Why Do Angular Momentum and Energy Calculations Differ in a Collision Problem?
4 replies · 3K views
uq_civediv
the problem is the following:
we have a vertical wooden bar pivoted from the top end, length [tex]2 l[/tex], mass [tex]M[/tex]
a bullet with mass [tex]m[/tex] hits it in the middle at velocity [tex]v[/tex] and gets stuck
i am asked to find the angular velocity [tex]\omega[/tex] of the system bar+bullet immediately after the hit
i do know this calls for applying the conservation of energy or angular momentum, for some reason however i get different results
Both if them involve the moment of inertia of the combined system, [tex]I_{\Sigma}=\frac{1}{3} M (2l)^2 + m l^2 = \frac{4}{3} M l^2 + m l^2[/tex]
Conservation of angular momentum gives me [tex]m v l = \omega I_{\Sigma}[/tex], from which [tex]\omega = \frac{m v l}{I_{\Sigma}} = \frac{m v l}{\frac{4}{3}M l^2+m l^2} = \frac{m}{\frac{4}{3}M+m} \cdot \frac{v}{l}[/tex]
Whereas conservation of energy says [tex]\frac{m v^2}{2} = \frac{\omega^2 I_{\Sigma}}{2}[/tex], which gives [tex]\omega = \sqrt{\frac{m}{I_{\Sigma}}} v = \sqrt{\frac{m}{\frac{4}{3}M + m}}\cdot \frac{v}{l}[/tex]
So the big question is where did I mess up this time. I know it's something really basic because I can't see it. Usually i ask a deskmate or someone to have a look if they spot something really simple but since nobody's around I had to come here.
P.S. while you're at it, why do my [tex]m[/tex], [tex]v[/tex] and [tex]\omega[/tex] look superscripted but [tex]M[/tex] and [tex]2 l[/tex] don't ?
Your only mistake is in thinking that mechanical energy is conserved--it's not. This is an example of a perfectly inelastic collision.
To use Latex in the middle of a line of text and have it appear even, use "itex" as your delimiter, not "tex". It gives you [itex]m[/itex] instead of [tex]m[/tex].
so the angular momentum one is correct ? (just clarifying...)
and the loss in energy is the good ol' [tex]\int F ds[/tex] over the distance the bullet travels into the rod !
Yes.
Good luck calculating that! To find the loss in energy, just calculate the final KE and compare it to the initial.
o no wasn't going to do that, good luck indeed
just realising where the energy went.
case closed anyway
