Which scenario ?
I was referring to question b. Do you mean if x has an even power in the initial equation or in the solution?
Like SammyS said,
so
Oh wow, I think it makes sense now. Seeing the step between x^6 and |x^3| was really helpful. I wasn't writing that step down, I was simply skipping to the final step. Thanks a bunch.
