Why do all measurements of neutrino speed show a positive delta t?
The discussion centers on the measurements of neutrino speed, particularly the observation that most measurements indicate a positive delta t (δt), suggesting earlier arrival times for neutrinos. Participants explore the statistical implications of these measurements and the ongoing debate regarding the possibility of neutrinos traveling faster than light.
  • One participant notes that all major neutrino speed measurements show speeds within the speed of light, but most indicate a positive δt, which statistically seems unexpected.
  • Another participant suggests that a formal meta-analysis could clarify the situation, emphasizing that the weighting of studies should consider variance rather than just count positive and negative results.
  • A different participant points out that only the MINOS 2012 measurement shows a negative δt with a small variance, implying it should carry more weight in the analysis.
  • Some participants express skepticism about the resolution of the "faster than light" issue, indicating that the scientific community continues to engage with this topic.
  • One participant argues that the best measurements from SN1987A are significantly more precise than others, suggesting that less accurate measurements do not contribute meaningfully to understanding the phenomenon.
Participants do not reach a consensus on the implications of the measurements or the statistical analysis methods. There are competing views on the significance of the positive δt observations and the ongoing relevance of the faster-than-light debate.
Participants acknowledge the limitations of the current measurements, including the small number of studies and the variances involved, which may affect the interpretation of the results.
Niceperson27
Hi people,
I have the following question:
First, here is a concise statement of the major neutrino speed measurements:
http://en.wikipedia.org/wiki/Measurements_of_neutrino_speed
As you can see all of them show that the speed of neutrino is within the speed of light, when taken into consideration the errors of course. But if you notice, almost all the measurements (MINOS (2007), OPERA (2011, 2012), ICARUS (2012), Borexino (see: improved analysis), LVD, Icarus, Opera) provide a positive δt (when no error is accounted for). Note that δt>0 indicates an earlier neutrino arrival time.
Shouldn't be that almost half of the measurement should provide a positive δt and half of them a negative one? I mean it does not make sense statistically.
Thanks
You would need to approach this with a formal meta-analysis. Usually in meta-analysis it is not simply a vote-counting approach, but the weighting is determined roughly by the inverse of the variance. So if you have a large number of high variance studies with a positive δt and a small number of low variance studies with a negative δt then you may still get a negative δt in the meta-analysis.
I don't know that anyone has done such a study, but it would be interesting.
Sure,
but if you take a look at the variances you will see that only negative \delta t is for MINOS 2012 (new timing system, where they improved the measurements of the previous old one), where the variance is in fact quite small.
Of course we would need more measurements (than the 5-6 we have) to see what's going here, but remember something IMHO: I do not think we are over yet with the ''faster than light'' issue.
Niceperson27 said:
Sure,
So, you think neutrinos travel faster than light?
I did not say that. I mean that I do not think that the scientific community has stopped discussing on this issue.
So that one will be given the strongest weight.
The best measurements are from SN1987A. These are about a thousand times better than the other measurements. I don't think you learn anything by looking at measurements 1000x worse and seeing how they are distributed. At best, that tells you something about the systematics of inferior measurements, not anything about nature.
  • · Replies 30 ·
9K
  • · Replies 19 ·
  • · Replies 18 ·
9K
  • · Replies 18 ·
